My "Build" aka Resurrection...
Discussion in '1st Gen. Builds (1995-2004)' started by StaticFilter, Aug 22, 2011.
  1. Aug 22, 2011 at 9:12 PM
    StaticFilter
    StaticFilter [OP] Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    Mostly already built but I might as well start a thread anyway because I do have things to add/change/fix.
    Bought a 1998 Toyota Tacoma TRD Offroad Xtra Cab with 151,933 miles on 08/17/2011
    Equipped:
    3.4L V6
    5 Spd Manual Transmission
    Pre Runner Bumper (rhino lined and diamond plating inserts)
    6" Trail Master Suspension lift
    3" Body Lift
    Tire fenders
    Nice Fusion sound system
    Newer BFG Mud tires 33 x 12.5 x 15 ( 5/8" deep tread... under 3500 miles on them )
    Rhino lined bed
    Toyota rear E-locker ( Toyota 4.10 gear ratio)
    K&N Cold air intake
    Throttle body spacer
    Red top Optima battery
    Magnaflow muffler
    Also came with a HIDEOUS color scheme on the interior...
    Problems to Fix:
    -Replace both rear shocks (BAD)
    -Replace Idler Bushing on the driveline (BAD)
    -Fix "Airbag light stays on when passenger side enabled" issue
    Things to do:
    -Replace or repaint horrid interior dash color scheme
    -Hella Supertones Horn
    -Keyless Entry
    -Exhaust Tip
    Any *HELPFUL/CONSTRUCTIVE* suggestions or Ideas would be great, thanks guys and gals!
    First "Mod" :)
    Suspension pics...
    lift struts had rubber boots on them which had electrical tape on them...
    Cut the boots off, wire brushed the rust/corrosion underneath, then gave them a coat of Rustoleum enamel, should have used FLAT instead of Gloss black, oh well...
    They turned out looking okay, gave everything a bath in white lithium spray grease
    View from the rear
    Full size truck leaf springs?
    As it sits in my driveway
    Took it offroad through a creek bed that's been flooded with snow run-off
    Some flexin, rear passenger tire isn't touching, felt like i was going to tip over
    water was up to the hubs, got deeper
    Suspension was just fine, I think once I fix the driveline bushing, balance tires, and get new rear shocks, i'll be golden.
    4 High and Lo worked great, I have my doubts as to whether the locker is working do to the light never staying on, it just blinks slowly. Never saw an ABS light?
    *09/04/2011 Update*
    Bought a hitch receiver for $40 from a guy parting out his 2001 and installed it yesterday
    The install went fairly smooth and took around an hour from start to finish
    Next steps are taking the ball out of the bumper, wiring up a towing harness for trailer lights, and replacing the center support bearing. I'll buy the one from the guy with the 2001 for $10 for now, it's gotta be better than mine
    *November 1st Update*
    Added Roll bar with lights $175 and most of saturday to clean it up, redo lights, wiring etc...
    Safari Snorkel $Free took about 2-3 hours of work
    *January 6th 2012 Update*
    Just passed 155,555 Miles
    Went wheeling and blew my secondary strut on my Trailmaster lift.
    Installed my new ebay headlights and sidemarkers I got for Christmas
    Did some research on fixing the POS Trailmaster lift, looked into the Gabriel Inversion Mod since Trailmaster no longer makes the struts
    after checking out my lift closer, the Mod has already been done so It's as easy as replacing the struts
    Bought my new struts, I'll go the cheap route for now and see how long they last, next set may be Billies!
    [​IMG][/url]
    Also removed my Subs/amp for winter (talk about HEAVY and AWKWARD! Next time I'm taking the SEAT out first), and had a full service oil change with Mobil 1 Synthetic 5w30
    AND! Verified that my locker is in fact alive and well!
    Also replaced my OEM Spare tire carrier that had a broken cable
    *January 7th 2012 Update*
    Replaced the struts on my Trailmaster Lift and did the "grey wire mod" for my locker now that i know it works. Also fixed a grounding issue i had with my KC Lights on the bumper
    *May 18th, 2012 Update*
    SOLD! Sold the truck to a guy for $8650, kept the sound system. Got $13.67 more than my loan payoff so I'm happy. Guy that bought it is from Farmington, I referred him here to the site so hopefully we will see him around here. It's been a fun truck to drive, wheel, and work on. I feel like I've given it a second chance at a good life and hope the new owner enjoys it more than i was able to.
    Reason for selling? I need a 4 door, I was looking for a 4 door when I bought this truck so the search shall continue. Thanks to all of those that helped me!
  2. Aug 22, 2011 at 9:15 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    new hood... :p
  3. Aug 22, 2011 at 9:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Good to hear the truck wasn't as messed as it seemed!
    :popcorn:
    As far as the blinking locker, did you make sure it was in 4lo? Otherwise it just blinks....
    and some members here have said after not being used for awhile it takes a few tries to get the locker to engage.
    (I'd take that body lift off ASAP too. If Bowhunter was having problems with it way back then...)
  4. Aug 22, 2011 at 9:23 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    loose the bumper, mud flaps, hood scoops, body lift, ghey rims, and taillights
  5. Aug 22, 2011 at 9:27 PM
    StaticFilter
    Cedar Hills, UT
    You show me how to make a 2005-2011 Sport hood fit and I'll get right on it :)
    Yeah we shall see how bad it really is I suppose. Hopefully the locker is an easy fix/user error and the airbag issue isn't too pricey!
    What problems was he having with the body lift?
  6. Aug 22, 2011 at 9:28 PM
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    x2
  7. Aug 22, 2011 at 9:34 PM
    rcfreak201
    rcfreak201 Well-Known Member
    wasnt this that other 16 yr old kids truck?
    agreed on the hood, tailights, bumper and lift. i say take it all back to stock and put some nice coilovers on it and an all pro bumper or something like that, and get some 33s with nice rims or just sas it :D
  8. Aug 22, 2011 at 9:37 PM
    StaticFilter
    Cedar Hills, UT
    haha might as well have kept my 05 for how much you guys want me to spend to REDO the whole thing
  9. Aug 22, 2011 at 9:41 PM
    rcfreak201
    u sold the 05 for this?
  10. Aug 22, 2011 at 9:42 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Not everything, just that damn body lift....
    Pics of suspension? :D
  11. Aug 22, 2011 at 9:52 PM
    StaticFilter
    Cedar Hills, UT
    No, I sold the 05 for these:
  12. Aug 22, 2011 at 9:54 PM
    rcfreak201
    congrats brotha, im sure your on a budget haha but for now i would definitely take out that body lift and slowly start improving everything
  13. Aug 23, 2011 at 7:34 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Congrats on getting another Tacoma. The truck looks great other than the items you already mentioned, it makes one wonder why some people think some things look good like painting the air vents.
    Can't wait to see it on the trails.
    Didn't you buy a Dodge Dakota after you sold your 05?
  14. Aug 23, 2011 at 7:42 AM
    TacoMatt02
    South Carolina
    02 sr5 double cab
    most of the stuff people are telling you to do are cheap to free, take off your body lift, switch hoods with someone (sure someone would do it), sell your tails get stock ones (or nightshade your current ones), re paint your interior, and trade some one for your bumper. Your truck would look bad ass
    edit: actually just take off the skewpz from your hood, looks like there held on there with some 3m
  15. Aug 23, 2011 at 2:50 PM
    StaticFilter
    Cedar Hills, UT
    Yeah what a nightmare that turned into, Had to rebuild the bottom end. sold it for $1000 more than I bought it though so I came out even. Bought a 1993 Subaru Legacy after that, 230,000 miles, but it has a 2.2L Turbo and is AWD so it was a good deal for $1100
  16. Aug 23, 2011 at 6:03 PM
    StaticFilter
    Cedar Hills, UT
    Added more pics... I want to fit 35's when the 33's are dead, can i do that without the body lift?
  17. Aug 23, 2011 at 6:08 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I say take off the hood scoops (if they're attached), new rims, and take out the diamondplate inserts on the bumper...I think the bumper would look pretty good without them.
  18. Aug 23, 2011 at 6:10 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I'm pretty sure you can, a friend of mine does.
    I dig those KM1's though
  19. Aug 25, 2011 at 9:08 PM
    StaticFilter
    Cedar Hills, UT
  20. Aug 26, 2011 at 8:26 PM
    dustin81
    dustin81 DUSTOFF
    Rio Rancho, NM
    09 TaCo Lifted TRD
    PRO COMP 6" Lift Stage II PRO COMP 2.75" Coilovers PRO COMP MX-6 shocks PRO COMP skid plate Bushwacker Fender Flares Smittybuilt Chrome Steps KC Chrome 6" SLIMLITES Billet Custom Grill JDM window vent visors Window Tint Flowmaster TRD CAI
    nice truck cuz...
