My Custom PrInSu Roof Rack
Discussion in 'Other Builds' started by Chux, Feb 11, 2015.
  1. Feb 11, 2015 at 10:08 PM
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    BA4DD3E7-81D8-4A20-8665-E2210FA1BCE0_zps_28f5887ef7cbf74039498cf95821ceb4738e4f90.jpg
    FD3FFD44-0FBE-4023-8753-4C413EC96F0A_zps_2c531510242c6d315488d166bced6a458f9b1777.jpg
    87260A57-B40F-4AE6-B233-422BB847731B_zps_d68f4b8e9373e6a0c353acd9d18f9b035aa15ff0.jpg
    I recently finished a roof rack that has been an idea in my head for sometime now. I am a firm believer in "don't just talk about it, be about it", so when I had this idea I couldn't let it go. Wanted to bring you through a little journey of my rack build. Thank you to Zach from PrInSu Designs for working with me and helping making this happen.
    The main idea was to have a slim line roof rack to support accessories on top and host a roof light bar in the most sleak fashion. I knew from the start I was going to use the PrInSu roof rack as a base. I noticed a couple custom racks made for a 50" light bar, so I started thinking custom was possible. After back and forth emails with Zach, I had to start figuring out the dimensions to bring this idea to life.
    This is my idea on paper
    F471F2D4-AEB4-468F-B479-EBAF37F599F8_zps_24e0e61875dac20a5dd971b83f8bc664d4fc720f.jpg
    And here is the dimensions I came up with needed. I decided to give myself extra space that i can trim to my needs once I was able to see how everything lines up once assembled.
    51AF27B6-0F1E-4D4C-819F-D454901A7BA2_zps_f308f2af73aebee12c8666c469aa4b2fcafefef9.jpg
    I sent Zach the dimensions and waited for the rack to arrive.
    When the rack arrived the first thing I did was bolt two cross bars together with the side rails and layed it up on the truck! Couldn't wait to see it with the light bar.
    5F073BFD-34AC-454E-B3B2-DF89F4D50655_zps_5200afa4b424b1dfdfdf8ceab30aba3af294c4ed.jpg
    A323F6A0-4625-4048-925A-654956B6A394_zps_d02f8ea92ae45903493249f33336d1f6d71610ad.jpg
    A7C4BA34-CDD0-44FA-8158-D31FA3C04BB6_zps_d1bedb28d5662c354e80d6c7aa386ae1649f2f33.jpg
    Then had to throw all the accessories on top to finally see what it will look like when complete. Nothing is bolted down, you would do the same :D
    32D600F8-AE60-4301-B2F9-618FC1D6A1DB_zps_bf6e9364e7620546ff098e0e231671547597347f.jpg
    CDEAD459-6183-48A5-8C33-1D56D3611CB5_zps_2500e13ddec8af9dd7cf445b96e3560e6c98cca3.jpg
    Then became time to start the fabrication. A combo of no garage and the winter weather turned my spare bedroom and kitchen into a workshop :anonymous:
    74B45931-AB91-41B9-8EFA-43D9EC70348B_zps_bdb1438fc50249774791646702049aa2e7e98680.jpg
    8B87C47D-97ED-4831-937B-C16DCFAC790C_zps_a537054bfab1cac0a9cfb744ebe93255c69771df.jpg
    First problem arrived when I realized that with a curved light bar, the mounting arms can not be mounted behind the bar on a flat surface. The curve only allows it to be mounted above or below the light bar.
    BACD2508-A77F-423B-8A48-831A703A69CF_zps_03fcf237251a09006bc42bffee600979036674ca.jpg
    6144EA4A-45F3-4C39-82A2-029CC7CF3A46_zps_0d6fd130b14d5599a15910b863693d6e6a69f8d2.jpg
    Needing it to be mounted behind I grinded down the mounting arms, then was able to mount it as needed. I asked to not have any holes drilled for fairing or light bar. That way I can position them to my liking. I found the best position for the light bar, drilled holes, and bolted the cross bar that will hold the light bar.
    8B191851-42AB-460F-8FDF-CB7284603A42_zps_73c1acf081dce2363e7242806bab984cb0323608.jpg
    85F47858-1F13-46A1-88C2-A3F5B8E54BF4_zps_49fb024343e228fd243ec1e4d621007339b7fb4a.jpg
    0F961276-54C2-474A-93F6-F16BC3E3E5B5_zps_5c9056506039767bba79470e1fec148c7fdcaff6.jpg
    Next was to trim the side rails. I wanted to take the curve of the light bar and follow that line all the way out to the side rails.
    D74EB0AA-AAB8-4218-8AE5-F8F4749F1ECD_zps_b1900dd6bdde1d98be0302ac65f4e45923d028e9.jpg
    6FC797B2-0311-45E8-926B-C693A27C22B0_zps_547d3b28a7459d4b06b6a856b82d404cca982878.jpg
    I wanted to use my chop saw but the metal blade I had for it had a good wobble when I turned the saw on. So I had to resort to an angle grinder. Cleaning the cut with a flap wheel really made for a clean result.
    DB774519-E0F3-4944-8532-325D5D725D57_zps_72f17d413aa80f1ded7bfda4043f68402cca2458.jpg
    83B34147-7264-4CA4-95E7-6F93B893C32B_zps_7297da3286bc09e3e1579d3d2d2e5bbf3662df0f.jpg
    E2B57F9F-B2ED-4863-9215-B7A49CE15F66_zps_4afda39b8e63e85eecd015a43d51e3b291e7c0be.jpg
    5C156620-2BD8-4852-856E-57E4BE1A01B2_zps_ab9c13663a66bfc9b758d9758813758f2a6c99bf.jpg
    Visually checking it out, step by step
    547C2F5D-836D-42B8-A897-1B75DD2DB1E9_zps_7e9d7c244c3cf0b188e4900d89a4c8d4da7efb57.jpg
    B089B28D-99DA-494B-9BA1-614A01666550_zps_6fcf491602d035cfd5b39ee604380a464e79ede3.jpg
    BD25696F-3F84-4CE4-8940-C2BA76A221FB_zps_fa12f690ede8c6245e3bdbf65ff433566d4ad28e.jpg
    Now came time to figure out mounting the accessories that will live on the rack. The accessories will be a Pelican rifle case transferred into a storage box, got that idea from Zach himself. A set of TRED recovery ramps, and a 4 gal. rotopax fuel can.
    Before getting the rack installed and buttoning everything up, I decided to figure out the TRED mounts. Got the idea of using a piece of angle iron as the base from geekhouse23's build. Then used long bolts to thread the TREDs. For now washers and wing nuts will hold them in place.
    5496A3E4-92E7-4FC8-B263-9601C411BEA0_zps_2f86eca874d653eb5163a8ed8eee092178bd8cc1.jpg
    A33636DA-0856-40C0-B3E8-C7F4C69B00BC_zps_39fd8c7a884989e831f10ba9d06bb1ec98a56fb5.jpg
    76CE8973-8943-4AE4-9210-CFBBCFB54F8A_zps_86bc6baa2c340d94da20dc15fc1cb5b493fd7dcd.jpg
    Time for install. I filled the tap holes in the roof and the aluminum spacers centered over with rtv silicone and bolted down the rack. All the cross bars were preassembled including the light bar to the side rails.
    I ran the light bar wire harness down the passenger side window.
    5B0EA541-C3A8-44A3-8379-B74FF8B69EFC_zps_0c7b862c3c8965da1d85299cc89803c3a95c9fee.jpg
    The 4 gal. rotopax fuel can was an easy mount with the 4 gal. roto mounting bracket. The TRED mount was prefabbed and ready to go.
    Last up to mount is the Pelican box. I picked up 2" square U bolts which fit the crossbar perfectly!
    598A8B58-8A0F-48F5-A034-DCD4E4F19977_zps_a9dc9a0f07c4715990fdcdcc8d62a780fdb0cc62.jpg
    FAD23DB7-026C-4A1F-A573-23E58D245A85_zps_a213fa6f323486f1bc0852e7e46e084cf6af110b.jpg
    Quick look of everything kept in the Peli box
    709D7B98-F0ED-4CEF-A744-4F404F45001B_zps_1417a1caccf4cb8d00972c7c900a5049149603f5.jpg
    B16D1DDF-E15A-4861-9BBE-F7B4A7459E38_zps_cac6a52cec59ddc5fae2e00eaca75a33fcb50545.jpg
    2754FE66-72E9-4544-80B8-EF2881024FF9_zps_cf5463184a26ccc776a9a7963016ec9d92e3805a.jpg
    Finished the rack and accessory install just in time for a little snow storm. Come morning I went out for a drive feeling invincible :burnrubber:
    50AE48C2-772B-4D33-8078-8B8526B2CF4B_zps_c73fab35e25c1307682822206f855267731a5486.jpg
    9C90479A-65B4-414E-89A7-85BFB2BC40DD_zps_5b320f0fdd01e6cd165c68dcd120ca96d76004a6.jpg
    Once the storm passed I started on the custom fairing. Ordered some black plexi glass and started sizing it up with cardboard.
    346042D8-E516-476F-AF86-3138866C6EDB_zps_65822f7063e49059829e144878a7e519dfcdc3a0.jpg
    A0DEDE56-8D0A-446A-A0AA-67BEFC3C9682_zps_b2c732606b770ea8eb3460b82f84d291742db0fa.jpg
    Decided to paint the carboard real quick to visually see what it would end up looking like. Once I did that I realized i may want to fill in the space on both sides of the light bar.
    262B09A7-A8F3-4FB4-963D-428B6C3DAF96_zps_9bbee2ff29388a54da88071d6fe8e3dfb04e3a79.jpg
    3F24962C-409F-4ABB-9C1D-E53ED5130E48_zps_8130988c93aa50be14574f5bf9bdd4bab86a637e.jpg
    956859A4-60D8-4FCF-AE15-A614987DBD12_zps_eaec4e1633eb7bb3114d87fcb5ce52e97411ddaf.jpg
    Plexi glass showed up so I picked up some hardware and started fabbing. First order of business was the fact that I was out of T nuts from the rack order, so I made some T bolts. The rest just fell into place after cutting out the fairing.
    0F287F15-FFEB-4073-B453-02A3AC5B6BC1_zps_88a986926d5fc3f2445837537f1e905f0845e403.jpg
    F190CADF-F47B-4A76-A26C-A4A6F4483C06_zps_25a0af64d989b4fb778056283d853851b43bd33d.jpg
    83004159-FF58-4631-8972-41AC040C6776_zps_777f65487ffa1ad51b4ad2ebd28b58f8472dfb7c.jpg
    705E1E6E-40F0-426D-8C7B-09ED211C7BA1_zps_13f0e48ae0e7387385af22c898006a7f13de1e57.jpg
    741066B1-645E-4D24-B3AF-DCA44192F0C0_zps_19b3bc3b61f5b1ebf68c4fc906ca8e85c5a5a6ad.jpg
    3997982F-98B8-4A6C-B93F-B8771BB1C1B8_zps_c475fcc8e6d49fae07e49a7fb32435e6808ea4f4.jpg
    Very Stoked with the turn out of my custom rack.
    Thanx again to Zach at PrInSu Designs for working with me and making a great product. This rack is sleak, strong, and versatile.
    If your in the market for a roof rack checkout http://www.prinsudesignstudio.com/
    81055354-8B2B-4E96-BFD3-24CC9B29B1E5_zps_6f871ce8f4b76ae630959d448f2ac28119ce9526.jpg
    Kronk21, jaymz25, Isosceles and 7 others like this.
  2. Feb 11, 2015 at 10:37 PM
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    subbed..... great job man that looks incredible! Very impressive especially bc you did it out of your spare bedroom/kitchen hahaha.
  3. Feb 11, 2015 at 11:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    :thumbsup:
    Great job
  4. Feb 12, 2015 at 3:54 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Great idea on the bar mounts
  5. Feb 12, 2015 at 4:11 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Awesome job and amazing write up. Definitely subbed.
    Thanks for the shout out too! :eek:
  6. Feb 12, 2015 at 4:15 AM
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    if i could do a set up like this i wouldn't really need a bed rack. how long is that pelican case? I have one on my bed rack and am wondering if i would be able to rotate it and run it along the top of my access cab. I thing the one i have is 40"-42" long.
  7. Feb 12, 2015 at 7:00 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Great write up. Turned out awesome!
  8. Feb 12, 2015 at 7:33 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    so.much.win.
  9. Feb 12, 2015 at 7:34 AM
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    Nice job. I'm curious why you used square U bolts on the Pelican instead of the T-slots on the cross member. I've got a set of racks on order from Zach and reading your post makes me feel like a little kid when Christmas is still weeks away haha. I can wait to get mine and start adding my gear to them.
  10. Feb 12, 2015 at 9:38 AM
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    There is allot of strength in using U bolts. The Pelican box is heavy and takes the brunt of the wind drag. I feel good when I'm going down the highway that it's definitely secured to the rack. The T slots are very versatile but only allows you to thread up to 1/4", which is fine for other applications but as far as the Peli box I wanted it to be extra secure, and it was easily done with the U bolts.
    Toynado likes this.
  11. Feb 12, 2015 at 9:41 AM
    Rebelimo
    Rebelimo Well-Known Member
    Coatesville
    08 4x4 Silver streak Limo
  12. Feb 12, 2015 at 9:47 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Wow. That's all that can describe the work done for the rack and great writeup too!
  13. Feb 12, 2015 at 4:39 PM
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Awesome, looks good. I finished up mine yesterday, pretty excited that I finally have a place for everything. I'll need to revise a couple of things but otherwise it's solid. Thanks for the pics that lead me in the right direction.
  14. Feb 12, 2015 at 5:48 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    looks good man!
  15. Feb 12, 2015 at 6:20 PM
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Thanx for all the positive feedback. I actually cant wait to see what you guys are doing to your PrInSu racks. Feel free to post up ideas or pics!
  16. Feb 12, 2015 at 11:11 PM
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    No pictures of how everything looks like on the rack (same as Chux besides a black case)
    But heres how I made my mounts, I was trying to figure how I could mimic your setup but I only have the standard bars (I should have just got the HD ones) So I ended up just using flat pieces of aluminum, I wanted a sheet but couldn't find anything local
    Incase someone wants a cheat sheet of what to buy
    Roto Pax
    (2) At least 3' x 1.5-2" piece of aluminum strips
    (4) T-slot nuts (I used 5/16-18 square nuts and slimmed down 2 sides)
    (4) 5/16-18 bolts with both flat washers and lock washers
    TRED
    (2) At least 3' x 1.5-2" piece of aluminum strips (I went with 2" since I was drilling 1/2" holes in the center)
    (4) 6" x 1/2" threaded rod? (I used 2 1ft pieces and cut in half)
    (8) 1/2" nuts
    (16) 1/2" fender washers
    (8) 1/2" lock washers
    (4) 1/2" Wing nuts
    nut/lock/washer/aluminumstrip/washer/lock/nut/washer/treds/washer/wingnut on all 4 corners
    All I need to do now is drill holes for the middle cross bars to eliminate some of the slap that I get on bumps. Still looking for a lock option besides a cable for the TREDs
    Toynado likes this.
  17. Feb 18, 2015 at 5:28 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    This thing is amazing... gimme!
  18. Feb 18, 2015 at 6:58 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Chux - Where did you source the Pelican Box from? Thx!
  19. Feb 19, 2015 at 6:03 AM
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
  20. Feb 19, 2015 at 6:10 AM
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Moar rack pics
    2545379A-E1C7-4DD5-92AF-0828282F9931_zps_fabe9e333021c0880773143b2033e2a38ec93667.jpg
