My Continued Frustration w/ my Transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by ghoststoglory, Nov 14, 2010.
  1. Nov 14, 2010 at 11:50 AM
    ghoststoglory
    ghoststoglory [OP] Well-Known Member
    OK, so it all began here four months ago.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/101834-so-i-think-i-trashed-my-transmission.html
    Since then, I finally finished the Tundra brake upgrade, and attempted to drive my truck today....nothing happened. The truck starts fine, but does not engage any gear. This is a rebuilt auto tranny in case you were wondering. Also, when I attempt to go into park when it's running, there is a grinding sound coming from somewhere in the tranny. FML. I'm really at my wits end here, and not sure what to do. I think I'll finally bite the bullet and bring the truck to someone, I've just got to figure out who. Anyone have any ideas what the hell might be wrong now? It now shifts through all the gears...but engages nothing, and grinds when going into park. Oh yeah, and the truck rolls forward like it's in neutral, in any gear. ANY insight would be helpful, thanks.
  2. Nov 14, 2010 at 5:20 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    subscribed
  3. Nov 15, 2010 at 12:10 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    sounds like a bad transmission pump
  4. Nov 15, 2010 at 3:50 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Which equals bad trans
  5. Nov 15, 2010 at 8:42 PM
    ghoststoglory
    I know for a fact he changed the pump out...could it be bad again?
    Also, anyone know anyone in North Texas I could take this to? Trustworthy, reliable, etc...
  6. Nov 15, 2010 at 8:50 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    is the driveshaft connected?
  7. Nov 15, 2010 at 10:09 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    I'd personally take it back and tell the first gentleman/woman to fix it right...unless you somehow burnt through the clutch packs or burnt the pump up by not haveing enough fluid or something
  8. Nov 16, 2010 at 8:25 AM
    ghoststoglory
    I filled the torque converter and tranny, so I don't think tjat was it. The guy who rebuilt it is in Colorado...I'm in Texas. I'd have to pull it and send it off
  9. Nov 16, 2010 at 11:21 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    When you filled the converter did you have it running and shift through gears?
    change your fluid and check if its dark or has alot of material
  10. Nov 16, 2010 at 1:34 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    What was the cost for the rebuild if I may ask? I know we all want to save a buck, and there is nothing wrong with that, but sometimes it bites you in the ass.
  11. Nov 16, 2010 at 6:27 PM
    ghoststoglory
    I'm not sure what you mean by did I fill the converter when it was running...how would I do that? I filled it before I attached it to the tranny.
  12. Nov 16, 2010 at 6:35 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    your saying if you get in the truck ,and put it into drive,and press the gas the trans shifts gears but it doesnt move?
  13. Nov 16, 2010 at 7:14 PM
    03redtaco
    03redtaco Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
    im thinking the same thing. I know its a stupid question.
  14. Nov 16, 2010 at 8:20 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    was the truck running when you filled the trans was what i was implying, i had mine idoling while i filled to circulate fluid but idk if its a requirement
  15. Nov 17, 2010 at 4:27 AM
    ghoststoglory
    "your saying if you get in the truck ,and put it into drive,and press the gas the trans shifts gears but it doesnt move"
    yes, it does not move in any gear, and yes, the driveshafts are connected
    I filled the tranny before starting it, and then topped off the fluid a little bit twice
  16. Nov 17, 2010 at 7:39 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    im thinking A. rebuilder didnt do a good job. B. clutch packs are burnt up for some reason. or C. you may have forgotten to plug something in. D. is your shift lever connected properly? E. Did you bolt the Torque converter to the fly wheel?
    if you none of these work id check the fluid and drop the pan for any possible clues
  17. Nov 19, 2010 at 11:10 AM
    ghoststoglory
    I'll be working on it tomorrow...we'll see what happens...
  18. Nov 19, 2010 at 11:33 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    but does it shift gears?
  19. Nov 20, 2010 at 7:22 AM
    ghoststoglory
    Yes, it shifts into every gear, and does nothing in every gear. When I return it to park, is when the grinding noise occurs.
  20. Nov 20, 2010 at 7:25 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    ok,can you tell if the drive shaft is turning when it is in gear?
