My CEL came on
Discussion in '1st Gen. Tacomas (1995-2004)' started by only_K, Mar 16, 2010.
  1. Mar 16, 2010 at 9:42 AM
    only_K
    only_K [OP] 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
    It came on when i was driving to school. When i come to a complete stop and accelerate it shifts and a sudden jerk will slow my truck down for a second. When i finally get up to speed i go to step on it harder and it seems to shift up, rather than down. Its almost like a gear is missing. When i get home i'm going to put the scanner on it, but until i do, does anyone know what is happening?
  2. Mar 16, 2010 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Without the code, it could be a plethora of things....Post the code when you have it read.
  3. Mar 16, 2010 at 10:39 AM
    only_K
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    Ok. Ill be home in about an hour, ill post it then. my Dad thinks the tranny fluid might be low.
  4. Mar 16, 2010 at 11:40 AM
    only_K
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    ok the code is P0120
    The throttle position. ive gotten this error before but it never acted the way it did. hmmm i guess i should stop flooring it!
  5. Mar 16, 2010 at 11:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well....You can try cleaning the Throttle Body with some electronic contact cleaner, and see if that helps. If it doesnt, You can get a new TPS at Auto Zone for about $60.00 or so.
  6. Mar 16, 2010 at 11:59 AM
    only_K
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    ok. thanks for all the help.
  7. Mar 17, 2011 at 12:59 AM
    Tdubliture
    Tdubliture Member
    Tyler
    Sorry I know this thread is old but. Did that fix your issue? I have a Tacoma with the same symptoms.
