My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Feb 2, 2013 at 10:11 AM
    #301
    derrenwd
    derrenwd Member
    ontario canada
    2005 trd offroad 6 speed
    k&n intake, banks cat back, 3 inch block lift with rear aal, MagnaFlow "Direct fit headers and cats" URD short throw shifter kit
    is the breather the same place on the trd off roads 2005 ?
  2. Feb 2, 2013 at 11:48 AM
    #302
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    Yes
  3. Feb 2, 2013 at 12:00 PM
    #303
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  4. Feb 2, 2013 at 12:14 PM
    #304
    derrenwd
    derrenwd Member
    ontario canada
  5. Feb 2, 2013 at 12:18 PM
    #305
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Wish you posted before I bought from Toyota. I looked local for the Brass 1/8" BSPT (British Standard Pipe Thread) no one had them
  6. Feb 4, 2013 at 10:03 AM
    #306
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    Okay - I've read both of the major threads on this mod and will be doing this soon, but here's my confusion:
    Some people use union p/n 90404-51026 (1/4" barb) and this seems to thread down all the way to the nut.
    Some people use union p/n 90404-51319 (3/8" barb) and this seems to thread in but has quite a few threads still showing.
    Both of the above p/n's are metal and have 1/8" NPT threads and everyone's using teflon tape for installation.
    The poster above me has used a brass fitting with 1/8" BSPT threads with no problems. If the threads are BPST threads, then people using the 1/8" NPT fitting may run into problems down the road.
    In reading all of the postings with regards to this mod, the majority of people have no problems, but some have had the fittings not thread in correctly, not been able to tighten the fitting or they have been loose and wobbly, and in one case, not been able to remove the loose fitting after installing it.
    Everyone seems to have an opinion, due to what worked for them, but does anyone know - definitively - what the thread should be on this fitting and which part should be used??
  7. Feb 4, 2013 at 3:05 PM
    #307
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Buy both, take yours out and compare the threads to the new one's. Return the other one. :notsure:
    I got the one listed in the first post and it worked
  8. Feb 4, 2013 at 3:07 PM
    #308
    BostonBilly
    Easton
    Sounds like good advise. I also bought what was listed in the first post and came home from work today with plans to do it but my daughters car took priority
  9. Feb 4, 2013 at 5:57 PM
    #309
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The 'union' part I used had the same threads as the factory valve/breather I took off the differential.
  10. Feb 4, 2013 at 6:59 PM
    #310
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    I believe the threads on toyotas use BSPT not NPT
    this sources confirm my thoughts some what:
    -http://www.tacomaworld.com/forum/1st-gen-tacomas/15223-diy-differential-breather-extension-3.html
    -http://www.youtube.com/watch?v=hXqzJJtKW7A
    -http://www.fjcruiserforums.com/forums/engine-performance/111727-oil-pressure-kit-connection.html
    -http://www.4crawler.com/4x4/CheapTricks/WaterProofing.shtml
    BadBrains likes this.
  11. Feb 9, 2013 at 9:07 AM
    #311
    Hylandr18
    Hylandr18 New Member
    AL
    New York
    Tacoma Sport
    Fog light bypass,TPMS bypass,LED cap lights
    My son burned up his rear differential in his 2005 because this vent became clogged.He traded it in for a 2013 so, I'm glad I joined this forum and came across this post.Thank You very much as this will probably save me $ in the future Very helpful!
  12. Feb 12, 2013 at 12:21 PM
    #312
    David K
    Yes, much harder to clog it up if it is up inside the storage compartment and not down in the mud!
  13. Mar 1, 2013 at 12:08 PM
    #313
    akaryanreynolds
    akaryanreynolds STRIKER TRD
    Los Angeles
    2012 DCLB MGM TRD Sport 4x4
    Debadged, Tint, Euro Antenna, OEM Roofracks, OEM skid plate, SMD LED interior lighting, AFE ProDry Drop-in, FX-R 6000K headlights w XB halos, VHT taillights, Fog light mod, Flyzeye V2W, T-Rex T1 Eyelids by Toyota Man, King 2.5 resis Front and Back, Devil Horns by Andres, Redline Hood Struts, PIAA 2500K H11 Fog Bulbs, Escort 9500ix, Ultra Gauge, Cobra 75 WXST, Firestik II w/ Quick Disconnect & Spring
    Payment sent for Bass union
  14. Mar 5, 2013 at 1:27 PM
    #314
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
  15. Mar 5, 2013 at 11:35 PM
    #315
    David K
    On the opening post, I took a photo of the parts bag, so nobody would get the wrong number...
    On the first page of this thread is a photo of all the parts I bought, including a package of hose clamps... ones that will fit 1/2" to 1" diameter hoses... here's a close up of the end, in the compartment:
  16. Mar 12, 2013 at 9:27 AM
    #316
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Just completed this today! Thanks for the write up!
  17. Apr 2, 2013 at 5:26 PM
    #317
    David K
    You get an A !
  18. Jun 2, 2013 at 10:34 AM
    #318
    Pearcem87
    Pearcem87 Well-Known Member
    2013 TRD Off Road
    Did anyone ever get confirmation on whether or not the e-locker breather needs to be moved as well? It might have been in the 17 pages, but I easily could have missed it. Just waiting on the parts to do this mod next weekend.
  19. Jun 9, 2013 at 6:53 PM
    #319
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Did this mod just now. For those wondering like I did, the stock breather threading is the same length as the new union you are replacing it with. It can be tightened all the way down to the differential housing. I was wondering why I saw about 1/4 of the threads on the earlier pics, thinking that it was longer and intruding into the gear area. It's not. +1 Rep for OP!
  20. Jun 10, 2013 at 4:34 PM
    #320
    David K
    Did I do something right?!! LOL
    Thank you! You will also note that I wrapped teflon tape on the threads so it would seal without over-tightening and risk of snapping it off!:cool:
