My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. May 24, 2014 at 11:10 AM
    #341
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    GOOD JOB! New color tube looks great!
  2. May 24, 2014 at 10:02 PM
    #342
    UTdez23
    UTdez23 Half Baked Dez Cruiser
    Jesse
    SLC, UT
    09 4x4 SR5 DCLB
    Bilstein 5100's front & rear, Eibach 620 lb Coils, Dakar Leaf Packs, Rear Diff Breather Mod, All Pro Sliders, RCI IFS Skid
    Thanks David! Yup, as advertised Lowes no longer carries the yellow high pressure hose, just the bright red/orange.. Thanks again for all the notes & pictures. Super helpful! It's a very useful & easy mod, now I can run through stream & river crossings with confidence! (While still using common sense :D )
  3. May 25, 2014 at 5:32 PM
    #343
    David K
    I know someone with a Toyota Land Cruiser that got his rear diff fluid water contaminated from just one time crossing a deep muddy creek, the same one that got me, in Baja, when my truck was new.
    DON'T DELAY, DO THE REAR DIFF BREATHER MOD TODAY!
  4. May 25, 2014 at 6:19 PM
    #344
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    We had flash flooding here the other day and I had a few involuntary water crossings (on roads) up to my rockers. I had no worries with this mod, completed last summer.
  5. May 28, 2014 at 6:03 PM
    #345
    David K
    :thumbsup:
  6. May 28, 2014 at 6:39 PM
    #346
    Grakyn
    Grakyn Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    I need to get this done asap.
  7. Jun 12, 2014 at 4:56 PM
    #347
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Some of you may be interested in this little devil. It has a "cool" factor to it: http://www.arb.com.au/products/arb-air-lockers-accessories/differential-breather-kits.php
    This kit is intended to replace your factory breathers and contains enough fittings and tubing to connect at least two drivetrain assemblies. More tubing and push-in fittings can be purchased separately to connect up to four assemblies to the central manifold (Part Number 170113).
    FEATURES
    • The axle breather manifold is machined from billet aluminum and anodized, making it lightweight and resistant to the elements.
    • The manifold has 4 axle breather ports allowing for between 1 and 4 breather lines to be connected. It is very compact allowing it to be installed in virtually any location.
    • The kit comes with self tapping screws, but the manifold mounting holes are large enough to allow mounting using an M6 (1/4 inch) bolt or stud, which is the common size in most vehicle engine bays.
    • The air filter is the ARB compressor air filter, which is a splash resistant air filter with a washable high flow sintered bronze filter cartridge.
    • 8mm Polyethylene tubing is flexible, oil resistant, water resistant and heat resistant.
    • 8mm tubing has been selected over the standard 6mm tubing to improve the air flow and reduced the chance of oil blockages in long breather lines.
    • The 8mm push-in fittings make the installation simple and fast.
    KIT CONTENTS:
    • Anodized Aluminum Manifold with 5 ports and 2 mounting holes
    • 4 x 1/8"BSP ports for connecting up to 4 breather lines
    • 1 x 1/4" NPT ports for the air filter
    • Air filter assembly
    • 4 x 8mm-1/8"BSP push-in fittings
    • 3 x 1/8"BSP plugs for plugging unused ports
    • 8m x 8mm polyethylene tubing
    • 2 x self-tapping screws
  8. Jun 19, 2014 at 5:06 PM
    #348
    scrappletaco
    scrappletaco Damn Deer and Idoit Drivers
    Josh
    Williamsport PA
    2011 reg cab 4x4, Debadged and dirty
    Debadged, Removed Charcoal filter
    Doing mine tommorow. I sucked a bunch of water in mine also. Changing the fluid tonite with some supertech synthetic from walmart to clean out the diff then doing a full 4x4 system change
  9. Jun 21, 2014 at 9:17 AM
    #349
    David K
    Good idea, better late than never (and have your rear end cease on you)!
    It will impress me to no end to see the next gen 4WD Tacoma have a true two-way breather on the rear differential as they already do on the front! I don't get that they put the correct one up front, up high, but leave the rear vulnerable to water contamination???
  10. Jun 21, 2014 at 11:09 AM
    #350
    scrappletaco
    Josh
    Williamsport PA
    I got a little behind on maintance after I got out of the airforce. By the time summer is over my truck will be ready for lift and some bumpers
  11. Jun 21, 2014 at 11:10 PM
    #351
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    This will be the next mod on my list! Can't believe these trucks didn't come with a breather from the factory!
  12. Jun 22, 2014 at 9:12 AM
    #352
    skygear
    skygear                    
    That's basically what I was thinking of. I just used a bunch of Watts fittings to accomplish the same thing. Manifold makes it cleaner, and the ARB logo is interesting. Price. I could do something with that money
    If you price out the components I used though, price got up there quick.
  13. Jun 22, 2014 at 11:18 AM
    #353
    skygear
    skygear                    
    Found this too.
    [​IMG][​IMG]
  14. Jun 23, 2014 at 7:22 AM
    #354
    scrappletaco
    Josh
    Williamsport PA
    That fluid in my rear end was nasty as hell. Now on to the breather mod today
  15. Jun 23, 2014 at 9:11 AM
    #355
    David K
    :yes: It will look milky when water has contaminated the gear oil. Good thing you got to it before a breakdown!
    I run Mobil 1, 75/140 in the rear and 75/90 in the front and transfer case, at the recommendation of Speed Freek (Jason).
  16. Jun 23, 2014 at 1:13 PM
    #356
    skygear
    skygear                    
    Why the different weights?
  17. Jun 23, 2014 at 2:01 PM
    #357
    coastemac
    coastemac Well-Known Member
    Mac
    NC
    2014 Tacoma TRD 4DR
    Bone Stock.
    Sub'd for future mod. Thanks for the info and the GREAT post.
  18. Jun 24, 2014 at 8:32 AM
    #358
    gravedgr
    gravedgr dirty Ford driver
    Doug
    Alpharetta, GA
    2014 Tacoma 4x4 DCSB TRD Off Road (Blue) - gone
    Method Racing Mesh wheels (17x8.5), Cooper ST Maxx tires (285/70/17), Toytec Ultimate lift (3"), Wet Okole seat covers, WT mats, Gemtex mirror, CF stubby antenna, scoop hood, painted grill surround, SOS bumper, SOS bed rack, Tepui Autana RTT, Engo 10k winch, bed lights, under hood lights, diff breather, 12v bed socket, 31M battery + battery monitor
    I was working on mine this weekend and found the new breather plug seems to be a bit smaller in diameter than the union plug. So the 3/8" ID tube fits okay on the union (not real tight), but is fairly loose on the breather. Is that to be expected and I should just tighten it down with the hose clamp? Or should I find another tube that fits tighter or has a smaller (1/4") ID?
  19. Jun 28, 2014 at 10:21 AM
    #359
    David K
    I don't remember there being any noticeable difference in the barb/tube connection between the two. In either case, they get a hose clamp... and this is not under any king of pressure... the true breather is not spring loaded like the one way valve Toyota puts on the rear differential. The tube in this mod is just a vent tube. A fancier breather could be the tiny air filter unit (K&N or ?) instead of the one made for the front differential that we are using here for the rear.
  20. Aug 16, 2014 at 7:10 AM
    #360
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
    I just ordered the parts from the dealer, they will be here Tuesday!
