2003 4Runner Limited 4wd V8 FJ tcased overlanding rockcrawling do-it-all build
Discussion in '4Runners' started by xtremewlr, Feb 8, 2020.
  1. Jan 11, 2021 at 12:20 PM
    #341
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    OK, that makes sense! I thought you were whipping this up on the fly lol.
  2. Jan 11, 2021 at 12:22 PM
    #342
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited
    4th gen T4R with a few mods
    Lol, no, not for this one. Fortunately, there are already really good designs out there for the front. The back, there are good designs but nothing that covers what I want, which is why I'm following your footsteps and building that one from scratch.
  3. Jan 11, 2021 at 12:23 PM
    #343
    Kwikvette
    Kwikvette Chief Executive Officer at Kwik Fab
    Stock
    Needs rear bumper :burp:
  4. Jan 11, 2021 at 12:25 PM
    #344
    xtremewlr
    Todd
    Tucson, AZ
    It kinda has one right now.
  5. Jan 16, 2021 at 8:22 AM
    #345
    xtremewlr
    Todd
    Tucson, AZ
    Been sick with a stomach bug for the last week. Finally feeling better. but work has me on quarantine as a precaution until the 21st. So, that will give me some time to hopefully finish up the front bumper and do some other things.
    I ordered up CF18 Smart Tap LED flasher from Diode Dynamics (non-DRL only) to cure the fast blink since I have front LED turn signals now for the new bumper.
    https://www.diodedynamics.com/smarttap-led-flasher-for-2003-2009-toyota-4runner-non-dtrl.html
    Unfortunately, because my Limited did have DRL to start, which I manually turned off with Techstream, the flasher relay is different from a truck that didn't come with DRL from the factory. Mine has a 12 pin relay where the non-DRL version is an 8 pin relay.
    The fix is a small, $24 shipped, wiring harness from Toyota for the non-DRL 4Runners. Part # 82241-35010. This plugs into the 12 pin harness on one side and the 8 pin relay on the other. Pic of a pic from the interwebs.
    Difference in physical size of the relays and the pin counts.
    And for those that don't know, the relay is on the back of the cabin fuse box. So you have to pull things apart a bit to get to it.
    So now I'm just waiting for the new harness to come is so I can eliminate the rapid flash turn signals I have now.
    Also got some new LED bulbs for the HVAC controls. I think I like the white display over the orange that regular bulbs produce in the LCD panel. Trying out the softer, light blue color in the controls for a while to see how I like it. It's not hard on the eyes like most blues are and softer than the white that I had in there before, which is still in the center control because I mis-counted in my head and didn't order enough bulbs.
    These also came in yesterday.
    Sorely needed since mine are the originals with over 298k miles on them and they have torn UBJ boots. Replacing them today and will have more pics up later on.
    y=mx+b likes this.
  6. Jan 16, 2021 at 8:52 AM
    #346
    Phessor
    Phessor Well-Known Member
    Bob
    Colorado Springs
    1998 TRD XTra Cab
    Stuff
    Get better
    xtremewlr[OP] likes this.
  7. Jan 16, 2021 at 12:07 PM
    #347
    xtremewlr
    Todd
    Tucson, AZ
    Doing better already, thanks!
  8. Jan 16, 2021 at 12:31 PM
    #348
    xtremewlr
    Todd
    Tucson, AZ
    SPC UCAs installed. They were sorely needed too. The UBJ boots were both torn and had been since I got the truck. All the UCA bushings were also shot.
    Only thing remaining for now is getting the alignment done. I'll replace the LCAs at a later point.
    Install was very straight forward and took less than 45 minutes per side. The majority of the pictures are from the driver side but both sides are virtually identical.
    Yuck. Both sides were like this.
    UCA bushings on both arms were totally done.
    Comparison of the stock and SPC arms.
    Yes, I had the ball joint on the SPC arm backwards. It was not installed like that.
    I highly recommend this front end service kit from OTC. The ball joint separator made short work of popping the UBJs free.
    https://www.amazon.com/gp/product/B0002SRH7O/
    Pivot bolt on both sides was able to be snaked out without having to bend sheet metal or do anything crazy. Super easy. Swapped UCAs and started bolting everything back together.
    Torque specs:
    Pivot bolt for UCA - 85 ftlbs
    UBJ castle nut - 45 ftlbs and tighten as needed to line up cotter pin holes
    SPC UBJ adjuster nut - 150 ftlbs
    jubei, Phessor and y=mx+b like this.
  9. Jan 16, 2021 at 1:00 PM
    #349
    xtremewlr
    Todd
    Tucson, AZ
    Alignment schedule for Monday at 10am :thumbsup:
  10. Jan 18, 2021 at 8:14 PM
    #350
    xtremewlr
    Todd
    Tucson, AZ
    Alignment done this morning. Good enough! Rear axle is crabbed a little but the truck tracks straight so I'm not going to worry about it for now.
    Pulled the bumper off to finish welding all the inside seams and start on the finish grinding/cleanup. Threw it on my scale before that to see how much weight I've added. 127 lbs. Not too bad I think.
    Impromptu welding and grinding bench. Need to build a real one after this.
    Got all the welding done today and started the clean up grinding. Finish that up tomorrow and them give it a good bath to prep for paint.
    jubei and y=mx+b like this.
  11. Jan 19, 2021 at 4:33 PM
    #351
    xtremewlr
    Todd
    Tucson, AZ
    Did all the finish grinding today and got the bumper primed and painted. Letting it dry over night and will reinstall tomorrow morning.
  12. Jan 19, 2021 at 5:05 PM
    #352
    Phessor
    Bob
    Colorado Springs
    1998 TRD XTra Cab
    Stuff
    Very nice
    xtremewlr[QUOTED][OP] likes this.
  13. Jan 20, 2021 at 9:16 AM
    #353
    xtremewlr
    Todd
    Tucson, AZ
    Bumper installed this morning. Thinking about possibly installing these cheap Chinese LED light I have at some point. Have to cut about a 3" hole for them. till undecided. I don't really wheel at night. Harness for the flasher relay is supposed to be delivered Monday so I can fix the fast flash.
    y=mx+b, Phessor and Kwikvette like this.
  14. Jan 20, 2021 at 9:19 AM
    #354
    Kwikvette
    Stock
    Why not a bracket style that sits below the hoop?
    This way it's adjustable.
    Otherwise that setup looks badass :fistbump:
  15. Jan 20, 2021 at 9:21 AM
    #355
    xtremewlr
    Todd
    Tucson, AZ
    Because I have these already and can make them adjustable-ish with spacers. Also would have to weld tabs to the hoop which I kinda don't want to, at least not right now. And then buy more lights.
  16. Jan 20, 2021 at 9:22 AM
    #356
    Kwikvette
    Stock
    Ah ok.
    Before you finish your rear, will you incorporate some sort of chase light?
    I'll be adding one to the Sherpa rack I ordered.
  17. Jan 20, 2021 at 9:26 AM
    #357
    xtremewlr
    Todd
    Tucson, AZ
    Dunno, haven't gotten that far yet :rofl:
  18. Jan 20, 2021 at 9:30 AM
    #358
    Kwikvette
    Stock
    A few times at Hollister Hills and other trails, there was a ton of dirt kicked up and I always told myself "fuck I hope they can see me back there"
    And then when we went to Moab, I really wish I had a chase light back there so I plan on getting one installed at the rear of my roof rack.
  19. Jan 20, 2021 at 9:32 AM
    #359
    xtremewlr
    Todd
    Tucson, AZ
    Like a red fog light?
  20. Jan 20, 2021 at 9:35 AM
    #360
    Kwikvette
    Stock
    An amber spot light (not flood) aimed straight forward so the light aims above the vehicle behind you.
    But being amber, it'll cut through dirt/snow/etc better than something more reflective like white light.
    Also being a spot light, you don't blind the person behind you.
