My CB Installation (in detail)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Jan 15, 2011.
  1. Apr 4, 2012 at 10:34 PM
    #101
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    nice job
  2. Apr 5, 2012 at 5:49 AM
    #102
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i like the setup.
    there is electrical feedback from braking when the squelch is off. i wired the cb directly to the battery so i am not sure how else i could elliminate that noise. however, when i am on trail runs, i turn the squelch on so that there is no background static and that removes the electrical feedback.
    i cant think of anything that i would do differently.
    i have been through stream crossings that put the water up to my headlights and i have had zero water leaking into the cab from that grommet. i suppose if i left the truck sit in the stream, water might seep in. i suppose i could put some silicone sealant on it if it became a problem.
  3. May 21, 2012 at 4:15 PM
    #103
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    hey great write up .
    helped out when installing my cb .
  4. May 21, 2012 at 5:58 PM
    #104
    dlg636
    dlg636 Active Member
    Darrin
    Honolulu, Hawaii
    4x4 Tacoma w/all the goodies
    DR front coils and rear shocks, deaver springs, load leveling airbags, k&n intake, JBA hedders and exhaust,Unichip power chip, URD short shifter, onboard air compressor, upgraded power inverter (1000W put in stock inverters location) budbuilt traction bar, warn transformer winch mount and warn winch, HID headlights and foglights, full LED bulb conversion, LED bed lights, full stereo system with GPS and they all roll on 16x8 black steel rock crusher and 285/75R16 BFG KM2's.
    hello, just wanted to throw in my two cents. i am running a galaxy 929 in my truck with a 102" whip mounted to the back side of my truck box and i am able to hear and talk pretty far. i live in Hawaii and i have honestly had conversations with people in Australia, Alaska, California, Washington, Oregan, Arizona, Colorado, Alabama, Mississippi, and Florida. i have also heard people from Japan and Mexico, but haven't talked to them because i don't speak those languages. from what i learned on CB radio talk forum, its not about how good the radio is but how good the antenna is because all "legal" cb radio outputs is supposed to be only 4 watts. thanks for letting me throw in my two cents. Aloha all
  5. May 21, 2012 at 6:07 PM
    #105
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    dlg, how many watts is your antenna?
  6. May 21, 2012 at 8:48 PM
    #106
    dlg636
    Darrin
    Honolulu, Hawaii
    i'm sorry, what do you mean? i'm not running any boosters or amps if thats what your asking. the cb is a stock 929.
  7. May 21, 2012 at 8:51 PM
    #107
    nammer
    Nam
    Bradenton, Florida
    i'm not too familiar with cb setups, i thought u were saying legal antennas are 4 watts, so if they are stronger you will get better reception, so i thought u were saying you had more wattage, but im prob just confusing myself more, if you dont know what i'm talkin bout, then it prob doesn't mean anything :notsure:
  8. May 21, 2012 at 8:52 PM
    #108
    nammer
    Nam
    Bradenton, Florida
    yea i thought the antenna's were just plugged into the back of the cb radio with a coax?
  9. May 21, 2012 at 9:12 PM
    #109
    dlg636
    Darrin
    Honolulu, Hawaii
    @ nammer, ok, i think i know what your asking. yes, antenna's are just connected to the back of the cb via coax cable. the 4 watts i refered to is the output wattage of the cb radio. the legal limit is 4 watts (atleast here in Hawaii). so in order to get the best possible range you need to set up the best possible antenna you can (the better the setup the further you can talk). yes, putting boosters or amps or pumping up the watts in your cb (if possible) will give you more power to reach further also but i really don't want any federal agencies coming after me.....lol :eek:
    so in short- expensive radio + bad antenna= short range :(
    cheap radio + good antenna= long range :)
    expensive radio + good antenna= better long range :D
    cheap radio + bad antenna= you talking to your self....lol :mad:
  10. May 21, 2012 at 9:51 PM
    #110
    nammer
    Nam
    Bradenton, Florida
    haha, cool, thanks for the clarification, i appreciate it, yea that explains everything
  11. May 21, 2012 at 10:39 PM
    #111
    dlg636
    Darrin
    Honolulu, Hawaii
    "as recommended, the antenna is at least 2/3rds above the cab"
    op, if you can or want to try something to get a little lower SWR reading and a little bit farther range, you may want to try and move you antenna to the rear corner of the bed. my dad has the same antenna and fold over as you and had his mounted like yours. when he added his truck box, he move it the the back corner of the bed and he now can talk farther and, if i remember correctly, his SWR readings dropped to around 1.3:1. just something you may want to try.
    oh yeah, my dad has a 2009 (i think) access cab 4x4
  12. May 22, 2012 at 12:25 AM
    #112
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    Man I gotta get those parts
  13. May 22, 2012 at 1:11 AM
    #113
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Great job with the install, write-up & pics.
  14. May 23, 2012 at 5:35 AM
    #114
    dwsyab
    dwsyab Old Man
    David
    Sturbridge MA
    2012 TRD Offroad
    TRD Exhaust, rear diff breather mod, CB Radio
    CQ...CQ....CQDX...Do you copy? :D
  15. May 26, 2012 at 1:35 AM
    #115
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    sub'd. Looking to do a group ride out in silverado on the 2nd of July and this may come in very handy. Thanks OP!
  16. Dec 1, 2012 at 10:06 PM
    #116
    D.Holliday
    D.Holliday Well-Known Member
    Jon
    Portland, Oregon
    2008 Tacoma DCSB TRD Sport SR5 4x4
    Extang Trifecta Tri-Fold Tonneau Cover|Pioneer AVH-P1400DVD|3" Revtek Lift w/AAL|Pro Comp 7069|285x70r17 Federal Couragia MT's|Extra D-Rings Mod|Anzo Black Headlights|Corbra 75 CB w/3' Cobra Antenna & 4' Firestix Antenna|DTRL's Mod|L.A. Angels Sticker Mod|Smoked Aftermarket Tail lights
    That's badass. I like how the firestik can fold down, I haven't seen that before, i'm sure it comes in quite handy. I'll have to do this when I get the cash. I miss having a loud speaker since Iraq too, had way too much fun with that, may have to do that was well, ooooh I can see the flashing blue and red lights in my rearview now... lol. ;)
  17. Dec 2, 2012 at 1:42 AM
    #117
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    Good call with the fold-down!
  18. Dec 2, 2012 at 1:50 AM
    #118
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    that spot for cb would drive me crazy. especially with all the wire showing before it runs under the seat. i mounted mine here:
    for a bunch of different reasons.
    its screwed to the change holder thing so it can be easily replaced when if i were to get rid of the truck
    the fuse box/good ground location is right behind it, and the CB's power is tapped into the ignition fuse so it only comes on when the truck is on, fool proofing it from me killing my battery by leaving it on
    wires are all hidden, and very easily hidden, power/ground runs up behind the coin tray the radio is actually mounted to, and coax cable comes in just over the plastic right on top of the kick panel....
    also, so i could mount the microphone clip to a switch blank, once again, making it easy to replace if i were to decide i didnt like it there or was getting rid of the truck, youd never know it was there. it was also just a super easy location to put it, out of the way, and noone can really notice youre a nerd with a CB lol.
  19. Dec 2, 2012 at 4:23 AM
    #119
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    For all you guys out there that are nervous about drilling holes in your dash and resale, these are a few things I try to do/ think about.
    Try to drill holes under the dash rather than right in the face. Most dealers will completely miss those when you go to trade and you can always explain to s PP sale why they are there if they are seen.
    "Christmas tree" trim plugs are a great way to camo your holes if necessary. Your local body shop will have SEM dyes in rattle cans if you need to color match
    LED indicators are a good cover for a dash hole.
    Many times, a heat gun can be used to soften the plastic, and close up a small screw hole. Be very careful and do your research before doing this as you can also melt it, or discolor it
  20. Dec 2, 2012 at 7:53 AM
    #120
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
