My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Jan 31, 2015 at 8:30 PM
    #421
    laufer
    laufer New Member
    Chicago, IL, USA
    2004 4Runner Limited 4WD V8 (UZN215L)
    https://www.toyota-4runner.org/garage/9434
    Thanks a lot, CowboyTaco, DoorDing, and David K, for your helpful responses!
    I did say underbody instead of truck bed because this is indeed a 4Runner. :) The breather is tied to highest point of the underbody directly above the rear diff.
    I am concerned about dirt, grime and salt because this is not as protected an area as the engine bay where the front diff breathers are. Besides, this is not even above tire height, which I believe roughly equals wading depth (about 70 cm).
    Therefore, I am planning to follow the instructions in the posts cited above and relocate this breather to the tail light cubby. That seems to be a great place for it.
    Thanks again!
  2. Feb 1, 2015 at 12:02 PM
    #422
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Sounds like a good plan laufer!
  3. Feb 11, 2015 at 7:12 PM
    #423
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  4. Feb 23, 2015 at 10:02 AM
    #424
    Paul M
    Paul M Active Member
    Paul
    Virginia
    14 F150 3.5 Lariat, 2018 RAV4 Limited, 14 Tacoma SR5 DCLB SR5 V6 4x4
    The Tacoma is Straight stock at the moment
  5. Feb 26, 2015 at 7:29 PM
    #425
    David K
    OK, been getting a few messages and replies here from folks needing details that were in the first post... so please read my first post, re-posted here so you don't need to go all the way back to page 1. :)
  6. Feb 26, 2015 at 8:19 PM
    #426
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Maybe replacing that yellow tube with pink or something. Easier tutorial that way lol
    Had to get my truck align 3 times this month. Every tech asked me what that orange tube for. Easy mod and some day save big time.
  7. Mar 27, 2015 at 8:42 AM
    #427
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
  8. Mar 28, 2015 at 4:37 PM
    #428
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Finally got the motivation to do this, and ordered parts from this site. Love the $3 shipping cost. Thanks for the link.
    And thanks, David, for re-posting on this page. I plan to route to the tail light, though.
  9. Mar 28, 2015 at 6:20 PM
    #429
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Is the factory breather a one way breather and only lets fumes out? If so, why do we need to do this?
  10. Mar 28, 2015 at 8:57 PM
    #430
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Factory vent has a check valve to only allow venting out. If a hot diff gets submerged in say a cold stream, there can be negative vacuum, and the factory vent will not allow air back in. Water could get sucked into the diff through the axle seals. It's happened to some.
    From a 4Runner forum:
    The rear axle, instead, has a little breather cap (withOUT the hose) on top of the axle. The silver cap acts as a one-way valve. When the axle housing gets hot and pressure builds up, the cap pops open, releasing the gas and then closes down to prevent water from getting in. HOWEVER, in theory, this cap can malfunction, especially when you have mud/dirt sticking to it. This can happen if you off-road often or cross streams often. And if it malfunctions, then water/mud can get into the differential housing. That would be bad.
  11. Mar 28, 2015 at 10:41 PM
    #431
    David K
    It is fully explained on page 1 when I made this thread...
    If, after reading my explanation there, you need other details, I am happy to try and help.
  12. Mar 29, 2015 at 6:52 AM
    #432
    cstallings
    Arkansas
    Thanks. Makes sense now.
  13. Mar 29, 2015 at 10:34 AM
    #433
    David K
    Now? On the first page, in 2010:
    "The new breather fits perfectly inside the 3/8" I.D. tube. Unlike the original breather, the new one does NOT have a check valve (a one way valve that lets gear fumes out, but nothing in)... That was reported already, so I was not surprised. I guess my diff. was contaminated by muddy water getting in through the axle seals...?
    Having a two-way breather would act as a vacuum breaker and allow clean air to return to the differential during a negative pressure occurance (like dipping a hot differential pumpkin into a cold stream)!"
  14. Mar 29, 2015 at 2:11 PM
    #434
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    You know well that many never visit post 1, page 1, or any of page 1, for that matter.
    I, on the other hand, could use the part of my life back spent reading through every page of some long-winded threads (not this one - I wanted to see every post)...
    I was just responding to cstallings' query yesterday since he apparently didn't look too closely at page 1.
  15. Mar 29, 2015 at 9:21 PM
    #435
    cstallings
    Arkansas
    I read that post, but didn't correlate the negative vacuum sucking water through the axel seals. I thought you were saying it seaped in or you had a bad axel seal.
  16. Mar 30, 2015 at 9:47 AM
    #436
    David K
    No problem, I was just wondering how it was missed... that is the reason for the mod. My truck was new (6 months old) when it was in 2-3 ft. deep muddy water. When serviced after the trip, the diff oil was milky (water contamination). I did the mod, and 5 years later still no contamination.
    If the front differential has a real (2 way) breather, then why wouldn't the back one get it from the factory too??? Well, it has it now!!!
  17. Mar 30, 2015 at 10:26 AM
    #437
    cstallings
    Arkansas
    I was concentrating on the breather to much so when you said axel seals it didn't strike me as a place of suction, but I understand how it can be. I was thinking to hard...ha ha. Similar thing happened to my truck that happened to yours when it was brand new, so I wanted to make sure I understood it and not just followed a thread. Thanks for the post
  18. Apr 21, 2015 at 2:41 PM
    #438
    aaol1
    aaol1 Well-Known Member
    sam
    victoria BC
    10' TRD sport DCLB
    Rear diff breather Plasti dip emblems and rims Garmin glo GPS receiver + ram mount with tablet Toytec BOSS lift with rear AAL Custom steel bolt-on sliders with kickout Custom aluminum bed rack Wild Coast Tents Sundog RTT mounted to rack 2 x Treds PRO Lime green mounted to rack Shovel + Hi-lift mounted to rack Cheap bush bar 2 x CREE LED light pods with hood mounts 265/75R16 Hercules Terra Trac ATII
    hey just wanted to say I just did this mod today, first mod to my truck, and it went super smooth and easy because of this tutorial! thanks a bunch, much appreciated :)
    David K[OP] likes this.
  19. Apr 21, 2015 at 4:55 PM
    #439
    David K
    Glad it helped ... wheel freely now!
  20. Apr 21, 2015 at 6:38 PM
    #440
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Just thought I would add the fact that I changed the rear diff fluid recently at 40k mi and it looked good just worn out. I did the mod when my truck had about 6k mi on it. I went through many water crossings since I've owned the truck. Kudos David
