My Brake Master Cylinder crapped out! $$$?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScrippsRanch67, Aug 11, 2022.
  1. Aug 12, 2022 at 4:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Never had an OE fail on a Toyota.
    But I have used after market master cylinders. Most of the time they are OK.
    If they aren’t bad right out of the box, you’ll probably be fine.
    I’d rather run an aftermarket MC than Caliper.
    That said, I don’t work on vehicles for a living. I’d wait for the other two guys to voice their opinions. They do this stuff every day.
    SUMOTNK likes this.
  2. Aug 12, 2022 at 4:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Aftermarket is fine, as long as its a reputable brand, I've never had a master fail after replacing it.
    I get costs, everything is crazy and I even try to save my customers money by suggesting aftermarket from time to time.
    SUMOTNK and TnShooter like this.
  3. Aug 12, 2022 at 6:15 PM
    Waasheem
    Waasheem
    2007 xrunner
    Agreed. Disappearing fluid doesn't mean a bad mc. It's going somewhere. You might be able to see something wet through the wheel spokes, or a puddle underneath.
    Symptoms of a bad mc I've seen are it's wet and leaking, push the pedal slowly it'll go to the floor, push it hard and fast it'll grab.
  4. Aug 12, 2022 at 6:28 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you don't see it leaking onto the ground pull the vacuum line off the booster and see if it's going in there, if it is you will need a booster as well as a master cylinder.
    stickyTaco and Jimmyh like this.
