my CV boot mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, Dec 1, 2011.
  1. Feb 5, 2013 at 9:16 AM
    #101
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Yup.
    Nope.
    I have one where the grease is seeping under the clamp, but that's my fault, as I slid it too far and had to back it out, thereby allowing some grease between the boot and the shaft. Nothing major, but it is annoying.
  2. Feb 5, 2013 at 3:46 PM
    #102
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Good to know. I am getting OME 885's and want to have all my bases covered before the install
  3. Feb 13, 2013 at 12:07 AM
    #103
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    might have to do this... :spy:
  4. Feb 13, 2013 at 1:21 AM
    #104
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Just gonna throw it out there that the hose clamp mod "prolongs" the cv boot after a lift, it will not prevent tears
    Or at least when wheeling.
    I have all 4 done
  5. Feb 13, 2013 at 5:57 PM
    #105
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Driver boot started leaking. Looks like the clamp might have cut it. I think the clamp shifted in. The passenger side is perfectly fine. Dealer is picking it up tomorrow. Fingers crossed
  6. Feb 18, 2013 at 7:52 PM
    #106
    tmreyes1
    T-Rey
    TX
    2017 TRD
    So I got the boot covered under warranty at the dealership. After thinking about it I remember running over a flattened can that got thrown up by the car in front of me. That might have cut the boot. Dunno but at least it got fixed for free :headbang:
  7. Aug 22, 2013 at 1:03 PM
    #107
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Is anyone else's lower boot just impossible to move up the shaft the 1/2" or so that is shown in the OP write up??? :confused:
  8. Aug 22, 2013 at 7:40 PM
    #108
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    I had to work mine side to side a bit to loosen it up and then they were able to slide back and forth. I did all four and then safety wired the inside and outside clamps together with wire...no problems yet and it has been 7k miles.
  9. Aug 23, 2013 at 3:47 AM
    #109
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    yup.
    I have about 28k miles on this mod now and it is still preventing the boots from wearing a hole in the ribs.
  10. Aug 23, 2013 at 3:57 AM
    #110
    FATaco
    FATaco Meh
    Friends call me Ginger
    Fairbanks
    07' TRD DCSB
    Dakars w/AAL, OME/886's, All Pro Front Bumper, Rear bumper, IFS skid, and UCA's. Superwinch Tigershark. Magnaflow muffler... vrooom
    Just a thought. I've got around 115,000 miles on my truck, been lifted most of those, CV boots have always touched, no leaks or tears. Not sure it's an issue worth messing around with and possibly causing damage. Just my $.02
  11. Aug 23, 2013 at 4:22 AM
    #111
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I wonder if you aren't right on. If we had pure rubber boots that would ball and flake off. These have silicon in them and become self lubing. What's more they move together since its one piece. It folds and unfolds. I'm sure it wears more than a non lifted truck, but enough to wear all the way through? I kinda doubt it. Now failure from being stretched beyond the molds rest point? This I can see.
    This thread has been around a while so to each his own.
  12. Aug 23, 2013 at 8:04 AM
    #112
    elk340
    Justin
    Ouray, CO
    I thought this requires clarification:
    I pulled out the inner and outer boots for both axles and put clamps on both the inner and outer boots. I then safey wired the outside clamp on the inner boot to the inside clamp on the outer boot. This way, neither the inside boot or the outside boot can slide without pulling on the other boot.
  13. Sep 27, 2013 at 8:05 AM
    #113
    typeone
    typeone Well-Known Member
    central MA
    2013 TRD Off-Road 4x4 DCSB BLACK
    2.75" Rancho QuickLIFT Loaded coilovers, LR UCAs, Wheelers 1/4" poly top plate spacers, FBG diff drop, Toytec swaybar relocate, Wheelers 2" AAL, LRO 1" tapered blocks, RCD Bilstein 5100 rear shocks, OME carrier bearing drop, OEM roof rack, Access Literider tonneau, SCS Stealth 6 wheels, 285/70r17 Nitto Terra Grappler G2 tires
    i know this is an old post but... i had a similar idea but with some good grip glue i use on the dirt bikes. wonder which would hold better. probably both the same since it's only helping a tiny bit.
    doing this mod soon but going with something other than a super cheap worm drive clamp. i dont want to cut the boot end from the crazy forces needed to hold the boot in place.
  14. Sep 27, 2013 at 8:11 AM
    #114
    typeone
    central MA
    good idea!
    and to FATacos point... i dont think it's simply the boots touching because they rotate at the same speed. cleanliness of the boot has a lot to do with it (IMO). if there is grit in there from off-roading, this will cause more friction and wear.
    i dealt with this on my lowered 4x4 (street truck) with boots totally smashed against each other. i kept the boots super clean, wiped with silicone or similar often, and never had a problem.
    thecoz likes this.
  15. Feb 4, 2014 at 2:10 PM
    #115
    NetMonkey
    Geogetown, TX
    well... the right inner boot finally tore and then it sprayed grease all over the place. it had lasted about 36k miles with the lift. I guess its the price you pay for modifying the truck :)
    the left inner boot is still good though :)
  16. Mar 27, 2014 at 4:50 PM
    #116
    Sandrail
    Sandrail Member
    Paul
    San Antonio
    08 Tacoma 4dr 4wd
    3inch lift winch mount spot lights bed mounted spare roof rack lt285 75r r16 tires cb radio
    Also one thing to remember the outer cv boots are made of a thermo plastic,and do not last as long as the old school boots,so the idea of reposition with a better clamp is way better. I am in a slow process of replacing the outer boots with all pro boots.
  17. Dec 31, 2014 at 1:59 AM
    #117
    MTNROMR
    MTNROMR Well-Known Member
    Cy
    Jackson, CA
    2014 TRD Sport DCSB 4x4
    Build thread in signature.
  18. Sep 29, 2015 at 9:21 PM
    #118
    Yota_Wolf
    Yota_Wolf Active Member
    Tyson
    2011 Tacoma TRD
    Readylift Front & Rear, 32" Wrangler Duratracks on Procomp Crawler Rims, Diff Breather, Custom Bed Rack, Catback Magnaflow exhuast, Spidertrax Spacers, 24" Led lightbar
    Did this today on my inners, hope it works or I'll have to go more low
    Dcsleeper408 likes this.
  19. Aug 30, 2016 at 9:53 PM
    #119
    raggedphoto
    raggedphoto Well-Known Member
    Oregon
    DCSB 07 Desert Sand Mica
    For long haul vs short crawl
    Just did this mod, thanks OP!
  20. Aug 31, 2016 at 8:20 AM
    #120
    colenaymark
    colenaymark Well-Known Member
    Cole
    08 Tacoma
    Hey, interesting mod...have you done much off roading with this? I would be interested to see if you over stretch the boot and invert the rubber fins. I don't know if they would go back to the normal position on their own after inverting? looks like something good to check...thanks for posting!
