MY DUAL XHD7714 Head Unit Install
Discussion in 'Audio & Video' started by armstrsm, Mar 27, 2011.
  1. Mar 27, 2011 at 10:53 AM
    armstrsm
    armstrsm [OP] Well-Known Member
    Sean
    Little Rock, AR
    07' Double Cab 4x4 SR5 TRd OffRoad
    AVS Vent Visors, AVS Bug Shield, Locks On Bed storage, Weathertech floor liners, Access roll up tonneau, Dual Head unit, illuminated 4x4 switch, Devil Horns
    I Have been wanting to an Ipod capability to my stock unit, but after lots of research. I decided to by a new head-unit, so I purchased the Dual XHD 7714 head-unit from Crutchfield.
    I went with the XHD because it had Ipod Capability, built in HD radio (awesome), and Built in Bluetooth (for Calls and music streaming). Along with the Dual receiver i purchased the Axess steering wheel control adapter. The Metra Dash kit came for free!! All together $250!!
    Also in the middle is the 4X4 illumination switch from rcbs204
  2. Mar 27, 2011 at 10:53 AM
    armstrsm
    Sean
    Little Rock, AR
    The Before
    And After
  3. Mar 27, 2011 at 11:02 AM
    armstrsm
    Sean
    Little Rock, AR
    Started of course with the AC control unit
    pulled out all the control knobs and gently pried it off.
    the four bolts in this pic attached the stock unit to the dash.
    she pretty much popped right out after that
    then unhooked all the wires
  4. Mar 27, 2011 at 11:03 AM
    armstrsm
    Sean
    Little Rock, AR
    cant forget the 4X4 switch
    used a flat blade to pry it off
  5. Mar 27, 2011 at 11:09 AM
    armstrsm
    Sean
    Little Rock, AR
    I soldered all the wiring and wrapped them in heat shrink tubing
    then added my 4x4 lighting unit into the switch
    then built up the new receiver and dash kit
  6. Mar 27, 2011 at 11:16 AM
    armstrsm
    Sean
    Little Rock, AR
    the plug in the middle with the purple red and yellow wiring is the stock steering wheel control unit. I had to clip off the plug and used those wires to connect to the Axxes control plug. (forgot to get a good picture of that) The toughest part was soldering these wires while they where in the Taco.
    The red and white wires are for the 4X4 switch. I tapped into the AC lighting wires.
  7. Mar 27, 2011 at 11:21 AM
    armstrsm
    Sean
    Little Rock, AR
    After the soldering was done. Everything popped right back in no problem!
    Everything works
  8. Mar 27, 2011 at 11:29 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I'm lost.....what's up with the 4x4 switch? I think I missed something. I like the radio
  9. Mar 27, 2011 at 11:41 AM
    armstrsm
    Sean
    Little Rock, AR
    while i had everything opened up i did rcbs204 4x4 Illuminated Switch! modification.:cool:
  10. Mar 27, 2011 at 11:51 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Good job. Looks nice, got any better pictures of it in the day time?
  11. Mar 27, 2011 at 11:54 AM
    paintdiddy
    shithead
    silver bullet
    Oooooohhhhhh I thought it had something to do with the radio
