my CV boot mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Dec 1, 2011.
  1. Dec 9, 2011 at 8:48 PM
    jandrews
    '09 FourDubDee TRD OR
    The times I've read about this before, without an internal spacer the boots tend to slide back into place. Interested in long term results after several thousand miles. May try spacing mine out some.
  2. Dec 22, 2011 at 12:21 AM
    juan01
    juan01 Well-Known Member
    Guam
    05 TRD Sport Doublecab 4x4
    Toytec 3" Ultimate Lift Kit Light Racing LCAs
    So will this work if they are at a crappy angle?
  3. Dec 22, 2011 at 12:26 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Thats the point of this mod
  4. Dec 22, 2011 at 1:50 AM
    rdm197aps
    rdm197aps Well-Known Member
    Rick
    DFW
    10 TRD Sport 4x4
    ARB bulbar WARN M8000, OME/Dakar, enough recovery gear to yank a GEO Tracker outta ditch!
    rumor has it that silicone spray is a reconditioning agent for rubber. I'm sure some one on here will disagree with me, but that's something i heard a while back. i use Teflon with silicon spray on my door seals bi-annually. at least it keeps the rubber black. i haven't seen any premature wear from the Teflon-silicone spray yet. guess time will tell.
  5. Dec 24, 2011 at 9:32 AM
    jandrews
    Interested in an update on this.
    Just spaced mine out today. I took the added step of adding RTV underneath the lip of the boot that gets clamped. Hopefully this will cure and act as an internal adhesive in addition to the force of the clamp and make the boot more resistant to sliding backward.
  6. Dec 24, 2011 at 9:46 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  7. Dec 24, 2011 at 11:13 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Isn't there a way to hold the clamp from slipping back? My truck isn't raised, but I would install another clamp 1" from the one that holds the boot, and some how tied this clamp to the first one to hold it in place. Or, I suggest inserting a sheet metal under the clamp, which rests on the ridge under, and this metal will have a raised shoulder on which the clamp will set. Has to be a method, just my 2c.
  8. Dec 24, 2011 at 11:19 AM
    jandrews
    People have put in internal spacers to fill out the groove in the axle where the boot normally rests. This requires rebuilding the CV though. It's plan B if this doesn't work.
  9. Dec 24, 2011 at 11:20 AM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i just checked and the boots are at the same position as the last time i checked.
    i havent driven that much this month so there is only 240 miles on this mod.
  10. Dec 24, 2011 at 11:26 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    this!
    the one trick that i think i may try is when replacing the stock boot to cut the rubber and leave the rubber and band from the stock boot and install the new boot. use the piece of old boot and clamp as the spacer...
  11. Feb 3, 2012 at 8:06 AM
    ross123
    ross123 Well-Known Member
    fort bragg
    great idea man ill be doing this, this weekend
  12. Mar 11, 2012 at 1:33 PM
    NetMonkey
    Geogetown, TX
    just a little update. i drove 2000 miles across the country so i now have about 3300 miles on this mod and it is holding up fine. the boots have not slipped back and the fins are not touching.
  13. Mar 11, 2012 at 1:36 PM
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Darryll,
    Thanks for the update. How high, from hub to fender is your front? I have the same lift as you and my CV angles do not look near as bad and my boot fins aren't even close to touching.
    I'm at 23 1/4" hub to fender.
    Justin
  14. Mar 11, 2012 at 5:39 PM
    NetMonkey
    Geogetown, TX
    lemme go measure.....
    EDIT:
    wow... i really do have the taco lean :)
    left front is at 23.5"
    right front is at 24.0"
    i should really turn down that right side.
  15. Mar 11, 2012 at 6:24 PM
    #35
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I have heard silicone spray can kill your O2 sensor? Not sure if if is true or not? But I still never use around my vehicles.
  16. Mar 11, 2012 at 6:36 PM
    #36
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Mine hasnt moved as well, did it in Jan... Thanks for sharing this tip. Never thought about doing this till I read this.
  17. Mar 11, 2012 at 8:16 PM
    #37
    elk340
    Justin
    Ouray, CO
    That might explain it, you're sitting about 3/4-7/8" higher than me on both sides. This might explain why your angles are a little steeper than mine.
    I have the taco lean too! My left front is at 22 5/8" and right front is at 23 1/4". Did you crank yours higher after the install?
    I think, once the suspensions settles and I need another alignment, I'll put both sides at 23.5" and do your boot mod! I think I will go ahead and safety wire the inner and outer clamps together though, even if unnecessary, it couldn't hurt.
    Justin
  18. Mar 11, 2012 at 8:19 PM
    #38
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    Wish I would of thought of this when I installed my lift both my inner boots are junk now
  19. Mar 11, 2012 at 8:27 PM
    #39
    jandrews
    Also of note:
    I've had mine this way a few months, including a couple wheeling trips. No return slippage thus far. Key is cranking the replacement hose clamp down damn tight.
  20. Mar 11, 2012 at 10:45 PM
    #40
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
