My Dash sounds like Darth Vader when I turn the AC on.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fourfourone, Jul 7, 2022.
  1. Jul 7, 2022 at 5:49 AM
    fourfourone
    fourfourone [OP] Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Hi guys,
    Over the last few weeks my 15 tacoma has started to have this darth vader/whooshing sound happen on and off when the AC is on and its hot outside. Noise seems to be comming from somewhere inside the dash. The hotter it is the more often it does it. On a real hot day it will happen every 10-20 seconds. It sounds like darth vader taking a breath if that makes sense. Lasts 1-3 seconds. No other odd noise and the AC is still as cold as ice. I've seen a bunch of posts about 3rd gen guys having this issue but not much on the 2nd gen.
    I've read the refrigerant could just be a hair low. Should I try adding a bit with one of those DIY cans? Anyone else have this issue?
  2. Jul 7, 2022 at 6:55 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Mine does it every once in a while along with the slight smell of refrigerant. Possible leak in the system. I did top off the AC with leak sealer since it was a little low and havent heard the noise. When I worked AC jobs for BMW, every car that came in with low refrigerant made that same noise.
  3. Jul 7, 2022 at 7:19 AM
    fourfourone
    I don't have any smells and the AC is still ice cold. Its been hot up here lately so the AC has been ran a lot and ive heard the hissing sounds for weeks. I feel like if it was leaking the AC wouldn't be ice cold anymore.
  4. Jul 7, 2022 at 7:46 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't reccomend adding anything to it without checking pressures on both sides and please don't add anything with stop leak in it, it will only cause more grief down the road.
  5. Aug 27, 2024 at 11:45 AM
    Perrymenla
    Perrymenla New Member
    Have you solved this issue?
  6. Aug 27, 2024 at 11:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    His post was 2 years ago and his profile says that truck was sold.
    He's still active though, so maybe he'll pop in and report if it was remedied. @fourfourone
  7. Aug 28, 2024 at 5:37 AM
    fourfourone
    Sold the truck last year. The noise was for sure from being low on refrigerant. Ended up finding a pinhole leak in one of the lower AC lines. For a few months I would top off the system with the can refrigerant you can buy at any auto store. The noise would go away and then slowly come back as the system got low.
