My cold vibration noise fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slvr2ndGen, Feb 2, 2014.
  1. Feb 2, 2014 at 10:14 AM
    Slvr2ndGen
    Slvr2ndGen [OP] Well-Known Member
    05 PreRunner DCSB, 2010 PreRunner DCSB
    Got tired of hearing that stupid noise when the outside temperatures got low so I set out to fix it yesterday. Before I figured it was the air tube where it went through the fender but upon further inspection it had plenty of foam and room to move in any direction. So I then looked at the engine cover and discovered that it is very close to touching the air filter assembly on the bottom. I added a couple pieces of the furry side of sticky back Velcro and what do you know, no more noise!!! Hope this helps others that are tired of that noise.
  2. Feb 2, 2014 at 10:21 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Mine was the air tube where it went through the fender. Unbolted it and moved it a little then tightened it back up. No noise since. Glad you found your noise.
  3. Feb 2, 2014 at 10:24 AM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    I'll have to try this. I have one at low rpm's(1000-1500) and between 15-25mph that is not the driveshaft according to the dealer. it only seems to happen when it's cold out.
  4. Feb 2, 2014 at 2:23 PM
    Slvr2ndGen
    Thats like what mine did except it would also happen at any speed where the rpm was low.
  5. Oct 20, 2014 at 4:03 PM
    goualon69
    goualon69 Well-Known Member
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    is it a constant vibration?
    mine vibrate for 2 seconds at every 6 seconds
