My chosen lift, couple questions...
Discussion in 'Suspension' started by mxracer452, Sep 7, 2010.
  1. Sep 7, 2010 at 5:48 PM
    mxracer452
    mxracer452 [OP] Member
    Spraggs, PA
    stock for now, 5100'a all around with 885 coils and 2' aal in rear, light racing uca's and m/t sidebiter wheels 16x8, and nitto terra grapplers 285/75/16 in the spring
    i've finally decided on a lift for my 2010 tacoma trd sport access cab 4x4.
    5100's front and rear
    ome 885 coils (shocks set on 0) with the top spacer
    diff drop kit
    rear 2" aal
    extended brake lines
    u- bolts
    is there anything else i would need???
    and
    do i need to get the axle shims for the rear? or could i get them later if needed?
    any input is greatly appreciated guys thanks in advance
  2. Sep 7, 2010 at 5:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Sounds good to me. I would try it out with no shims then add them if necessary. I personally would do the same with the diff drop since they don't really do much. You may be fine not running it.
  3. Sep 9, 2010 at 5:02 PM
    mxracer452
    Spraggs, PA
    ok, i'll try it without them and see how it goes thanks
  4. Sep 13, 2010 at 5:08 PM
    mxracer452
    Spraggs, PA
    wow only one response.....is everyone sleeping or something?
  5. Sep 13, 2010 at 5:34 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Not me! How much lift you gonna get up front? And yea I would wait and see if you have vibes before the cb drop and/or axle shims
  6. Sep 14, 2010 at 3:08 PM
    mxracer452
    Spraggs, PA
    i'm going with the 5100's set at zero with the 885 coils and the top plate, so around 3 inches i guess
