my DIY satoshi grille
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cball917, Feb 23, 2012.
  1. Feb 23, 2012 at 8:59 AM
    cball917
    cball917 [OP] Well-Known Member
    Johnathon
    NE GA MTNS
    2010 Tacoma Woods and Water Edition
    black out package. custom decals, fogs
    started on it last night. i bought another grille to run in my truck so i would not be rushed to get this done. will update pics as progess continues
  2. Feb 23, 2012 at 9:38 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Cut out the small sides Op otherwise its only 1/2 done.....[​IMG]
  3. Feb 23, 2012 at 9:40 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    i just did mine too. not a good job, but good enough for me. i was too much in a hurry. i'll post pics asap
  4. Feb 23, 2012 at 12:55 PM
    cball917
    Johnathon
    NE GA MTNS
    That's why I bought a grille to put in while in building. Did not want to feel rushed
  5. Feb 23, 2012 at 12:57 PM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Germany
    2006 DCSB TRD Sport 4x4
    De badged tailgate,LED dome light,removed mud flaps,tail gate anti-theft mod,Maglite seat mount,rear diff breather,blacked out Tacoma emblems, blacked out Toyota emblem,foglight anytime,plastidiped stock rims,BHLM, behind grill light bar w/2 Hella 500FF lights, shortened 18" stock antenna, weathertec floor liners, Hi-lift, 3'' Toytec Ultimate with AAL, AVS Rainguards, Wet Okole seat covers, lowprofile tool box, pro comp 7089 w/33'' KM2s, flowmaster 40 series muffler, hidden CB mod w/firestick antenna.
    looks good man what kind of mesh did you use and where did you get it?
  6. Feb 23, 2012 at 2:48 PM
    KillSwitch
    KillSwitch Active Member
    Cali
    07 PreRunner
    3" lift
    i want to know the same thing.......reply back asap
  7. Feb 23, 2012 at 9:03 PM
    cball917
    Johnathon
    NE GA MTNS
    just search on ebay for aluminum black mini mesh. the buy it now is 29.99 plus 5 for shipping. the lowest offer they would accept was 25 plus shipping. took abotu 3 days to get it. comes in a 12x48 sheet. enough to do grille and triangles
    here you go
    http://www.ebay.com/itm/BLACK-ALUMI...Parts_Accessories&vxp=mtr&hash=item53e326ac6d
  8. Mar 11, 2012 at 7:10 PM
    cball917
    Johnathon
    NE GA MTNS
    here are some updated pics. i sanded, glassed, bondo, then primed. installed back in an ran for a solid week to see if any changes in the operating temp because of the small holes in the mesh. i noted no temp change at all. going to finish it this week and will post pics when finished. it will be super white.
  9. Mar 11, 2012 at 7:12 PM
    cball917
    Johnathon
    NE GA MTNS
    and a side note. the pic of it back on the truck..... i bought this small hole mesh so you could not "see" through it. i have not painted the radiator yet and you still can not see it when grille is installed. i am very pleased with it. the mesh was only 30 bucks
  10. Mar 11, 2012 at 8:29 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    How did you get the glass to bond to the ABS?
    I tried glassing mine and 3 days later it peeled off like a banana skin when I lightly flexed the grille.
    Started searching online, and everything I found indicated that glass resin will not properly bond with ABS.
    And I wondered why HomerTaco made his using plastic welding.
    I ended up laminating some ABS sheet to the back and attaching some cut pieces from the removed parts of the grille. One end is nice, the other end is still soft (after a week!).. I'm hoping it will firm up or I'll have to strip it back down and try again.
  11. Mar 11, 2012 at 8:32 PM
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
    :thumbsup: Looks good! :cheers:
  12. Mar 11, 2012 at 8:42 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Looks Good
    Doin' one of these is like startin' a new career.
    I also bought a 2nd grill, as it took me a couple months, a little at a time.
    CC
  13. Mar 12, 2012 at 10:51 AM
    cball917
    Johnathon
    NE GA MTNS
    anytime your bonding plastic to something you have to sand area for it to stick to
  14. Mar 12, 2012 at 6:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Did that.
    60 grit.
    It peeled off without an argument like a whore's skirt.
  15. Mar 13, 2012 at 6:40 PM
    cball917
    Johnathon
    NE GA MTNS
    it should have stuck i would think. i used 8o grit and lightly scuffed and then degreased and layed it to it
  16. Mar 13, 2012 at 6:42 PM
    cball917
    Johnathon
    NE GA MTNS
    still trying to decide if i want to put an emblem back on grille. it looks bad aZZ without one. so i am torn???
  17. Mar 13, 2012 at 7:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'm going to use a white one from an FJ
  18. Mar 13, 2012 at 7:30 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Awesome job OP. Satoshi's are quite an endeavor. All you guys who do it yourselves get props.
  19. Mar 13, 2012 at 9:41 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    X2 :cool:
  20. Mar 14, 2012 at 10:56 AM
    cball917
    Johnathon
    NE GA MTNS
    thanks for the comments. hopefully will get it on this week. watersanding now
