My Experience with Raptor Lining My Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoffengineering, Sep 14, 2020.
  1. Sep 14, 2020 at 4:43 PM
    hoffengineering
    hoffengineering [OP] Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I recently Raptor Lined the bed on my 2015 DCLB and thought it was worth sharing my experience.
    When I bought my Tacoma earlier this year, the bed wasn't in terrible shape, but it had definitely been heavily used by the PO and was showing some wear and tear. I'm not the kind of person who worries about every little ding and scratch--but I am the kind of person who likes to "start fresh" and to "erase" the wear and tear from the PO, so that I can impart my own wear and tear! :)
    So after a lot of research, reading, and inspiration from seeing the results others had achieved with Raptor Liner (@jeffmort, in particular), I decided to pull the trigger.
    I also replaced the bed rail and tailgate caps with KB Voodoo parts at the same time.
    Which kit?
    The approximate inside surface area of the DCLB bed is ~60 ft^2. I calculated ~54 ft^2 per the overall dimensions of the bed, +5 ft^2 margin for all of the "features" in the bed, such as the wheel well protrusions and bed floor corrugation. So it came to approximately ~120 ft^2 required total for two coats.
    According to U-pol, the 6-quart kit should cover ~126 ft^2 (~21 ft^2 per bottle) with 0.018" thickness. Therefore the 6-quart kit should be sufficient for 2 coats for a DCLB.
    I found this to be pretty accurate. When all was said and done I was left over with ~1/3 bottle. 5 & 2/3 bottles, per U-Pol, equates to ~119 ft^2.
    Kit used (with included gun): https://smile.amazon.com/gp/product/B074KPWNZD/
    Prep
    First, I removed all of the bed rails, bed bolts, D-ring bolts, and bed cubbies.
    I then prepped all of the surfaces to be coated by first washing, then sanding with 180-220 grit, then washing again, and then finally de-greasing.
    I masked everything off with frog tape, blue painters tape, and plastic sheeting. I installed the stock fasteners into all the threaded inserts in the bed to protect them from overspray. I masked the heads of the bolts to make sure they could be removed easily after application, but that probably wasn't necessary as I replaced all of the bed fasteners with new stainless steel bolts.
    Lastly, I used the Raptor Liner Adhesion Promoter: https://smile.amazon.com/U-Pol-Raptor-Adhesion-Promoter-Aerosol/dp/B07DGP6T45/
    Application
    I used the gun included with the kit which seemed to work just fine. I used an inexpensive pancake air compressor regulated to 50-60 psi at the gun.
    I followed the recommended application instructions and started with the corners of the bed. Next came the floor of the bed, and then the vertical surfaces last.
    I cleaned the gun with acetone-based de-greaser between each bottle.
    I waited 90 minutes between coats. I also did one "final" spray at the end of the 2nd coat with the gun much further from the surface to achieve some texture.
    I removed all of the masking immediately adjacent to the coated surfaces (and partially unscrewed all the bolts) within 30 minutes of the final coat.
    Results
    The bed definitely looks much better than before and I am pleased with the results so far. It's only been about a month since application, so time will tell WRT durability. So far, no complaints and I'm definitely glad I did it.
    Onto the pictures...
    Sanded:
    Fully prepped and masked (in my incredibly small garage):
    Immediately post-coat:
    Masking removed:
    Next day:
    Several days later (with new bed bolts installed):
    KB Voodoo side rail caps installed and bed tie-down rails re-installed (all with new stainless fasteners). I don't have a good "before" picture of the bed, but the tailgate cover shows a good comparison between the condition of "before" and "after":
    Bed cubbies reinstalled (also Raptor Lined, with new stainless fasteners as well):
    All KB Voodoo caps installed:
    And finally, covering up all my hard work with my bed mat:
  2. Sep 14, 2020 at 5:19 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Nice walk-through of the progress and awesome job!
    Are you eventually planning to spray the tailgate part? How good or bad was the over-spray in your garage? Are your side cubbies coated with something else?
    hoffengineering[OP] likes this.
  3. Sep 14, 2020 at 5:39 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Wow, that really looks good. Come back from time to time and let us know how it's holding up and holding on!
  4. Sep 14, 2020 at 5:53 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Great job!!!
  5. Sep 14, 2020 at 5:59 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Thanks!
    I plan on replacing the tailgate cover with something more robust eventually than the stock plastic, so I chose to not coat it for now.
    The overspray wasn't too bad. The liner is far thicker than something like spray paint and it tends to go only where you are pointing the gun--at the pressure I was using, with the supplied gun, I'd say the spray cone came out at ~20-30 degree angle. I masked like crazy just in case, but there was only really minor overspray where I purposefully sprayed past the edge of the bed to make sure I got full coverage. I lined the sides of the garage with plastic in the areas that I thought I would have overspray.
    The cubbies are coated with the same liner, but I prepped it slightly differently and accidentally coated it a little thicker than I wanted to, and end up with a slightly glossier, less textured appearance.
    Musubi3[QUOTED] likes this.
  6. Sep 14, 2020 at 6:04 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Thanks, will do!
  7. Sep 14, 2020 at 6:14 PM
    11rex11
    11rex11 Member
    Rex
    Washington
    2015 Tacoma DCSB
    ARB Bumper, 12k Badlands Winch, Offgrid4x4 Dual Batt
    Watching this thread, love the look! Wonder how this will fair after a few years!
  8. Sep 14, 2020 at 7:28 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Thanks man. I live in Southern California, so not too much crazy weather or snow except for trips to the mountains in the winter. I definitely plan on posting updates periodically though!
  9. Sep 14, 2020 at 7:34 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Very cool. Came out great.
    I’m about to raptor line my US Off-road low profile winch mount. Got two of their aersol cans and etching primer. Hope it comes out half as nice as your bed
  10. Sep 14, 2020 at 9:03 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Looks great!!
  11. Sep 14, 2020 at 9:14 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    That turned out a lot better than I was expecting. I really like the KB caps.
  12. Sep 14, 2020 at 10:25 PM
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
    Nice write up and great work.
    Turned out as well as I’d expect.
    With some proper prep and taping, you get a great finished product with that liner.
    I’ve done several pieces on my truck with Raptor Liner. I’ve used both from the gun/compressor as well as the aerosol can.
    Love their product. I’m curious to see how it holds up actually lining a bed. Let us know.
  13. Sep 16, 2020 at 7:26 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    Thanks. Yeah, as with most painting/coating projects, prep and masking definitely took the bulk of the time. It was probably 8-10 hours of prep work, and about 30-40 mins of actual spraying. Sanding the bed was the most time consuming/annoying part--all of the ridges and features made it pretty cumbersome.
    BizzyB726[QUOTED] likes this.
  14. Sep 16, 2020 at 7:33 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Awesome job, looks great.
  15. Feb 14, 2022 at 2:08 PM
    SilverbackOffroadRecovery
    SilverbackOffroadRecovery Member
    Luis
    2019 TRD off-road
    SmartCap bed replacement (coming soon)
    @hoffengineering any updates on how it’s held up? About to do this project the coming weekend and it’d be nice to know if I’m wasting my time or making a smart move.
  16. Feb 14, 2022 at 5:44 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    It's held up pretty well so far. It's been ~1.5 years since I applied it. There are some minor areas where the coating has started lifting and cracking, but they are pretty localized. Given how local the "failing" areas are, I chalk it up to not putting in enough prep in those areas. Most of those areas are also in internal corners or under the heads of fasteners (e.g. the heads of the bed bolts), which makes sense.
    Other than the handful of failure points, it's held up really well and has maintained its adhesion to the composite bed well. That being said, I have a bed mat in the bed 24/7 and I haven't hauled anything super hard/abrasive/heavy/etc. (so far just small amounts of lumber/soil/a few cinder blocks and then camping and wheeling gear—often on moderate wheeling trails). So while I don't take extra care to "keep it nice" (I routinely just wantonly throw stuff back there), I also haven't really put it through the ringer in terms of abuse either. It has been exposed to sub-freezing (I think ~10F?) all the way up to 110F-degree ambient temps—haven't really noticed any issues with temperature so far.
    Overall, I'm still happy with it. If I were to do it again, I would spend even more time on prep (mostly the sanding part) and use lower grit sandpaper when doing the prep. I initially used 180-220 grit; I would probably use somewhere in the area of 100 grit if I did it again. I do plan on patching the "failed" spots at some point using 80-120 grit to re-prep those areas (and probably an even lower grit on a flapper wheel to prep the still good liner at the boundary of the failed spots).
    I'll try to get some pics soon to show the "problem" areas.
    05Taco4x4 likes this.
  17. Feb 15, 2022 at 7:24 AM
    Luis
    2019 TRD off-road
    Okay great to know, thanks for your response. So definitely going to spend a shit ton of time on sanding the bed and focus the adhesion promoter on the problem areas that would tent to have lifting issues. And will stick to 80-100 grit. I also plan on running a bed mat since I have the DECKD drawers in the winter and don’t want any rub through issues, luckily they have the adjustment for the thickness of the mat.
