My experience and results with Alcan, 6" Lift Leaf Springs
Discussion in 'Suspension' started by Max713, Apr 19, 2014.
  1. Feb 23, 2016 at 2:45 PM
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    Nice man! Good write up! This is exactly what ive been wanting to do as soon as I have some extra money. Glad this fixed the wrap problem. I cant wait to get rid of the Blocks!
  2. Feb 23, 2016 at 2:48 PM
    603fishhunter
    603fishhunter Well-Known Member
    Forrest
    New Hampshire
    2014 tacoma 4 cyl access cab
    6" rough country lift
    What are you running now?
  3. Feb 23, 2016 at 2:50 PM
    UssMoGn
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Procomp stage 2 6'' DB lift, Stock leafs 2 inch block with AAL. Honestly rides nice, doesn't sag yet, does lean a little more on driver side. Cant haul much(Id assume this is from the shitty stock tacoma leafs.)
  4. Feb 23, 2016 at 2:56 PM
    603fishhunter
    Forrest
    New Hampshire
    Yeah my 4" blocks are rough they gotta go
  5. Jul 22, 2016 at 3:56 PM
    TakeNoteS
    TakeNoteS Well-Known Member
    Luke
    Kalama Washington
    2022 Silver Taco SR5 LB 4X4
    Stage 1 Pro Comp here :frusty: Rides like garbage, I wanted to upgrade and I am starting with the rear. Do these Alcans just bolt right on and will keep my lift in the back the same height? would anyone recommend anything else to go along with a leaf pack?
  6. Jul 24, 2016 at 7:33 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I have the Alcan . I have the 8 leaf +200 lbs. and I am at stock higth. They ride great . If you do go with Alcan order them with the OEM bushings. The polyerathane ones squeak. I had to get some daystar polyerathane grease. I would definitely order Alcan again. Bill and his crew put out a great product and are very helpful. The trick is when you talk to Bill about what you want tell him exactly what you want. Hope this helps .
  7. Jan 14, 2017 at 3:04 PM
    ChiefKealoha06
    ChiefKealoha06 Active Member
    2009 Toyota Tacoma
    Did a 3" leveling kit
    Where did order those lift springs? @Max713 what year is your truck? Is this specific part that will fit my 09
  8. Jan 14, 2017 at 5:02 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    2005-2015 leaf packs will all fit. Same rear suspension as the Model T.
  9. Jan 14, 2017 at 5:16 PM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    truck looks great man! What kinds MPGs?
  10. Mar 19, 2017 at 8:32 PM
    Max713
    Max713 [OP] Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    I bought them directly from Alcan.
    I miss that truck on a regular basis... Truck got 17-18 or so going down the interstate at 60mph. Got 13 or so around town.
    Definitely wasn't a Prius.
    lpfe42 likes this.
  11. Oct 7, 2018 at 7:32 PM
    lvasquez93
    lvasquez93 Well-Known Member
    2017 Tacoma TRD Off Road
    did you order your leaf springs directly from alcan?
  12. Feb 14, 2022 at 5:32 PM
    dpf88101
    dpf88101 Well-Known Member
    Glueman - what did you finally go with deavers or Alcan ? I am looking to purchase a new set of leaf packs. I have the BDS 6” DB lift and need 800-1000lbs over stock
    do I ask for a 6” lift spring or ?
  13. Feb 14, 2022 at 10:09 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    I got some custom springs made for my truck. I think the best thing is to call one of those guys and tell them what you have, how much extra weight you have and what kind of off-roading you do and they can figure the rest out and make a set for you.
    dpf88101[QUOTED] likes this.
  14. Apr 19, 2022 at 8:39 PM
    Voltacoma
    Voltacoma New Member
    I ordered Alcan springs with a 4” lift. I have a fabtech 6” lift in the front and the rear has a 3” block and add a leaf. Will the 4” spring lift get me level or do I need to call back and increase the rear spring lift to 5 or 6?
  15. Apr 20, 2022 at 4:58 AM
    #35
    dpf88101
    Lew built/spec’d mine with 5” of lift for my bds 6” lift (bds has a 4” block). But I am carrying 920lbs constant in the rear, Lew built mine for 1k over weight. Lew was spot on with his calculations and weight.
    if it was a bit high I could always have adjusted my front coilovers to level it. A 1/2 inch wouldn’t have been much.
    I weighed my truck and sent pics and weigh ticket info to Lew, and he came up with the magic number
    dzilla315 and Glueman like this.
  16. Apr 24, 2022 at 7:14 PM
    #36
    dzilla315
    dzilla315 New Member
    Dan
    18 inferno
    35s 6inch DB BDS method wheels
    just sent a request for the same deal on BDS 6 DB. Happy with the outcome? I want to get rid of the block ASAP lol
  17. Apr 24, 2022 at 7:58 PM
    #37
    dpf88101
    Extremely happy! Truck has never handled better suspension wise, best decision I made was to have Alcan build custom leaf springs specific for my truck.
    dzilla315[QUOTED] likes this.
  18. Apr 24, 2022 at 8:01 PM
    #38
    dzilla315
    Dan
    18 inferno
    Awesome, appreciate it! I’ll be following suit with them for sure
