My first fishing trip did not go as planned
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Username1000, Oct 10, 2021.
  1. Oct 10, 2021 at 7:43 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Not a normal issue… if it’s out of oil your getting a new short block no doubt… shitty it happened like this. But man made machines will always be imperfect, and unfortunately you got unlucky.
    photogr4x4 likes this.
  2. Oct 10, 2021 at 7:44 AM
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Make sure you ask for warranty to be extended 10yr/100,000. Can’t hurt to ask.
  3. Oct 10, 2021 at 7:44 AM
    Empty_Lord
    Dan
    If the trucks not in 4x4 then it can be towed with the front wheels on the ground…. Won’t be any extra wear on the diff or axles since it’s the same thing as if your driving in 2wd
    Phlogiston, jmneill and TacomaGuy7878 like this.
  4. Oct 10, 2021 at 7:46 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Agreed in theory, just not sure why toyota requests a dolly in the manual then
    verynearlypure likes this.
  5. Oct 10, 2021 at 7:48 AM
    Empty_Lord
    Dan
    I never understood that. The only trucks that’s an issue with are the AWD 4runners and sequoias. antrhing with ADD can safely be towed with the front wheels on the ground
  6. Oct 10, 2021 at 7:50 AM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    So was there no oil or it leaked out? 2 very different things.
    69 Jim, DAS Taco and auskip07 like this.
  7. Oct 10, 2021 at 7:50 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    This sucks, but it happens. Just an unlucky draw and it's not limited to any particular brand. I had a 2018 Jeep Grand Cherokee that only made it 200 miles before it needed a cylinder head replaced. Hope it works out and your dealership does the right thing.
    2mtrux likes this.
  8. Oct 10, 2021 at 7:55 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    With the automatic you run the risk of damaging the transmission with the front wheels on the ground if you're dumb and have it in 4hi for some reason. With the manual there's no risk of damage since the transmission doesn't require an oil pump to maintain lubrication. It's wrong by the owners manual but doesn't carry the same risk.
  9. Oct 10, 2021 at 7:58 AM
    Empty_Lord
    Dan
    4hi in a truck with a manual in gear can lead to issues too..
  10. Oct 10, 2021 at 9:28 AM
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    Cover all idiot proofing….
  11. Oct 10, 2021 at 9:29 AM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    Much success brother
  12. Oct 10, 2021 at 9:41 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I really don’t wanna sound like a dick here but I have always been under the impression that checking fluid levels and tire pressure was just SOP before any road trip
  13. Oct 10, 2021 at 9:57 AM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Sucks man!
    I check new cars inside out I am buying same as a used car I would be buying.
    Check for frame damage, bondo repairs, engine coolant, oil color on dipstick, remove oil cap and smell inside engine, etc.
    I have never encountered a new car engine with no oil. That’s just crazy!!!
    Hope Toyota takes care of you.
  14. Oct 10, 2021 at 10:02 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I think that's on the dealership's checklist as well, before selling.
  15. Oct 10, 2021 at 10:07 AM
    #35
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    IMO, that checklist is worth the paper it's printed on.
    My dealership absolved themselves of that responsibility anyway. Claimed it was completed by the distributor(Gulf State).
  16. Oct 10, 2021 at 10:18 AM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Low oil pressure is a warning light, not an 'I'm out of oil and dead to you' light.
    No oil on the dipstick doesn't mean the crankcase is empty, just that you're down way more than you should be.
    IF you have no obvious leaks or blow outs of oil, my guess is they'll top it with oil, start it, and send you on your way.
    If you have lot's 'o wet stuff, it will get fixed. Start with an exam of the timing cover seal.
    Either way, I would, as someone else suggested, seek an extended warranty, since you were either given delivery of the vehicle with inadequate prep or had a failure of significance early in the life of the vehicle.
    Let us know the results..........
  17. Oct 10, 2021 at 10:19 AM
    #37
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    So it was fine for 500miles and just happened to dump the oil on your trip? Must of hit something or vandalism
    auskip07 likes this.
  18. Oct 10, 2021 at 10:25 AM
    #38
    Tacomod
    Tacomod Well-Known Member
    Or a leak that happens when the truck is running.
    Me personally I'd review the lemon laws for the state and see about getting a new truck entirely. A repair would be acceptable but a failure that early is not a great sign.
    The people saying be patient and work with the dealer are right.
  19. Oct 10, 2021 at 10:26 AM
    #39
    Empty_Lord
    Dan
    It’s part of our PDI. But if it had no oil for 500 miles it wouldn’t of made it 500 miles
  20. Oct 10, 2021 at 10:31 AM
    #40
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    That's a bummer for sure OP. I would be upset too.
    Chances are if you shut it off right away there was no damage to the engine.
    I doubt the oil was that low the whole time you've had it. Something must have failed to cause the oil level to drop suddenly.
    Hopefully the dealer and Toyota make this right for you. Like already mentioned I would push them for an extended warranty.
