My Coming Out Party
Discussion in 'New Members' started by Athlaos, Mar 31, 2018.
  1. Apr 1, 2018 at 9:36 AM
    su.b.rat
    su.b.rat broken truck
    MT SC IN CN AWESOME
    Athlaos[OP] likes this.
  2. Apr 1, 2018 at 12:34 PM
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I actually have a question. I did a write-up for the relocation of my cruise control switch, where is the appropriate place to post that?
  3. Apr 1, 2018 at 12:38 PM
    su.b.rat
    here in the 3rd gen forum. or you can create your own build thread and put it here or in the builds forum. just title it appropriately.
  4. Apr 1, 2018 at 12:49 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    I thought URD specifically states Sequoia TB's don't work with the adapter?
  5. Apr 1, 2018 at 12:52 PM
    Athlaos
    Leigh
    Edmonton
    You, my friend, are today's winner. That was a test to see if you guys were paying attention. It is, indeed, a Tundra throttle body that I used.
    hoverlover and PapaBear[QUOTED] like this.
  6. Apr 1, 2018 at 12:54 PM
    PapaBear
    Austin
    SIN CITY
    What did I win? :rofl:I've got the adapter on the way, already have a 3URFBE TB from a '16 Tundra sitting in my garage.
  7. Apr 1, 2018 at 12:56 PM
    Athlaos
    Leigh
    Edmonton
    You win... uhhh... bragging rights, and the cruise control relocation write-up that I'm working on right now? Don't think about the fact that everyone else on the forum will win the writeup.
    What are your other mods? Do you have a link to your build?
    PapaBear[QUOTED] likes this.
  8. Apr 1, 2018 at 1:03 PM
    PapaBear
    Austin
    SIN CITY
    https://www.tacomaworld.com/threads/tbd-will-manifest-into-a-build-thread-somehow.524142/
    I literally have nothing in my build thread yet, but if you look in my info for mods, I have everything separated out. Lots of suspension at the moment waiting to be installed.
    My build is on hold, I've had my truck looked at by many shops. Shes leaking coolant internally, probably head gaskets, which I'm hoping Toyota extends the HG TSB soon to 07+. Power steering pump is bad, water pump is going, valve cover leaks, timing chain seal leaks, shes looking at with labor, a $5k job. I'm looking at my options at the moment. I've had the OVTune tuner level self tune kit since november, have a shop lined up for tuning, and I'll tune NA first. Then well go FI soon after(single turbo setup), that is as long as these repairs hold up. Also already have URD 160 thermostat and adapter ready for install as well.
  9. Apr 1, 2018 at 1:12 PM
    Athlaos
    Leigh
    Edmonton
    I feel your pain mang. I had to spend $4500.00 on a new transmission (part alone, did the installation myself - then when it was off I also realized I needed a new clutch for $1000... yeah...) but I am committed to this project.
    Don't let a little $5000.00 bill stop you from realizing your dream.
    Single turbo would be amazing. When you do that are you touching the bottom end at all or just keeping stock?
  10. Apr 1, 2018 at 1:15 PM
    PapaBear
    Austin
    SIN CITY
    Stock until rod 6 shoves its head through the bottom of the block like Jack Nicholson coming after Shelley Duvall in The Shining :anonymous:
  11. Apr 1, 2018 at 1:17 PM
    Athlaos
    Leigh
    Edmonton
    When one makes an analogy that alludes to a movie, I think one should always use a Stephen King analogy.
  12. Apr 1, 2018 at 1:18 PM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    :hattip:
  13. Apr 1, 2018 at 2:21 PM
    advan7
    advan7 Buy once, cry once!
    Orlando & Duuuuuuvalllll!
    2018 Cav Blue Pro
    V2.2021
    Welcome! Nice setup! :D:thumbsup:
  14. May 2, 2018 at 10:01 PM
    phillipthetaco
    phillipthetaco Well-Known Member
    Marcus
    Mesa,AZ
    2007 Tacoma Prerunner Barcelona Red
    Wheels and Tires: (5) 35/12.50/17 Toyo R/T tires (5) 17” x 8.5” Matte Black Method NV wheels Black extra thread (ET) spline lug nuts Front Suspension: Total Chaos 3.5” long travel kit Fox 8” x 2.5” coilovers with remote reservoirs Wheelers Super Bumps Limit straps and clevis mounts Total Chaos shock tower gussets Total Chaos cam-tab gussets Maxtrac 4 inch lift spindle Larger Lexus rotors, calipers and brake pads Stainless steel extended brake lines Rear Suspension: DMZ Fabrication Spring Under Kit Fox 16” x 2.5” smooth body shocks with remote reservoirs Fox 4” x 2.0” hydraulic bump stops (shortened to 3”) Custom low profile bolt in bed cage (1.5” DOM tubing) Boxed frame from fuel tank back Custom tube rear cross-member (1.5” DOM tubing) Custom bump stop mounts and strike pads Stainless steel extended brake lines Performance: AFE cold air intake w/reusable filter Nitro 4.88 Gears w/heady duty seals Custom driveshaft with grease-able slip-yolk Odyssey Extreme battery Armor: Custom front tube front bumper (1.5” DOM tubing) w/custom skid plates and valance Custom rear tube bumper w/license plate mount and led light Exterior Accessories/Body: SDHQ “y-strap” for spare tire mounting Harbor Freight 1.5 ton floor jack w/quick release mount Fiberwerx fiberglass front fenders Fiberwerx fiberglass “TT” style bedsides Custom window tint and tint visor Retrofit style Headlights LED tail lights Custom black mesh grill Viper alarm Rigid Industries 30 inch amber LED Rigid Industries 20 inch white LED Rigid Industries D2 Blue rear chase lights X2 Interior: Pioneer touch screen head unit Kenwood mono amplifier Rockford Fosgate 12" P3 subwoofer Infinity Kappa door speakers (4) Weathertech front floor mats LED interior dome lights
    Hey @Athlaos if you could pm me some info on how you did the steering wheel and the amount of work it took i'd appreciate it. Wanting to do an aftermarket wheel soon and figured i'd ask someone who has it done.
  15. May 12, 2018 at 6:15 AM
    #35
    Athlaos
    Leigh
    Edmonton
    Hey @phillipthetaco Sorry, I just saw your post. I can describe succinctly how I did it, however it's been a while and I didn't really take pictures. Give me a couple of days to put something together.
    phillipthetaco likes this.
  16. May 13, 2018 at 3:27 PM
    #36
    phillipthetaco
    Marcus
    Mesa,AZ
    Thanks man i appreciate it very much!
