My experience with a 3" lift and 285's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fluffy nuggets, Jan 16, 2018.
  1. Jan 17, 2018 at 5:05 PM
    72rtchallenger
    72rtchallenger Member
    terry
    ky
    2013 TRD Sport Tacoma
    TRD Bronze Wheels OEM 16"
    What wheels do you run, mine are the baja toyota wheel but unsure of offset
  2. Jan 17, 2018 at 5:08 PM
    Stefan_Ray
    Stefan_Ray Tacoma TRD Life
    Stefan
    Concord,North Carolina
    2021 TRD Pro
    Cooper STT Pro’s
    I have the Method NV’s in 16x8 with 0 offset.
  3. Jan 19, 2018 at 4:33 PM
    tibj3
    tibj3 New Member
    15 sr5 pre
    I'm running 285's on stock body no rubbing at all. Wanna 3"lift so I can put 33's under it. Is rubbing what I have to look forward too?
  4. Jan 19, 2018 at 4:36 PM
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    What 285’s are you running? 99.9 percent of the 285’s out there ARE 33” tires. The Nitto Trail Grapplers come in a 285/70R16. They are 31.89 tall, but that’s the only 285 I know of that isn’t 33” tall.
  5. Jan 19, 2018 at 4:38 PM
    fluffy nuggets
    fluffy nuggets [OP] Well-Known Member
    2013 DCSB
    Every truck is different and you may be lucky with no rub. That might change if you do any sort of off-roading.
  6. Jan 19, 2018 at 4:43 PM
    tibj3
    tibj3 New Member
    15 sr5 pre
    I misspoke. I am running 265 70r16 coopers so much clearance don't see how 285's would come close to rubbing.
  7. Jan 19, 2018 at 4:54 PM
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    You’d be surprised how much difference 2” makes. Are you running stock wheels? What year truck?
    fluffy nuggets[OP] likes this.
  8. Jan 19, 2018 at 4:56 PM
    tibj3
    tibj3 New Member
    15 sr5 pre
    2015. 16" stock at the moment.
  9. Jan 19, 2018 at 5:09 PM
    Stefan_Ray
    Stefan
    2021 TRD Pro
    Cooper STT Pro’s
    You are going to need to get 0 offset wheels or new UCA’s with stock wheels. OEM wheels are +25 offset which means they are pushed in toward the truck. When you put on 285’s and turn left or right, you are going to hit the UCA’s. Once you put a lift on you will need to do some trimming unless you find a 0 offset wheel. I run 0 offset wheels on mine and have a 2.5 lift and BARELY get by without trimming.
  10. Jan 26, 2018 at 8:41 PM
    Yonnietacoma
    Yonnietacoma Member
    Jonathan
    2013 Tacoma 4wd srs
    Me so far
    I'm looking to install 285/75/r16's BFG Ko2's on my SRS 2013 4x4 4 door ...BUT I'm going with 3" in the front, 2" in lvl kit in the back and bought 4x1.25" wheel spacers (I admit I went the cheaper route and just got the hockey puck spacers in front for now). My question is has any one noticed any different problems between the spacers/5100's?
    (I don't meen to hijack your thread but I thought it might add some light as the difference of rubbing between hockey pucks and actual shocks and struts :/ )
    So this rubbing may or may not take place. Granted this is going to be a street princess as I have no wish to take it off roading ever, Just mainly for looks. What issues am I getting myself into?
