my CV boot mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Dec 1, 2011.
  1. Dec 1, 2011 at 10:39 AM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    a little over a year ago, i had a 3" lift installed. i knew the fins on the cv boots were touching and i have been monitoring them ever since. i have about 12k miles on the lift and now there is about a 1-2mm deep wear ring on the cv boots. i read on another tread on TW that several people have used hose clamps to reposition the boot. so, i gave it a try too....
    so here you can see the fins touching and the resulting wear ring on one of the fins. (the wetness that you see it not leaking grease. its from diving in the 5 inches of snow that we had today :) )
    to get the stock clamp off, you can pry up the end of the clamp with a screw driver. i was really suprised at how easy these clamps come off.
    after prying to a certain point, the clamp just pops loose.
    you can see the 3 ridges and holes on the clamp that you have to pry apart.
    it didnt take much adjustment of the boot to prevent the fins from touching. i moved the end of the boot maybe a half inch down the shaft.
    i used just a regular 'ol hose clamp from home depot. it is a 1-1/4" to 1-3/4" clamp. i screwed it down very tight.
    no more touching.
    this is super easy to do and it took all of 10 minutes.
    hopefully, this will be a permanent solution and the end of the boot wont slip back to the stock position. i will keep monitoring it.
    if this does work, then it will be the best $2.60 that i have spent on my truck :)
    Start: 12-01-2011 @ 20700 miles
    Check: 12-09-2011 @ 20814 miles: boot slipped back a little, but the fins are not touching.
    Check: 12-24-2011 @ 20939 miles. boots are at the same spot as the last time i checked.
    Check: 3-11-2012 @ 24200 miles. boots are at the same spot.
    Check: 7-8-2012 @ 27324 miles. boots are at the same spot.
    Check: 8-23-2013 @ 40350 miles. boots are at the same spot.
    jackn7, Ngneer, helix66 and 19 others like this.
  2. Dec 1, 2011 at 10:43 AM
    BattleStatic
    BattleStatic Gluten Free
    Goodyear
    2013 TRD O.R. 4x4
    OME 885's w/Nitro Chargers and Dakar rear leafs ATX AX199 Mohave I I (0 offset, 4.5" bs) BFG KM2 285 75 16 Avid Sliders w/ kickoffs Pelfreybilt rack w/ Tepui RTT Katzkin front and rear Sunroof
    Interesting. Good write up, keep us posted.
    Ngneer likes this.
  3. Dec 1, 2011 at 11:38 AM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    :woot:
    sub'd. let us know if it slides back into place
  4. Dec 1, 2011 at 11:52 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    This :spy:
  5. Dec 1, 2011 at 7:44 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    nice! sub'd
  6. Dec 9, 2011 at 11:51 AM
    NetMonkey
    Geogetown, TX
    UPDATE:
    after about 100 miles, i checked the clamp and the fins of the cv boots and all is good. even though the boot slipped back a little bit, the fins are not touching. yay :)
    the boot of the clamp that i did not tighten down as much slipped more. these clamps really need to be cranked down VERY tight.
    if the fins do end up touching, i will reposition them and crank the clamps down even tighter.
    also, i am keeping a record at the bottom of the first post on this thread.
    Ngneer likes this.
  7. Dec 9, 2011 at 2:49 PM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    Please aware me......
    Good idea but im confused. Why is it bad if the fins are touching? Isn't the boot to just keep the lubrication on the joints? Its not like your changing the angles of the shaft, and its the angle of the shaft is what will make the axles wear prematurely. Right?
  8. Dec 9, 2011 at 2:59 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Because, if they rub, they can wear prematurely and this will cause an opening to occur. Then you'll leak out the grease and allow in dirt and debris. If they don't touch, then no friction on the fins and no wear.
    Marc70 likes this.
  9. Dec 9, 2011 at 3:04 PM
    Twiostaco
    Austin
    Utah
    Well there's my "duh" moment for the day Haha
  10. Dec 9, 2011 at 3:08 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    So Simple, It's Brilliant
    Gatta love a thinker, thanks for the Write-Up.
    I'm assuming the original clamp is a bitch to reinstall.
    Or is that the original problem, that it doesn't hold?
    CC
    Ngneer likes this.
  11. Dec 9, 2011 at 3:08 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    This is a great write-up! Is there anything to condition the rubber, some kind of oil or grease that won't corrode the rubber? My boots look really dry, I just used a red rag and some 40w, but I am thinking it just made them shiny and look good instead of helping?? Anyone else have a suggestion? Not trying to Hi-jack sorry.
    Ngneer likes this.
  12. Dec 9, 2011 at 3:10 PM
    RedTaco2134
    Scott
    Portland, Or
    CapeCodder: The " Rubber Boots Fin's " touch and the new hose clamp helps hold it in place, so that they will not rub on each other. <<< Oo " Rub on eachother " :crazy:
  13. Dec 9, 2011 at 3:24 PM
    Sunner
    Sunner Well-Known Member
    Sub'd. CV boots rubbing is one of the bigger issues with lifts right? I will definitly be doing this.
  14. Dec 9, 2011 at 3:46 PM
    Cape Codder
    Jack
    Yeah, knew that, just never thought of the mod to solve it.
    Still curious if the original clamp is the problem,
    not capable of holding the boot expanded
    Thanks again, Toyota :smack:
    CC
  15. Dec 9, 2011 at 3:47 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Try silicone spray... doesn't tend to pick up abrasive dirt/dust as much.
  16. Dec 9, 2011 at 4:32 PM
    NetMonkey
    Geogetown, TX
    the stock clamp is only meant to hold the boot at the stock position. it is not on very tight and only holds the boot in a little groove on the shaft. taking the stock clamp off and stretching the boot to a new position requires a new clamp that can hold against the tention of the stretched boot.
    Marc70 likes this.
  17. Dec 9, 2011 at 4:34 PM
    NetMonkey
    Geogetown, TX
    ya, when you do a coil/shock lift above 2.5", you run a greater risk of the cv boot fins touching. my lift is at least 3" so there was no question that they would touch.
  18. Dec 9, 2011 at 4:36 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    that's a trick that All Pro uses when installing the CV boots for their LT kits. very simple to do. i have regular standard hose clamps on each end of my boots
  19. Dec 9, 2011 at 4:42 PM
    Cape Codder
    Jack
    Thanks. So it's just the design.
    Lookin' forward to the long term outcome.
    BTW: Nice job thinkin' outside the box.
    CC
  20. Dec 9, 2011 at 8:43 PM
    RedTaco2134
    Scott
    Portland, Or
    Gotcha, read it to fast the first time....I am e-tarded..:facepalm: D'oh! ..
