my CV boot mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Dec 1, 2011.
  1. Mar 11, 2012 at 10:57 PM
    #41
    bhh2000
    bhh2000 Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Some silicone oil. It can be had in a spray can just gut up there and spray them everyone once and a while.
  2. Mar 11, 2012 at 11:49 PM
    #42
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    This is more than just a rumor. It's recommended to annually spray down the door weatherstripping on any vehicle. My experience indicates it works great, too! I would imagine it would work on CV boots, too.
  3. Mar 12, 2012 at 10:04 AM
    #43
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    no, i didnt lift mine higher. that is where darren set them. i am thinking that it might be too high though. what is that measuerment without the lift?
  4. Mar 15, 2012 at 7:34 AM
    #44
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Mine, prior to the lift, was 19 1/2" hub to fender on the left front and 20 3/8" on the right front.
    Justin
  5. Mar 15, 2012 at 7:54 AM
    #45
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Also, on top of keeping the rubber in good shape, it helps prevent your doors from freezing shut in cold climates.
    OP thanks for taking the plunge and giving this a shot. I'm going to have to look into doing this.
  6. Mar 15, 2012 at 10:59 AM
    #46
    NetMonkey
    Geogetown, TX
    damn... then i got a 3.5 in lift.
    i think i might lower that down a bit... now to find the spanner wrenches :)
  7. Mar 15, 2012 at 1:49 PM
    #47
    jandrews
    '09 FourDubDee TRD OR
    Just use two 9mm hex wrenches.
  8. Mar 15, 2012 at 2:24 PM
    #48
    NetMonkey
    Geogetown, TX
    wouldnt i bend those while turning the collar?
  9. Mar 15, 2012 at 3:27 PM
    #49
    jandrews
    I haven't yet.
    Thin nose punches work pretty well too, probably better.
    And leave your front at 3.5. I'm at 23.5 front, 24 rear. Rears too low. needs another 1-2 inches.
  10. Mar 15, 2012 at 4:39 PM
    #50
    elk340
    Justin
    Ouray, CO
    With the Dakar leaf pack, I'm at 25" hub to fender in the rear with a 200 lb topper on. Others are at 25.5" w/out the topper.
    Justin
  11. Mar 15, 2012 at 5:38 PM
    #51
    jandrews
    That's why I am purchasing Dakars in the very near future.
    Toyota factory springs simply don't get it done. I lose about an inch in the rear when I load up my tools/spare parts/recovery gear for wheeling trips (together they total about 150lbs). I also have a hi-lift, bed rack, and fullsize spare that live in the bed which all add up to around 100lbs of everyday weight.
    So total, I want something that maintains a ~25in ride height with 250lbs. in the bed. And I don't want it made by All-Poo.
    Dakars with the D29XL add a leaf sound about right.
  12. Mar 15, 2012 at 5:44 PM
    #52
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    great writeup and pictures!:thumbsup:
  13. Mar 15, 2012 at 6:56 PM
    #53
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Since I got my front lowered (about an inch..) I haven't had any issues, but before when the spring perch was jacked way up I was going through cv boots faster than tony montana through a mountain of cocaine. Also, some tech put the bolt where the shocks attaches to the lca on backwards, so at full lock it would catch the booty ( :D ) and rip it. Might do this mod to be safe though. Cool write up man! Hope to see you around at the next meet.... Whenever that is....
  14. May 6, 2012 at 5:41 PM
    #54
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Just did this mod today and removed my dagum front diff drop!
  15. May 15, 2012 at 7:09 AM
    #55
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    :woot: love this mod!!
  16. Jun 1, 2012 at 1:22 AM
    #56
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Would this mod void my warranty if for any reason I have to take the truck into the dealership. I really need to do this mod cause I am getting the wear ring on my inner boots.
  17. Jun 1, 2012 at 4:35 AM
    #57
    jandrews
    You've already got a lift, larger tires, and wheel spacers, and you're worried about *this* causing warranty problems?
  18. Jun 1, 2012 at 4:54 AM
    #58
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    My dealer told me that my warranty is good to go, just whatever i replace wont be covered....
  19. Jun 1, 2012 at 5:38 AM
    #59
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    YEA UNTIL YOU BRING IT IN FOR SOMETHING THEN YOU WILL FIND OUT THE TRUE STORY....
    THAT TRUCK IS FUCKED
  20. Jun 1, 2012 at 5:41 AM
    #60
    NetMonkey
    Geogetown, TX
    haha... that made me laugh :)
    .... and the clamps are still holding...
