My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Oct 20, 2012 at 4:37 AM
    #281
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    I've got a tractor supply and lowes lol. I just used the tube I bought its not as thin as I thought. it would take alot to tear it. And its tucked under there
  2. Dec 9, 2012 at 8:25 AM
    #282
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is a very easy mod and very cheap, too! Keeping muddy water out of the differential is essential for long life.
    A reminder: This mod does to the rear differential what Toyota already does for the front. The question is why does the factory only do it on the front when you will get both axles and differentials underwater in a water crossing of 18" deep? Having the same model breather used on the front added to the rear, and placed up high above a water crossing level will prevent a vacuum that would otherwise suck muddy water into the differential past axle seals.
    The vacuum is created when a hot diff. is dipped into cool water. The factory rear breather is actually not a 'breather', but an exhaust valve to allow hot gasses to escape, but does not let any air back into the diff. to balance the pressure. Nature hates a vacuum!
  3. Dec 11, 2012 at 4:55 AM
    #283
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Subscribed. Useful mod.
  4. Dec 24, 2012 at 5:02 PM
    #284
    Databox
    Databox Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    This is why I love this forum...
    I bought my truck about 3 months ago. I took it out trail riding and crossed several muddy streams up to the bumpers.
    I am going to do this mod, but ...do you think I should change the diff fluid? How would I know if it was contaminated?
  5. Dec 24, 2012 at 5:13 PM
    #285
    David K
    The gear oil will look milky. Don't hesitate to change it. I put 75-140 Mobil 1 in it thanks to Speeed Freeek in Vista.
  6. Dec 24, 2012 at 5:15 PM
    #286
    David K
    Always remove the top fill bolt before you drain the oil from the bottom bolt.
  7. Jan 20, 2013 at 1:48 PM
    #287
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
  8. Jan 21, 2013 at 9:02 AM
    #288
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Gabe 911 - Whats the switch for?
  9. Jan 21, 2013 at 1:24 PM
    #289
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Guess the stock breather on my rear diff is only 1 way valve so I followed the OP's advice and switched it out for a 2 way with longer hose. Its suppose to help preserve the seals
  10. Jan 21, 2013 at 2:18 PM
    #290
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    pretty sure he's asking about the switch on the left side of the cubby... :popcorn:
  11. Jan 21, 2013 at 2:32 PM
    #291
    Gabe911
    FLORIDA
    10 PreRunner MGM
    LOL... sorry :)...The switch is for my bed lights I put in the smaller pocket cubby holes closer to the cab. pics should be in my sig
  12. Jan 21, 2013 at 2:32 PM
    #292
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
  13. Jan 23, 2013 at 8:46 AM
    #293
    David K
    Well, it prevents a vacuum from developing inside the differential so muddy water doesn't get sucked in when you cross a stream deeper than 18". This is the setup that Toyota does on the front differential, but failed to on the rear. It is the perhaps the easiest mod in the world and maybe the most important one any off roading Tacoma should have!
  14. Jan 23, 2013 at 10:14 AM
    #294
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It wouldn't hurt for them all to be that way...even the 5 luggers. People drive thru water deeper than 18" in the streets when it floods, lol.....or try to.
  15. Jan 23, 2013 at 7:06 PM
    #295
    David K
    Agreed! Other truck companies have extended breathers on the rear diff... why not Toyota? Thanks for extending the front differential up high, at least... half is better than none?!
  16. Jan 23, 2013 at 10:23 PM
    #296
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Is the rear breather even necessary? I've dunked the rear a few times recently and just changed the fluids and they looked fine.....could just regularly changing it be fine if I got into some dirty shit?
    Im just lazy and haven't found the need for the breather yet??
  17. Jan 24, 2013 at 9:07 AM
    #297
    David K
    What the Tacoma has on the rear differential (from the factory) is an exhaust valve that opens to relieve high pressure, although we all call it a 'breather'.
    By changing the exhaust valve to a true breather (the same kind Toyota puts on our front differential) you reduce the chance of mud contaminating the gears. The muddy water gets in past the axle seals because a vacuum is created when you quickly go from being hot to cold when you drive into a stream.
    It happened to my 6 month old Tacoma the first time I drove into a muddy creek... and had it's gear oil inspected after we got back from Baja. It was milky (water contaminated)... so changed the oil, right then.
    Next, I performed the mod, as shown in my photos on the first page of this thread, using the Toyota parts shown (breather and union) with the tube to place the breather up high in one of the bed compartments.
    Now, anytime I quickly cool the differential by driving into water, it can breath to break the vacuum and not suck in any mud or water. It also allows venting if over pressurized gas from the gear oil (just as the stock one did).
    That was almost 3 years ago, and haven't had an issue since!
    IF the factory does this kind of breather on the front differential, doesn't it make sense to do it on the rear??? YES!
  18. Jan 24, 2013 at 7:10 PM
    #298
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Makes sense....thanks!
  19. Jan 28, 2013 at 5:29 PM
    #299
    David K
    De nada!
  20. Jan 31, 2013 at 1:50 PM
    #300
    BostonBilly
    Easton
    I ordered the parts this afternoon. I will get them after work, I just have to pick up the fuel line. Has anyone used the extra fuel line for the oil filter drain
