My do it thric3 build
Discussion in '2nd Gen. Builds (2005-2015)' started by Thyces, Sep 25, 2017.
  1. May 30, 2021 at 5:18 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Nice! I am planning on this too. My Dakar’s are getting old, and I figure when I get the 14 bolt axle in, the 63’s may hold up better.
    Thyces[QUOTED][OP] likes this.
  2. May 30, 2021 at 5:26 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Are you going Ford shock towers? That's the last thing I need to order.
  3. May 30, 2021 at 5:38 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’ll be going in board on the shocks since I have the stock tire carrier out of the way. Less chance on rubbing on shock bodies and I can fit 2.5’s if need be.
  4. May 30, 2021 at 5:48 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    oh yeah... Flatbed things. Much better set up to move them in I've heard. I was looking at gearing but think I want to eventually go 14 bolt as well so am holding off until then. How pricey is the rebuild for the axle doing it yourself?
  5. May 30, 2021 at 5:52 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Axles are anywhere from $500-1k.
    -400-500 for brakes with disc brake conversion bracket
    -gears $1000
    -lockers 1500
    -shave kit with cover is $500ish from Tmr
    -may be doing a truss on mine 300isj
    -misc brackets 100-200
    Rebuild of seals and what not $200-300
    not terrible but the expensive stuff is going be driveshaft modifications and getting the brakes/hubs machined for our bolt pattern.
  6. May 30, 2021 at 5:53 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks for the info. Didn't realize it is that involved
    tacoma16 likes this.
  7. May 30, 2021 at 6:00 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Again you can do it cheaper. For instance find one with 3.73’s which I think exists. Then convert it to our lug pattern on the drums. From there it would just be the driveshaft.
    check out van city’s build. He used a 14 bolt with his ifs before he SAs it.
  8. May 30, 2021 at 6:03 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Will do. Would like to be at 4.56 eventually but I do have a spare taco axle as well laying in the garage.... I gotta figure all this shit out someday
    tacoma16[QUOTED] likes this.
  9. May 30, 2021 at 8:50 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    What front hanger are you considering, I'm looking at the ruffstuff one and not frenching it
  10. May 30, 2021 at 8:55 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Hear that. Tons to do!
    I won’t be frenching in either i think. As for hangers I am going to take a look at tmr. Local for me. Just not sure if they have the variety that ruff stuff has.
