My brake pedal vibrates at idle.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrdSurgie, Dec 31, 2017.
  1. Dec 31, 2017 at 1:04 AM
    TrdSurgie
    TrdSurgie [OP] revised
    Oahu
    So....
    I have developed a new vibration/buzz in my brake pedal. It only occurs while stopped, at idle, with the AC on. If I turn the AC off it goes away.
    No changes have been made to the truck for years now.
    I googled, only thing I found could be a leak at the booster? Is that even a thing of these trucks?
    What is it?
    ToyotaSam likes this.
  2. Dec 31, 2017 at 7:13 PM
    TrdSurgie
    Oahu
  3. Jan 6, 2018 at 9:57 PM
    TrdSurgie
    Oahu
    Damn you guys suck. Lol
  4. Jan 6, 2018 at 9:58 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Try bleeding the brakes
  5. Oct 4, 2020 at 4:59 PM
    ToyotaSam
    ToyotaSam Member
    2005 Access Cab Prerunner
    I have the same thing 2005 base. Quad cab 4x4.
  6. Oct 4, 2020 at 5:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The Engine bumps the RPM up when the AC is ON.
    Try turning the AC Off, then raise the rpm up 200-300, see if you get the same results.
    Also, does it do this in gear, in Neutral, or in Park?
    Jimmyh likes this.
  7. Oct 4, 2020 at 7:12 PM
    ToyotaSam
    ToyotaSam Member
    I mainly notice it in gear. Sitting at stoplights with my foot on the brakes. Usually not in park without for on the brakes.
  8. Oct 4, 2020 at 7:28 PM
    ICECOLDBEER
    ICECOLDBEER Well-Known Member
    2006 Tacoma 2.7L SR5
    Mine vibrates a little at idle. I used to shift to neutral or park at stop lights sometimes. Never really bothered me too bad so I never tried to fix it. I always assumed engine mounts but that's just a guess.
