My CB Installation (in detail)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Jan 15, 2011.
  1. Feb 11, 2011 at 3:56 PM
    #41
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    Thank You!!!!
  2. Feb 11, 2011 at 6:18 PM
    #42
    davidsdad
    davidsdad Well-Known Member
    Dave
    Grove City, Ohio
    Reg. Cab 4X4
    "Under Cover" Bed cover, 3" Suspension Lift, Sony stereo, 600w amp, Rockford Fosgate 12" sub, wheels, tires, (window tint coming soon).
    I have to disagree. I have a Firestick and get out more than 20 miles with my modified radio!!! I think Firesticks are on of the better antennas
  3. Feb 12, 2011 at 6:37 AM
    #43
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    ya, i have to agree. the firestick antenna is a good antenna. i know that i can transmit at least 5 miles in the city and i can receive signals from 20 miles away.
  4. Feb 26, 2011 at 9:51 PM
    #44
    day42
    day42 Active Member
    NJ
    06 Tacoma DC, with TRD Off-Road Pkg.
    None YET...some to come.
    Excellent write-up. Thanks for the pics, mostly. I may be getting a CB sometime soon and wanted to see a good way to route the antenna wire, and power wires. Thanks again.
  5. Apr 2, 2011 at 3:16 PM
    #45
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
  6. Apr 2, 2011 at 4:59 PM
    #46
    sicripp83
    sicripp83 Well-Known Member
    wboro
    sic
    great write up!! one question what did you do with the excess coax cable? iv read several different threads about what to do with it
  7. Apr 2, 2011 at 5:13 PM
    #47
    sicripp83
    wboro
    sic
    oh and one more question. im in the process of getting a bestop supertop and was woundering where everyone mounts their antenna toppers or bestops. the hood mount Relentless makes is sweet but i dont know about a 4ft firestick on the front of my truck
  8. Apr 2, 2011 at 5:26 PM
    #48
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    i would have liked to put my cb in the same spot, but my wife drives my truck once in a while and she would have had to move the seat foward. excellent job w the details.
  9. Apr 3, 2011 at 12:46 PM
    #49
    sicripp83
    wboro
    sic
    bump OP you must be out enjoying the cb
  10. Apr 3, 2011 at 1:14 PM
    #50
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    Awesome write up will def be using this in the future!
  11. Apr 3, 2011 at 5:03 PM
    #51
    NetMonkey
    Geogetown, TX
    i had about 2 feet of extra coax. so i stuffed it behind the bed pocket inside the fender.
  12. Apr 3, 2011 at 5:06 PM
    #52
    NetMonkey
    Geogetown, TX
    here is a molded side mount kit. you could bolt this into the side of your topper:
    http://www.rightchannelradios.com/c...unt-kit-firestik-cb-antenna-mounting-349.html
    EDIT:
    ohh.. i guess that topper is not made from fiberglass :)
    so maybe you could use one of their 3-way mounts:
    http://www.rightchannelradios.com/mirror-3-way-cb-mounts-85/
  13. Apr 3, 2011 at 6:54 PM
    #53
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Ya, fuses always go as near the battery as possible.
    I installed winch today and there doesnt seem to be a method of fusing it. I'm toying with getting an anderson power pole connector that I'll leave disconnected since having a 2 gauge wire ran thru my engine bay unfused scared the poop out of me.
    The other thing to note is that shortening a coax will mess it up is a total myth. Impedance is determined by several things, such as center conductor width, dielectric width, etc. Not length. As long as it is terminated properly with a good connector, make it as short as you'd like, The shorter the better really.
  14. Apr 3, 2011 at 7:14 PM
    #54
    NetMonkey
    Geogetown, TX
    umm... not with a NGP antenna. the length of the coax is very important.
  15. Apr 3, 2011 at 7:15 PM
    #55
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Great write up!
  16. Apr 3, 2011 at 11:35 PM
    #56
    anethema
    J
    Dawson Creek,BC
    Oh sorry, wasn't aware it was using the coax itself as the ground. Yes a minimum length will be needed for the ground plane. It's kind of a crappy design, but CB is a really crappy mobile system overall. Freq way too low for good mobile performance. It isn't used in Canada at all basically. VHF is King up here.
  17. Aug 5, 2011 at 7:38 PM
    #57
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    I have a regular cab that I am getting ready to install a Cobra 75 in and I have a question for you. I am trying to figure out how to run the cable without making a bigger hole in the grommet than I need. I saw that you cut one of the ends off, and attached it again using an o style connector. Was there a special mount you used on the antenna end? I always thought you had to use the connectors that came on there.
    Have you had any problems with mounting it the way you did? I would appreciate any tips that you might have. I have read this thread twice and I am about to look through it again, but your advice would be great.
    Thanks,
    Brandon
  18. Aug 5, 2011 at 7:42 PM
    #58
    Hayes
    Brandon
    Denver, CO
    ok, I'm an idiot. I just read the info right above the first picture.
    Let me make sure that I understand: NGP uses normal connection at the CB side and a bolt style/ring terminal at the other end? Does firestik sell the kit as a whole?
  19. Aug 6, 2011 at 9:13 AM
    #59
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Nice write up!
  20. Aug 6, 2011 at 9:34 AM
    #60
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
