My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Oct 7, 2011 at 12:48 PM
    #161
    ricktacoma
    ricktacoma Member
    rick
    New Hampshire Lakes Region
    11' Tacoma TRD Sport
    Floor Liners
    The problem with check valves is they get gcrapped up and don't seal or else close and don't open. Its just a spring loaded valve. I had one goobered up in my NISMO Frontier (salt and snow crud over a few seasons)and it caused the axel seal to leak out onto rear brake on driver side when I was towing a load (heated up and expanded in there). Nissan wanted to replace seals and brakes (900$) but my mechanic said we should try to clean out valve and clean up the brake/wheel. In his experience the seals on the Frontiers can reseal once the pressure is relieved in pumpkin. It worked in this case ($100) and stopped leaking at the seal, but brake pad was ruined (soaked diff oil in, this did not clean up). I am putting the extended axel vent you guys worked out on my new Tacoma Sport this weekend (traded the 05 NISMO). Cheers!
  2. Oct 7, 2011 at 5:31 PM
    #162
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    why didnt you just pop that cap off that plug and save a few bucks i did mine with a npair of pliers then put the hose and clamp on
  3. Oct 9, 2011 at 2:39 PM
    #163
    ricktacoma
    ricktacoma Member
    rick
    Floor Liners
    I thought the Nissan axel seal was shot since it had leaked considerable oil into the wheel, didn't realize the breather design was so problematic. . Took it to a local mechanic who told me the seal may be fine if you clean up or replace the breather valve, no garauntees but in this case the seal held once the breather was working again.
    I put the vent on my Tacoma this morning and had some pressure in the pumpkin when I loosened the stock breather (pumpkin was room temp from sitting overnight in garage). Surprised me. I wouldn't expect that it should be running with any pressure. Brand new 2011 truck, 1200 miles. Wat's up with that??
  4. Oct 10, 2011 at 8:15 AM
    #164
    gottahot1
    gottahot1 Well-Known Member
    T.D.
    Arizona
    08 BLUE double cab 4x4 short bed Sport TRD
    'Caribe' fog light mod - Power port always on mod - Defrost A/C override mod - Illuminated 4x4 switch - Read diff breather relocation
    I believe it was negative pressure (at least it was with mine). The valve is designed to let pressure out but when the diff cools down, no air can come in past the axle vent due to the spring/gasket design. That's the whole reason for the mod though, so it's a good thing that you got it done!
  5. Oct 10, 2011 at 8:18 AM
    #165
    gottahot1
    T.D.
    Arizona
    I looked at the same thing but decided not to do it because the leftover piece is small and the diameter is pretty big - you'd need a monster hose and don't have a lot of room to attach it to the nub that's leftover after you disassemble the valve.
    The replacement part has a barb. After attaching a hose clamp there's very little chance (if any) that the hose will come off.
  6. Oct 10, 2011 at 8:40 AM
    #166
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Because using the right part is the right thing to do... and it was like $5, so contaminating the differential if the hose falls off the modified breather is not saving anything. The right part (union) has a barbed insert end to help secure the tube.
  7. Oct 14, 2011 at 10:59 AM
    #167
    ckoerner
    ckoerner Member
    chris
    Elko, NV
    3" front 2" rear level lift, debadged, SATOSHI grille, rear diff breather mod, 4x4 illuminated switch, pop and lock, coming soon-ICON stage 4 suspension, TRD CAI, TRD exhaust
    Nice! Doin mine next week
  8. Oct 27, 2011 at 4:17 PM
    #168
    gottahot1
    T.D.
    Arizona
    I did this mod with a slight twist.
    First, let me say that my Taco is my daily driver. I have taken it off-roading a little bit, but nothing major - I have a trail rig for that. I did this mod because I don't like the idea of the sealed pumpkin and its inability to inhale while it cools. Plus, the little breather could get gunked up and stop working altogether.
    The first part where I varied from the OP is that I used an inexpensive fuel filter instead of the barbed OEM type breather. I got the fuel filter from O'Reilly Auto parts for $2.47. There were 2 options; this one was more reasonably sized - it almost looks like it was made for lawn equipment.
    The other variation is in the mounting location. I ran the hose up into the fender well (like in another thread on the same subject) but I used an insulated band clamp and a bolt/wingnut to secure the hose. This way I don't have to see the breather or be concerned about losing any space in the bed cubby and all that's visible is a bolt head behind the gas fill door.
    2WD and el_turks like this.
  9. Oct 27, 2011 at 4:20 PM
    #169
    David K
    Very cool... is there much restriction when you blow through the filter in either direction?
  10. Oct 27, 2011 at 6:53 PM
    #170
    gottahot1
    T.D.
    Arizona
    I can't blow through it without detecting some restriction but it's to be expected since it's a filter. In no way do I think it's over restrictive or will prevent the diff from getting adequate ventilation. It's way better than the OEM version for breathability...:D
    ADD: Plus, trying to blow through a straw, even without a filter, is going to give you the sense that there's some restriction when in fact there isn't.
  11. Oct 28, 2011 at 10:40 AM
    #171
    David K
    10-4... given that the stock breather is not a breather at all... only a spring loaded outlet vent... it should be better.
    With this mod., we are installing the SAME breather Toyota puts on the FRONT differential... which already is elevated at the end of a hose. IT JUST MAKES SENSE that the back differential on all 4WDs should get the SAME treatment, right???
  12. Oct 29, 2011 at 12:10 AM
    #172
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Equal rights for front and back diffs!
  13. Oct 29, 2011 at 9:10 AM
    #173
    David K
    YAH!!!:D
  14. Nov 10, 2011 at 8:13 AM
    #174
    David K
    Bump... Have you all done this mod yet? It's the rainy season here in the west!
  15. Nov 11, 2011 at 11:12 AM
    #175
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    The front isn't so hot either. I just got a front seal replaced (under warranty, as was the heater blower fan), and they told me the front diff was full of water. While this summer was a wet one, I've only once in 25k miles driven in water to roughly the middle of the wheels, and this only briefly.
    Where else could the water have come from?
  16. Nov 11, 2011 at 4:11 PM
    #176
    David K
    I would say that was a BS story... anyone who finds a diff. full of water would make a pretty big deal out of it, and a responsible service writer would find the cause ASAP... not let you drive away. They are basically saying you drove the truck into a lake up to the hood (so the elevated front breather would allow water in...??? The truck is new, so waht did they do?
  17. Nov 11, 2011 at 8:08 PM
    #177
    RogerRZ
    They changed the leaky seal under warranty, and charged me $30 for a diff lube change, which was called for at 35K miles.
  18. Nov 15, 2011 at 2:11 AM
    #178
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    If the seal was due to warranty the fluid change which is required with the seal change should have been covered.
  19. Nov 15, 2011 at 3:36 AM
    #179
    RogerRZ
    Any "official" reference to this? Before I go back and chew them out, I'd like to make sure...
  20. Nov 15, 2011 at 4:44 AM
    #180
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Well, similar but not equal...........they certainly replaced my rear brake shoes free when they ignored my first notification that the rear axle seals appeared to be starting to leak. Shortly thereafter when the fluid began being slung onto the rims and they could no longer deny the seals were leaking, they had to replace a non-warranty item due to the warrantied parts crapping on them. Should be same thing for you, the warrantied item failure caused contamination to the fluid (non-warrantied wear item). Just like my story so try to make them reimbusre you or change the fluid in the rear axle for free so both are fresh.
