My Console Subwoofer Build
Discussion in 'Audio & Video' started by Bazzy, Feb 10, 2014.
  1. Feb 10, 2014 at 10:53 PM
    Bazzy
    Bazzy [OP] Active Member
    Figured I'd start a thread for this. I'm building up a console subwoofer, very similar to the JL Audio one. I might have been able to get a better sub, but the rest of my system is Kenwood and I want to keep one brand throughout the truck.
    Subwoofer: 10" Kenwood Kfc-w2513ps
    EQ: SSL S4EQ
    Amp: Kenwood KAC-5001PS
    I cut the bottom out of the console and moved it up 5 inches. I'm trying not to lose my rear cup holders, I think there will be about 1" between their base and the subwoofer.
    Still waiting on my MDF ring. In the mean time, I can relocated my inverter and install the new amp. Luckily, all of my wiring is already installed from the outgoing enclosed subwoofer under the passenger seat.
    Inside the console, I'll be using car insulation with dynamat over that. Then install the console, lay down tape, and make a fiberglass mold. Once it's done drying, pop it out and finish the layers. Ideal Sealed Box Volume (cubic feet) is .65, my box will be .66
    My door speakers are Kenwood KFC-6984PS. They're powered with a Kenwood Kac-8405. Audio is fed from my iPad install that most of you have probably seen.
  2. Feb 10, 2014 at 10:55 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
  3. Feb 12, 2014 at 12:39 AM
    Bazzy
  4. Feb 12, 2014 at 12:49 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Looks like nice work so far...
    :popcorn:
  5. Feb 12, 2014 at 12:52 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Oh and Mmmmmm Reese's cups... :D
  6. Feb 12, 2014 at 1:09 AM
    Bazzy
    Those bastards put them right by the register.
    My biggest concern is vibration. While driving, I almost always have my arm resting on the console with hand on the shifter. It's going to drive me insane if it's buzzing uncontrollably . Do you think I should double up the sound deadening? I'm concerned with removing too much space
  7. Feb 12, 2014 at 1:15 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  8. Feb 12, 2014 at 1:23 AM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Does that duct insulation have a bad smell to it at all?
  9. Feb 12, 2014 at 1:23 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Interesting place for a sub but anyways sub'd
  10. Feb 12, 2014 at 1:30 AM
    Bazzy
    I read that people were using roofing insulation, and during the summer time their cars smell like asphalt. Frost King is meant for plumbing and has no smell
  11. Feb 12, 2014 at 1:32 AM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Awesome thanks!
  12. Feb 12, 2014 at 3:15 AM
    Airframes Chief
    Airframes Chief Well-Known Member
    Kekoa
    Kailua-Kona, HI
    Super white TRD 4x4 DCSB
    K&N drop-in filter, AFE performance exhaust, mild sounds by Kicker/Alpine and BedRug. 7.5" lift/18x10 Moto metal black 962/33" Toto M/Ts.
  13. Feb 12, 2014 at 3:56 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Yeah kind of a damned if you do, damned if you don't situation there. I would certainly go over the whole console and check screws and clips etc... Re-enforce where you can there. That might help. I don't think you're going to get away from all vibrations.
  14. Feb 12, 2014 at 8:35 PM
    Bazzy
    Not much to update, bad weather has delayed my shipment. I can't proceed with the glass until I have my MDF ring and speaker. I did get my EQ hooked up and layered the box. Painters tape wouldn't stick to the sound deadening material so I did a layer of duct tape. I decided to go as far into the console as I could.
    I think I may need to relocate the EQ, but I love it in the console. I think it's just taking up too much room. I'm going to get some packing peanuts tomorrow and test out the volume first. Another thought is eliminating that random cup holder.
    Another note, my door speakers amp wasn't tuned correctly, I wasn't getting much bass to the doors. Now that it's fixed, I need to pull my door trim and line them with deadening material. They are rattling like crazy with the bass up
    Another edit, maybe I should move the EQ to the cubby underneath the AC controls and make a door, like this:
    I want an OEM appearance, I don't like aftermarket things clearly visible
  15. Mar 8, 2014 at 9:05 PM
    cmcmanigal
    cmcmanigal New Member
    Connor
    Los Angeles
    Any updates? I'm extremely interested in doing this and curious how yours turns out. I also don't like aftermarket things visible.
  16. Apr 8, 2015 at 11:59 PM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    King anti-titty bouncers TRD spinney air generator
    subd with hope!
