My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Sep 15, 2015 at 10:55 AM
    #461
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Stupid question do you lose any fluid when you pull the old diff?
  2. Sep 15, 2015 at 11:41 AM
    #462
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Yea that is. I forgot to put breather on the end of it. My bad. Also has anyone had issues with it in the storage box? I know OP said in the beginning it can eventually clog in the fuel door area. Anything I should keep out of the storage box after the relocation goes there?
  3. Sep 15, 2015 at 2:22 PM
    #463
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I said that?
    I put mine in the cubby in the bed, drivers side... see photos. Put it where ever you want, but it should be high enough to not ever be underwater and minimal dust, if possible. Look where the SAME breather is for the front differential (near the battery).
  4. Sep 16, 2015 at 4:34 AM
    #464
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Had mine in fuel door for 4 yrs on 1 truck and 2 yrs on the other and never had any issue with it clogging. Clogging with what? More dust and gak accumulates in my storage boxes than the fuel door ever has seen.
  5. Sep 16, 2015 at 8:51 AM
    #465
    David K
    I am the OP, and I never said anything (in the beginning or beyond) about clogging in the fuel door area or that is why I didn't put my breather there. I just searched the thread, and about 6 pages back, I found this:
    "AHeppner, post: 9202960, member: 41303"
    Sorry, I should be more specific.
    What happened was I did this mod several years ago and the differential breather, the one used for this mod (not the stock) fused together.
    The metal "cap" on the breather (plastic), pushed into each other and corrosion on the cap cause an air-tight lock.
    I do not blame this on ice, but the cap and the materials it's made out of.
    The location also had a part in it. Mine was located in the fuel cap area, so I believe I inadvertently pushed the metal cap into the plastic of the body in the breather during fill-ups contributing to the air-block.
    Now on my new Tacoma (sold the 07 for a 13), I put it in the bed, as I have a cap/sleeping platform which is more out of the elements and hopefully will last longer (not that 6 years in the gas cap was bad).
    Since I blew a seal I just check on my breather it every time I fill the tank.
    Hope this was helpful.
  6. Sep 16, 2015 at 9:33 AM
    #466
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Sounds like bad placement in the fuel door area then. Mine is nowhere that interferes with fillups. ( I know you is OP cuz it says it right by your name on every post )
  7. Sep 16, 2015 at 10:04 AM
    #467
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    I would like to retract my previous statement. I did not mean to try and say you said something you didn't OP. So I would like to apologize. My brain must have f'ed sht up like normal, lol. So my bad guys.
  8. Sep 16, 2015 at 11:02 AM
    #468
    David K
    No worries my friend... it is just the Internet, facts can be flexible here sometimes! LOL
    4x4Banger[QUOTED] likes this.
  9. Sep 17, 2015 at 5:28 AM
    #469
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Great write-up OP. Thanks!
  10. Sep 17, 2015 at 8:08 AM
    #470
    David K
    The pleasure is all mine, have a great day!
    4x4Banger likes this.
  11. Sep 26, 2015 at 10:42 AM
    #471
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    the OEM plug didnt have Teflon tape on it, it should be alright replacing the new union w/out the tape...right? (I just did it, and didnt use teflon tape so Im wondering if i should take the union out and redo it)
  12. Sep 26, 2015 at 11:08 AM
    #472
    Skootter14
    Jeremy
    BTW, if you decide to run the hose to the passenger side compartment bin (next to the 400/100v plug), 6' of hose is perfect. I keep my hitch in the longer bin on the driver side and didnt want that knocking the breather plug so I ran it to the opposite side. I ended up only cutting 4-5" of hose in the end, which left me with enough play in the line also for the flex in the suspension. Thanks for the write up!
    rubiconjp likes this.
  13. Sep 26, 2015 at 12:45 PM
    #473
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    tape will give a better seal, with less possibility of water getting in.
  14. Sep 26, 2015 at 1:58 PM
    #474
    Skootter14
    Jeremy
    I ended up taking it off and taping it.
    patbegley likes this.
  15. Sep 26, 2015 at 8:56 PM
    #475
    David K
    Nice job!
    I am an irrigation guy, and always put teflon tape on the sprinkler valve fitting threads to prevent leaking. For sprinkler systems and plumbing pipes, it's so easy to do it right, why do it over?
  16. Sep 27, 2015 at 6:05 AM
    #476
    Skootter14
    Jeremy
    youre definitely right
    David K[QUOTED][OP] likes this.
  17. Oct 4, 2015 at 8:55 AM
    #477
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Sweet mod thanks! Gotta love tw|
  18. Oct 17, 2015 at 2:41 PM
    #478
    CASHORT
    CASHORT Well-Known Member
    Cory
    Whidbey Island WA
    2006 Black Sand Pearl TRD Off Road 98k miles
    Custom shovel, axe, fishing pole holders, Lumber Rack
    Sub'd doing this this weekend
    Anyone get the plug and union from anywhere but toyota? No dealership close by.
  19. Oct 17, 2015 at 3:42 PM
    #479
    ImpulseRed008
    Susan
    SC
    mail order? :notsure: got mine from Toyota
    DrFunker and CASHORT[QUOTED] like this.
  20. Oct 19, 2015 at 6:26 AM
    #480
    CASHORT
    Cory
    Whidbey Island WA
    Ended up ordering from toyota. Looks like I'm going for a drive. Guess I'll just have to test drive a 2016 tacoma and 4runner... darn! :cool:
