My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Sep 12, 2010 at 8:24 AM
    #41
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  2. Sep 12, 2010 at 8:33 AM
    #42
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    This is on my list for next weekend.
  3. Sep 22, 2010 at 9:05 AM
    #43
    David K
    Last Saturday while in Baja, the Rugged Trail (Fail) T/A with only 16,000 miles on it got a rock puncture on a graded road... Had it patched in El Rosario, and took a couple photos of my breather tube when the tire was removed...
    Here is also the stock 3 leaf spring on my 2010 (Baja, Mexico built Tacoma) that doesn't bottom out, like the 3 leaf spring on my 2005 Tocoma did...
  4. Sep 22, 2010 at 3:30 PM
    #44
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    David, I may be on the wrong track here, but, I took special care to make sure that there were no low spots in my breather hose. The chances however remote, are that, if you do get fluid above the low spot in the hose, you no longer have an open breather. I guess it would be kind of like those bellows breathers, the pressure could just push the fluid up :D.
    I don't know, maybe much to do about nothing.:confused:
  5. Sep 22, 2010 at 4:09 PM
    #45
    David K
    Maybe a good point... I think if a vacuum was strong enough to suck in water past the axle seal, it would be easier to first suck back any fluid sitting in the tube. I don't think there are in low dips in the run, anyway.
    I would enjoy hearing from the experts...
  6. Sep 23, 2010 at 11:05 AM
    #46
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the experts have concluded there needs to be more sucking :eek:
    no homo
    tbird95 likes this.
  7. Oct 29, 2010 at 11:05 AM
    #47
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Last year I some research on whether or not the electric diff lock really had a breather in the Tacoma. My research was inconclusive. I couldn't find much in the FSM. I was aware that the FJ had one though. Here are some documents from the 2006 FSM I really would like a definitive answer on whether or not there is one.
  8. Oct 29, 2010 at 11:19 AM
    #48
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    me too
  9. Oct 30, 2010 at 9:10 AM
    #49
    David K
    Crom, there is a smaller rubber tube that comes off the e-locker and disappears into the frame... This is much higher than the rear differential stock breather's location... What happens to that tube once in the frame cross member is unknown... Because of A-TRAC, if the e-locker fails it isn't going to stop me... but if the rear diff. fails, well... that is a problem and not cheap, so the breather mod for it was important.
    The yellow tube is sold at Lowe's... go buy 6 feet of it now, so you will have it... in case they stop selling it!
  10. Nov 22, 2010 at 8:22 PM
    #50
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    Just did mine. Only I used a clear tube, thought it would be nice to be able to see what's going on inside.
    Thanks to OP's easy to follow install steps!
    Dj Suisav likes this.
  11. Nov 22, 2010 at 8:30 PM
    #51
    ruslanus
    Rus
    Wasilla, AK
    I noticed when I dropped my spare for this mod, there was some wear on the tire side wall from rubbing on the frame. Did anyone else notice that when you took your spare down?
  12. Nov 22, 2010 at 8:31 PM
    #52
    jandrews
    '09 FourDubDee TRD OR
    They have stopped selling it. At least at my local Lowes. After lifting I decided I wanted more slack in the tubing so went and picked up another section of the stuff from Lowes. The stock on the shelf was the same color as red clay.
    But, I now know for sure I have enough slack for axle travel.
    And man...now that I have the TSB springs with an AAL, those stock leafs look awful small...glad they don't bottom out, but I'm still not crazy about the look.
    One word of caution for people: If you are not using high pressure hose or fuel line for this mod, I would be worried about tearing/punctures from trail debris, or kinking during enthusiastic suspension flex. The high pressure hosing really is the way to go...it's almost impossible to kink and is very cut/tear resistant. Fuel line is essentially the same thing in a smaller diameter. Back when I originally did this in August '09, I determined it was by far the best stuff for the job:
  13. Nov 22, 2010 at 11:12 PM
    #53
    David K
    Yes Russ, I saw the rub wear on the spare... another reason for turning it over besides access to the air fill valve stem.
    I agree with jandrews in that the clear tube may not be tough enough for flying rocks, sticks, etc. Keep an eye on it and let us know how it does... Glad you found my idea of where to put the breather made sense, as well!
  14. Nov 23, 2010 at 1:20 PM
    #54
    ruslanus
    Rus
    Wasilla, AK
    It was the easiest to route to :) I am planning on replacing the clear tube with a more durable one. I just used the clear tube to see if there wouldn't be too much condensation that could cause problems.
  15. Nov 23, 2010 at 5:11 PM
    #55
    David K
    GOOD WORK!
    Let us know what you see...
  16. Nov 23, 2010 at 5:54 PM
    #56
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    does the oil get sucked up in the tube? if i need to change me diff oil will it spill out the hose?
  17. Nov 23, 2010 at 5:58 PM
    #57
    David K
    Only in the vacuum of outer space...
    Umm, only if you do the job with your truck upside down!
    jjgandarillas, SR-71A and Stryker420 like this.
  18. Dec 2, 2010 at 12:30 AM
    #58
    ruslanus
    Rus
    Wasilla, AK
    so, after a week or so of running the clear tube I have not seen any condensation in the tube and I went ahead and bought 6' of 5/16 fuel line from Auto Zone and replaced the clear tube with a more durable one. It actually looks like it's factory installed now. Love this mod for the peace of mind it gives me. Not that I cross high water every day, but if I had to, I know I'm covered.
    David K[OP] likes this.
  19. Dec 4, 2010 at 8:12 AM
    #59
    David K
    Good job!
  20. Dec 4, 2010 at 8:40 AM
    #60
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
