My e-locker diff for your open diff
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by S.B., Mar 28, 2013.
  1. Mar 29, 2013 at 5:34 PM
    #41
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    if you want a real LSD youll need to swap I believe 07 and down???
    As all the current LSD's are computer controlled and not mechanical
    I could be incorrect on the year though
  2. Mar 29, 2013 at 5:43 PM
    #42
    S.B.
    S.B. [OP] Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    that is correct
  3. Mar 29, 2013 at 7:02 PM
    #43
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Am I correct in assuming you have your own LSD diff you want to put in the axle you're trading yours for?
    Either way, I totally called dibs first :D
  4. Mar 29, 2013 at 7:14 PM
    #44
    S.B.
    Sean
    San Diego
    15 Taco
    At first I thought that the Auburn diff that I bought would work in our open diffs, because I thought they were all 8" and only the stock LSD diffs were 8.4". But I did a bunch of research and it turns out I was wrong and that only the E-locker is the 8", and all the other diffs (at least in our 2nd gens) are 8.4".
    Sorry about the confusion man, that is my bad.
    I have recently updated the first post to say I'm looking into just trading for a stock LSD axle from the years 05-08.
    I also found out that the stock LSD is an Eaton LSD and it is rebuildable unlike my Auburn LSD that is not rebuildable and is trash once the clutch plates wear out.
    Again I am very sorry for all the confusion to you The Traveler and to all others that have messaged me with an open diff.
  5. Mar 29, 2013 at 7:39 PM
    #45
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    really clears up the confusion thats for sure, i at first was kinda in the same thought that maybe you had an LSD waiting to go in, either way GL with the sale
  6. Mar 29, 2013 at 7:44 PM
    #46
    The Traveler
    SoCal
    All good brotha!
    :thumbsup:
  7. Mar 29, 2013 at 8:10 PM
    #47
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    dibs? lol
  8. Mar 29, 2013 at 8:26 PM
    #48
    S.B.
    Sean
    San Diego
    15 Taco
    Idk how dibs would work in this situation, unless I have many reasons to hold it ;) JK.
  9. Mar 29, 2013 at 9:35 PM
    #49
    anthony250f
    Anthony
    San Diego, CA
    lol i couldnt swap full axles anyway since my axle has a bunch of stuff welded to it.
  10. Mar 29, 2013 at 9:53 PM
    #50
    S.B.
    Sean
    San Diego
    15 Taco
    I do have an LSD waiting to go into an axle, but found out it won't work for 2nd gen tacomas.
  11. Mar 30, 2013 at 1:26 PM
    #51
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    So, in a nutshell, S.B. has an Off Road locking differential (desired by nearly anyone who goes off road for extra traction) but wants a mechanical limited slip differential (only available in '05-'08 Sport TRDs) for slippery street traction... is that correct?
    I have been offline and got a PM linking this thread I just read this morning... sorry I wasn't quicker to reply.
    S.B., is that what you want the mechanical limited slip for? Why not just use the 4WD when the road is icy or slippery?
  12. Mar 30, 2013 at 2:01 PM
    #52
    S.B.
    Sean
    San Diego
    15 Taco
    I want a LSD so I actually have traction on the road, especially on right turns.
    You say use 4wd when slippery, but towing through shit weather (snow and icy roads) 4wd only does so much when you have 2 open diffs (towed this past winter, one of the scariest things I've done). For on road the LSD is a way better choice.
  13. Mar 30, 2013 at 2:50 PM
    #53
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Makes sense now. FWIW, you may be dollars ahead and have a better rear end if you buy a non Toyota LSD 8.4 open diff and install the diff of your choice.
    This catalog does not show fitment into anything newer than 2005 but they will fit according to shops that build high performance rear ends.
    http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_128302.pdf
    I have a non e-locker third waiting to have the new Truetrac installed and then the third will be swapped in. My truck is not e-locker equipped Prerunner 2wd.
    For grins have you emailed any of the shops that build the thirds and asked if the diff will fit if the e-locker input were capped and the wires stowed. Then it could be swapped back if needed later.
    Supposedly, even though the diffs are badged as 8 and 8.4, the gears are the same size. Don' hold me to this exactly, I did a lot of reading before buying my parts and it was very overlapped and confusing.
    My thought, keep your housing, get an e-locker third built with a Truetrac diff, cap the e-locker actuator input, stow the wires plug and play the entire third. Assuming this is mechanically possible. Keep the original third in a sealed five gallon pail with corrosion prevention fluid sprayed on the precision parts.
    PK
  14. Mar 30, 2013 at 3:51 PM
    #54
    S.B.
    Sean
    San Diego
    15 Taco
    No other locker or LSD will fit into the E-locker third. And the "8.4" third will not fit into the E-locker axle housing without some serious modification.
    Yes the 8" and 8.4" ring are the same physical size, but the thirds are different and the 8.4" has 12 ring bolt instad of 10 as in the E-locker.
  15. Mar 30, 2013 at 3:53 PM
    #55
    S.B.
    Sean
    San Diego
    15 Taco
    Also the stock LSD is an Eaton
  16. Mar 30, 2013 at 6:30 PM
    #56
    PMK
    Florida
    10 DCLB TRD Sport
    I was under the impression ir was made by someone else, a Japanese company. Possibly there are two manufacturers.
    PK
  17. Mar 30, 2013 at 6:35 PM
    #57
    TrdSurgie
    TrdSurgie revised
    Oahu
    Kazuma TRD LSD manufactured by Eaton
    I pulled a 3rd from a 2004 Tundra with one for my truck.
