my CV boot mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Dec 1, 2011.
  1. Nov 5, 2012 at 5:57 PM
    #81
    jandrews
    '09 FourDubDee TRD OR
    ಠ_ಠ
    Please tell me you don't actually believe this?
    TS4x4 and Rrowdy like this.
  2. Nov 5, 2012 at 6:06 PM
    #82
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    .......seen it happen?
    I'm talking about the worm clamp exploding.
  3. Nov 5, 2012 at 6:07 PM
    #83
    jandrews
    Not because of a hose clamp you didn't.
    ...then replace it.
  4. Nov 5, 2012 at 6:19 PM
    #84
    gasgasman
    Girard
    Texas
    OK. You win.
  5. Nov 6, 2012 at 11:48 AM
    #85
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    the oem clamps are not tight enough.
    i have driven almost a year with these clamps and they have never exploded. i even did a 2000 mile, cross country trip at 70-80 mph and the clamps didnt budge or explode :)
  6. Nov 6, 2012 at 4:25 PM
    #86
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    I've had hose clamps on mine ever since the OP installed his. No problems yet. I have had one start to slip on me though and have since safety wired the inner and outer clamps together so that they pull against each other preventing one or the other from slipping back into their original positions.
  7. Nov 8, 2012 at 10:12 AM
    #87
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Did mine today. The OEM FJ clamps are a little different than the Tacoma ones. Instead of being able to open up, I had to cut mine off. They made it so you can just barely pull it off the boot. Then I just used garden shears and cut them off.
  8. Nov 9, 2012 at 5:42 PM
    #88
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    I am doing this mod fo shizzle since my fins are making babies together.
  9. Nov 9, 2012 at 8:10 PM
    #89
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Good idea, subd
  10. Nov 10, 2012 at 12:18 PM
    #90
    TeamLombardo
    Tony
    El Paso
    Did the mod this morning. Holy shit you really have to crank down those clamps! After mod I drove to Target (3 miles round trip) and when I got home the fins had moved closer together. They weren't touching, but were close. I readjusted the boots and cinch down the clamps real tight like (cut into boot collar a bit). Lets see what happens.
  11. Nov 10, 2012 at 12:21 PM
    #91
    NetMonkey
    Geogetown, TX
    ya, i really had to crank down on the clamps too, but once the clamps are tight enough, the boots wont move.
  12. Nov 10, 2012 at 12:25 PM
    #92
    TeamLombardo
    Tony
    El Paso
    It felt like I was gonna destroy the clamps with how much I was torquing them down. The ends of the boots now flare out. You run into this at all?
  13. Nov 11, 2012 at 5:11 AM
    #93
    NetMonkey
    Geogetown, TX
    i looked back at my original post and the ends on mine maybe flared out a tiny bit.
    perhaps you got some grease on the shaft?
    you could try loosening the clams, pushing the boot all the way in so all the fins are touching, and then whipe the shaft off so that there is no grease on it. then expand the boot and reclamp.
    its worth a try.
  14. Nov 24, 2012 at 4:58 AM
    #94
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    I also used a thin bead of RTV on the shaft to be sure the boot would not slip....got that tip rom jandrews....shows he is good for something :rolleyes:
  15. Dec 3, 2012 at 5:13 PM
    #95
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    omg yes!!! such an easy/good idea, thanks for sharing.. mine rip all the time.
  16. Dec 3, 2012 at 5:20 PM
    #96
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Under the boot between the boot and the CV? Or just around the edge where it meets the CV?
  17. Dec 13, 2012 at 1:58 PM
    #97
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Doing this mod tonight. Just installed my Icon coilovers and my fins are rubbing.
  18. Dec 13, 2012 at 2:50 PM
    #98
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Just a bead around the CV, then slid "just the tip" over the bead and clamped it down with the hoes clamp....
  19. Feb 4, 2013 at 6:36 PM
    #99
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    So has anyone else done all 4 boots? Any issues?
  20. Feb 4, 2013 at 7:42 PM
    #100
    jandrews
    No need to do the outers.
