My experience towing with a 1st Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco-bender, Sep 5, 2017.
  1. Sep 5, 2017 at 4:08 PM
    Taco-bender
    Taco-bender [OP] Well-Known Member
    Tucson AZ
    2010 Tundra 4x4
    I just completed a 900 mile tow with my '00 Prerunner 3.4 and I have to say, I was not too impressed with it's towing capability. Even with a tow load of only 1,500lbs (roughly) the gas mileage sucks, sucks, sucks and the braking capability is marginal at best. I really thought this little Tacoma could do a bit better than it did.
    Now, maybe unrightfully so, I'm comparing the Taco to towing with my '02 Isuzu Trooper. The Trooper (3.5L 215hp v6) has hauled our little pop-up trailer (2,100lbs all loaded up) thousands upon thousands of miles with nary a whimper. 3rd gear through the mountains, as one would expect, and always, always, 17mpg when towing. And, it's a PIG! Heavy, wallows thru turns, etc. and I really don't enjoy driving it all that much.
    Anyhow, here's my trip report.
    We just listed my BIL's house for sale up in Sacramento and I needed to get his fishing boat out of the side yard. The boat, while in pretty decent shape, needs some fixing here and there to get top $$$ when we sell it. Soooo, with the long Labor Day weekend coming up I decided to drive solo up to Sac and haul it back to Tucson so I can get it ready to sell.
    I left Tucson @ 5am Friday morning and 14 hours later arrived in Sacramento. CA was having record high temps that day so I ran the a/c hard the entire way. Had the tires @ 44psi and didn't really have anything in the truck besides some tools, a floor jack, straps and a grease gun.
    I set the cruise at 75mph and the truck ran great. I averaged a bit over 20mpg for the 900 miles up. Was quite happy with that.
    Here's my mileage for the trip up with no load.
    Stayed with my brother and SIL Friday night and went to the BIL's house Saturday morning to get the boat ready for the trip back to Tucson. Jacked it up and checked the bearings which looked/felt good and gave them a few pumps of grease for good measure. The tires "looked" good but were about 10 years old. With the temps in the valley being 105+ degrees (AZ being 105+ also) I hauled the boat over to Discount Tire and had 2 new tires put on (decided to take my chances with the spare).
    The boat is a 16' Klamath center console fishing boat. According to specs I found online the bare hull weighs a bit under 600 lbs. The 40hp Yamaha comes in at roughly 225lbs and the EZ Loader trailer is probably right around 500lbs. With empty fuel tanks, 2 large deep cycle batteries and some miscellaneous junk the whole thing "might" be 1500lbs give or take.
    With the boat all cleaned up and ready to go I spent the afternoon knocking back a couple of cold ones with a couple of old friends. Plans were to take off Sunday morning after church and beat the Labor Day traffic on Monday.
    Here's the truck and boat at the Discount Tire parking lot.
    Left Sacramento about 10:45am Sunday morning and the entire trip back to Tucson, while uneventful, was less than awe inspiring.
    Running Hwy-99 south through the valley I ignored the CA speed limit of 55mph while towing and ran at 65mph. I was able to keep the OD engaged for the most part and got pretty decent mileage (about 17mpg). Had to get on the brakes pretty good a couple of times and, while not unsettling, they were far from confidence inspiring. I would try to keep a little more distance from the car in front of me as a result.
    Once I hit 58 east out of Bakersfield it was OD off and 65mph at 3,000rpm's the rest of the way to Tucson. The little Tacoma struggled going through the Tehachapi's and could barely make 55mph at times (Trooper on the same route could hold 65mph easy).
    Here's my fuel for the towing portion of the trip. The 13.60mpg is dragging the boat around Sacramento getting stuff done.
    In conclusion, I guess my expectations for the Taco may have been a bit high. I really thought pulling a 16' tin boat would have been a non-issue for the little truck but, maybe 1,500lbs IS a pretty good load for it. I certainly wouldn't want to tow anything near the 5k rating for any extended time, that's for sure.
    Oh, here's a pic of the Trooper with it's typical camping load.
    DLtaco02 and RangeDrive like this.
  2. Sep 5, 2017 at 4:17 PM
    Slickster
    Slickster greentaco
    2002 pre
    what app are you using for mileage?
  3. Sep 5, 2017 at 4:18 PM
    callmeammo
    callmeammo Well-Known Member
    Your camper looks much more aerodynamic than the boat set up. The open boat is like dragging a partial parachute behind you, I'd imagine.
    DLtaco02, standard and Chipskip like this.
  4. Sep 5, 2017 at 4:21 PM
    Thurman Merman
    Thurman Merman Well-Known Member
    Denver, CO
  5. Sep 5, 2017 at 4:21 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Amazing what Tundra brakes, a tranny cooler and a few other goodies can do for towing!
    Chipskip and Brice like this.
  6. Sep 5, 2017 at 4:46 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Tacos aren't known for their gas mileage, and that's not even towing anything...
    Your weight isn't the only factor. Aerodynamics play a big role too. If anything aerodynamics plays a BIGGER role at highway speeds than trailer weight, at least on flat ground. Driving hills are a different story, but that usually averages out when you come back down the hill.
    Years ago, I borrowed my in-law's tiny little Colman camper trailer for a trip up to WA and back to central Cali, about 1700 miles or so iirc. I averaged 18mpg for the whole trip. That was because I drove like a grandpa (55mph), and the trailer weighed like 1000 pounds soaking wet.
    I've got a bigger trailer now, <2500#, and make the same/similar trips annually, sometimes several a year. Recently did a 2400 mile trip to Durango and back. With the heavier trailer (still a pop-up) I got closer to 14mpg, maybe pushing 60mph.
    My new 4.0L 4Runner gets more like 17 towing the same trailer doing 70 the whole way, and nothing gets wet when it rains. :)
  7. Sep 5, 2017 at 5:05 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    FuelLog for Android.
    Already have a tranny cooler installed and I think it's a reasonable expectation that you shouldn't have to upgrade brakes towing 1,500lbs if the truck is rated for 5,000 lbs. Just saying.
    Taco Addiction likes this.
  8. Sep 5, 2017 at 7:18 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Yeh, Tacomas aren't known for towing well. But, boat towing is rough on any vehicle. They're just not designed to go down the interstate. I've towed a variety of trailers with my Tacomas. Most recently my 16ft Glastron skiboat. Probably a bit more weight than your boat, but my gas numbers are the same as yours. And in flat Florida. If I were to plan serious prolonged towing I'd step away from a Tacoma. Atleast noting less older than a 3rd gen.
  9. Sep 5, 2017 at 7:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My dad has an 08 Tundra and tows a trailer with 3 snowmobiles all winter and a 4000 lb wakeboard boat (boat alone) in the summer and has had no trouble with starting, stopping, or cruising. You might want to look for one of those if you are going to tow a lot.
  10. Sep 5, 2017 at 10:09 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    I don't really plan on towing anything on a regular basis and for what it is, a compact pickup, it's fine. I just thought it would do a little better than it did with a pretty lite trailer behind it.
    I've towed a lot crap with a lot of vehicles in my 40+ years of driving and the only other time I felt somewhat uncomfortable was towing my '66 Mustang on a dolly with my dad's '86 4.0 Cherokee. That thing did NOT want to stop.
    DLtaco02 and Dalandser[QUOTED] like this.
  11. Sep 6, 2017 at 1:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Well what can I say but I am quite happy as long as my mileage stays above 10mpg .
    I have noticed it pretty much is not the weight that effects fuel mileage it is how aerodynamic the load is and how fast you drive once you get much over 50mph fuel mileage drops fast .
    weight only plays into your stopping distance
    Dalandser likes this.
  12. Sep 6, 2017 at 1:29 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Not buying the boat being a rough load excuse, thats not too much weight. Ive towed with a 2nd gen tacoma quite a bit. I'll be hauling a uhaul trailer with a first gen for the first time in a few weeks. Ive also been curious what that'll be like.
  13. Sep 6, 2017 at 1:34 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    :notsure:
  14. Sep 6, 2017 at 1:10 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    You got it wrong. The driver (and engine) is in trailer, which is pulling a Prius for a long haul. They connected Prius backwards in hope of unwinding some miles on Prius's clock.
    Dalandser[QUOTED] likes this.
  15. Sep 6, 2017 at 1:13 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Must be really hard to steer with just one axle
    Balance must be interesting
  16. Sep 8, 2017 at 10:58 AM
    Glamisman
    Glamisman Well-Known Member
    towing speed is the most critcal component in MPG when towing... btw, and not picking on you, towing a trailer in CA, 55mph is the max. I am surprised the CHP didnt get you. I hear it all the time from AZ peeps at the desert, 65 mph towing a trailer in AZ but when they cross into CA it drope to 55 and they get tagged.
  17. Sep 8, 2017 at 11:06 AM
    The Driver
    Raph
    I towed 6,200 lbs, from Tulsa to Denver, with my Taco. Tires, tire pressures, brakes, suspension (leafs) and a tranny cooler, were the parts needed for a succesful tow. That was with 60 to 70 MPH winds, as we were traversing Kansas.
    It can be done, but a Taco needs to be modded to succesfully acheive that. I have no idea, why your truck was wimping out with just 1,500 lbs.
    StockTaco02 likes this.
  18. Sep 8, 2017 at 3:02 PM
    Taco-bender
    Tucson AZ
    2010 Tundra 4x4
    Yeah, me either. Only 116k on it. Well taken care of and runs like a champ. I really thought it would do better than it did but I'm sure it's just me and my high expectations. Is what it is and I'm not going to worry about it.
    If I get position again where I need to tow often (Camp trailer?) I'll sell it and get something else. Not a big deal.
  19. Sep 8, 2017 at 3:40 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    My situation is a little bit different but I routinely have 1,000 lbs in the bed full of gear and dirtbikes plus a good 350lbs of cabin occupants and additional gear. My truck with the 5 speed doesn't even notice the weight. Although I will admit the MPG will go down around the 17 mpg mark on the highway at 70 (I get an easy 20 normally).
  20. Sep 9, 2017 at 10:28 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    People on this forum laughed when I mentioned to a new owner his truck would notice a 500 lb load. I can tell a difference when I have a single passenger in my truck. These things aren't made for towing, carrying a few ladders and tool chests is about where they reasonably max out IMO.
    TacomaJunkie8691 likes this.
