My dream has been...Delayed
Discussion in 'Audio & Video' started by ToyComa92, Feb 20, 2012.
  1. Feb 20, 2012 at 11:24 PM
    ToyComa92
    ToyComa92 [OP] Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    So i finally got enough cash together to get a 7" Touchscreen in the truck. 2006 tacoma. I planned on doing the 2011 model 4300avh which was on sale for 399.99 At Quality Auto sound. The guy said it would be about 80 bucks for parts and 55 for labor so about 535 out the door. Cool works for me... Until he realized i have the JBL system... He told me i either have to buy a 120 dollar adaptor or replace all four of my speakers... I dont want to pay 120 bucks for something that will become useless as i planned on doing speakers later on this year... Is this guy legit?! Are the JBL speakers really not compatible?! i planned on doing Boston acoustic speakers all around or Focal just not immediately...
  2. Feb 20, 2012 at 11:31 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    the problems isn't the speakers its the external amp thats not compatible. but yes that is true you will need an adapter I'm not sure if the JBL is high or low power input. I has the same issue in my and Audi with Bose. Got my head unit installed and had to turn it full blast just to get any sound out of it. Got the adapter and everything worked great.
  3. Feb 20, 2012 at 11:47 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    You can probably find the adapter cheaper online and do the install yourself. Installing a head unit is fairly simple, I'm completely incompetent when it comes to wiring and I've been able to do it before.
  4. Feb 22, 2012 at 8:00 PM
    ToyComa92
    Jon
    Conifer, Colorado
    So i will probably end up buying the 2012 model avh4400 and just installing it myself along with speakers. Just gotta save up a couple more bucks! Anybody know what size speakers and how many il need? I want to go with Boston acoustics
  5. Feb 22, 2012 at 9:49 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Bostons are sweet! check out *********.com they have all the info you'll need
  6. Feb 22, 2012 at 10:11 PM
    ToyComa92
    Jon
    Conifer, Colorado
    Just wondering, I want to do two 10" Subwoofers and i want to go with Rockford Fosgate. I cant decide between the 2 or 4 ohm voice coils... Whats the difference?
  7. Feb 22, 2012 at 10:35 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    just the impedance 2ohm is more efficient than 4 ohm if your going with fosgate do not buy P1 get the P3's
  8. Feb 23, 2012 at 6:39 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Probably want to decide on the amp that you'll want to power those first. The amp specs will tell you what RMS power rating they will drive into what load (ohms). You'll then wire the subs together (series or parallel) to present that specific load to the amp.
    As for 2 ohm being more efficient then 4 ohm, not sure where that's coming from unless your intent was that "most" amps will drive a higher RMS rating into a lower ohm load. If that's the case, that is very amp dependant, so choose your amp before you order the subs.
