My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Apr 21, 2015 at 9:37 PM
    #441
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    HB Murphy (your neighbor?) was with me when my 6 month old Tacoma differentials went under water. The front has a high breather, and its oil stayed prestine. The rear had the stock "thing" (it's not a breather) and my fluid was milky from water contamination. The mod was performed, using the same breather that the front diff. gets, and my rear diff. oil has remained uncontaminated ever since (5 years now).
    Here is the video from inside HB Murphy's Tacoma (lead truck of 6)... and I am behind him. Turn on sound to hear his lady scream... too funny!
    https://www.youtube.com/watch?v=UBvjeiwTN48
    This is on the road to Mission Santa Maria in Baja California, less than a mile from the mission, in May, 2010. Here is a web page I made of that group trip to Baja's most impossible road, including 'The Widowmaker' grade!: http://vivabaja.com/msm2010/
    BUZZCUT likes this.
  2. May 15, 2015 at 9:16 AM
    #442
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    I think everyone should do this. Even if you dont offroad.
    During the past month it has been flooded a few times in my neighborhood due to heavy rain. Flooded to my garage door and my truck is parked on the street. Man it sure save me from changing the fluid.
    David K[OP] likes this.
  3. Jun 11, 2015 at 6:02 PM
    #443
    David K
    You are very welcome... I try to help!
  4. Aug 29, 2015 at 10:48 AM
    #444
    Johnny2525
    Johnny2525 Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    Ok, so this mod has been done...and done....and done. Something I've noticed was the different fittings everyone is using at the end. (where the breather would go) Looks like some people are using what looks like a cone shaped fuel filter?? Is that what it is? What is the difference between using a filter and the actual breather?
  5. Aug 30, 2015 at 7:38 AM
    #445
    David K
    The 'breather' Toyota uses on the front diff, that we are using for the back diff, is simply a cap over the open end with a gap that allows air/ gasses to pass but would keep debris out. A true breather filter (like from K&N) would be great if you do a lot of dusty driving.
    The main thing is to ditch the stupid one way vent on the rear diff, add the union, tube, and a two-way breather up higher than any water crossing level. Be it in the fuel door, behind the tail light lens, or like me and others, in the cubby in the side of the bed. Working great for me there for 5 years now.
  6. Aug 30, 2015 at 7:47 AM
    #446
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have been to every Lowe's, Home Cheapo and can't find the tubing required. Anyone know of any other spots to get it???
  7. Aug 30, 2015 at 8:10 AM
    #447
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Sweet thanks bro, all I got is AutoZone I think around me.
  8. Aug 30, 2015 at 8:12 AM
    #448
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Cool thanks again
  9. Aug 30, 2015 at 8:28 AM
    #449
    David K
    Right... it was just cool to get it in yellow... really shows up well to illustrate the installation!
  10. Aug 30, 2015 at 2:48 PM
    #450
    Johnny2525
    California
    Just finished this mod. Probably the easiest mod so far. Didn't even get thru one vodka/cran...I just bought the parts everyone posts from toyotapart.com. I don't know the diff between those parts and a 2-way...I'm sure it's fine how i did it. I'm curious tho....I only have 2WD so I don't have a front diff to deal with but do I have to do this to the tranny?
  11. Aug 30, 2015 at 3:31 PM
    #451
    David K
    No, only the rear diff. 2-way means a breather that allows air flow in or out, a true breather. What is in the rear from the factory is a 1-way vent and it doesn't break any vacuum. That causes contamination to occur.
  12. Aug 30, 2015 at 5:08 PM
    #452
    Johnny2525
    California
    I terminated mine behind the tail light already. Can i put a 2 way there? Can you post a pic of what I can use there? I swear I'll stop bothering you about this! Haha! sorry!!
  13. Aug 30, 2015 at 7:01 PM
    #453
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If you bought the parts listed in the first post, it is a 2 way breather
  14. Aug 30, 2015 at 7:29 PM
    #454
    David K
    The breather recommended in my post is no bigger than the thing that is on the differential from the factory, that is a spring loaded vent. Using that at the end of a tube is NO benefit to doing any tube extension as the same vacuum is created if you drive into a pond or stream with a hot diff! Sorry if I mis-understand you... and I don't ever feel bothered answering a question unless you never read my first post on the mod (and never used the parts I photographed and listed in the first post)... Here is the parts photo:
  15. Aug 31, 2015 at 7:31 AM
    #455
    Johnny2525
    California
    I'm confused. These ARE the parts I used. Are they NOT what you recommend?
  16. Aug 31, 2015 at 8:00 AM
    #456
    David K
    Yes, on page 1 of this thread is the instructions and those photos.
    It clearly says this is the 2 way breather (a true breather).
    This is what you posted yesterday: "I terminated mine behind the tail light already. Can i put a 2 way there? Can you post a pic of what I can use there? I swear I'll stop bothering you about this! Haha! sorry!!"
    Sounds to me like you used the factory rear diff thing (they call a breather) when you ask if you can put a 2 way breather there? That is why I repeated the photos and info that is on page 1 of this thread.
    I hope everything is clear and you have a great day!
  17. Aug 31, 2015 at 9:36 AM
    #457
    Johnny2525
    California
    Looks like I should be golden...Thanks for all your help!
  18. Aug 31, 2015 at 5:13 PM
    #458
    David K
    My pleasure...
  19. Sep 7, 2015 at 10:32 AM
    #459
    DrFunker
    DrFunker Well-Known Member
    because $
  20. Sep 8, 2015 at 8:24 AM
    #460
    David K
    One of life's great mysteries!
    Good springs in back is another weak link... yes it rides nice, but it is a truck and shouldn't need mods to carry the rated load.
    Can't be too hard on Toyota, it is still a great vehicle even with a few issues!
