My Footwell/cupholder interior accent led project (AKA Fighter Pilot Cockpit Mod)
Discussion in 'Lighting' started by RedruM29, Apr 14, 2009.
  1. Apr 14, 2009 at 2:37 PM
    RedruM29
    RedruM29 [OP] Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    So i decided to stay home and take a sick day today and i decided it was time to start my latest project. I ordered my Leds from http://www.oznium.com/prewired-superflux i got 5 of the orange Superflux Leds to light up my footwells, cup holder, and vent behind center console. I also purchased an led on/off switch that many people have used to fit the factory blanks (amber Led). So while i am waiting for the goods to get here tomorrow, i took apart my interior a little to familiarize myself with my upcoming project. Here are the items i am going to be using to do the install:
    Items List (that i used)
    - (5) Orange Led lights
    - 80' total 18 gauge wire (Red&Black power wire)
    - Assorted Crimp-on female spade connectors for 18 gauge wire
    - Assorted Crimp-on ring connectors for 18 gauge wire
    - (1) switch for the dash (lighted)
    - (1) mini fuse tap
    - (2) 10 amp fuses to fit the fuse tap
    - Black plastic wire loom tubing
    - Black Zip ties
    - Electrical tape
    - A crimp connector tool
    - Crimp Caps
    - T taps
    - Shrink wrapping
    - Wire cutters/ wire stripper
    - test light/ voltmeter
    - Phillips/ flat head screwdriver
    - Socket set
    Thanks to Rhoppas for the DIY after market lights thread
    Thanks to Totmacher at custom tacos for his thread (http://www.customtacos.com/forum/showthread.php?t=99899&highlight=led+lights)
    ChadsPride and cosmic stardust like this.
  2. Apr 14, 2009 at 2:41 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    can't wait to see how it looks!
  3. Apr 14, 2009 at 2:42 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Its gunna be sweet. Can't wait to see it man!
  4. Apr 14, 2009 at 2:44 PM
    Corralitos4x4
    Corralitos4x4 Well-Known Member
  5. Apr 14, 2009 at 2:59 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    First i decided to fit my fuses together and make sure the add a circuit was going to fit. I won't be using a relay because 5 leds should not draw enough power to need it. It went right in after a firm push then i choose my route to get to the center console. After looking at the diagrams on I opened up the area around the shifter and found all the screws i would need to remove to make the pilot hole for the cup holder. I want to put an Led or two in the vent in the back of the center console to give the back a little orange light too. I took a picture of the inside of the center console to show the screws needed to remove the back part of the unit. While i had the corrugated carpet piece from the bottom of the console out i put some tape making a handle for easy access next time. I also drilled out the black plastic cup holder divider to make some light holes and a place for the superflux led to fit in the divider.
  6. Apr 14, 2009 at 3:03 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Some more pics
    Side note: if anyone has any tips, tricks, or knowledge to impart, please do as it is much appreciated.
  7. Apr 17, 2009 at 12:44 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I got the package yesterday and everything came in a bubble wrapped envelope, I got the LEDS in three days! I am definitely going to order from Oznium again... The install took me around three hours to do everything I wanted to do, there was also a bit of partying going on at the same time, so it slowed my efforts a little.
    Disconnected battery first. I had made the harnesses and shrink wrapped everything up tight. I then attached the ends of the supply lead to the switch. I grounded the switch to the ground in the center console so i didn't have to go through the firewall(which was pretty sealed up i might add). I then connected the switch to the add a fuse and shrink wrapped the connectors. I then ran all the wires through the black loom tubing ziptied up nice and tight out of the way to the center console.
    While i was at the center console i put the first LED in the cupholder and it was a perfect fit under the divider. It needed some work to set the light flush into the plastic so i drilled out more and it fit fine. I siliconed this one in case of spills and wired it up with crimp caps and taped it. To get the vent how i wanted it i Zip tied and loomed the wire right into the spot i wanted it. With the superflux LED i was able to use one to light it up how i wanted with a subtle glow. I put the back of the console back on and ran my two other LEDs up to the floor vents(driver and passenger sides). I zip tied the LEDs instead of taping them for fear of the tape melting.
    I cleaned up everything and made sure to shrink wrap and tape all exposing wires or connectors(don't want to short out the circuit). Put the cupholders and middle console back in. Cleaned up all the tools and tested the lights, perfection. It was dark last night so i was happy to see that four LEDs lit up the truck just how i wanted, a subtle orange glow that is perfect for night vision. I still have one LED left so i have to decide where i am going to put it, Maybe someone could recommend somewhere.
    I hope everyone enjoyed my project, if anyone wants to do something like this and needs help just PM me.
  8. Apr 17, 2009 at 12:48 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    sorry the pictures were taken in the morning:eek:
  9. Apr 17, 2009 at 12:51 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    get some pictures that show the whole cab at night... i would be interested to see that
  10. Apr 17, 2009 at 12:59 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    cool project. Is it just for show or does it provide any amount of usable lighting?
  11. Apr 17, 2009 at 12:59 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    one more for good measure.
  12. Apr 17, 2009 at 1:03 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    It is a little of both i guess, I wanted to light the interior up at night if i drop something. I also wanted to see my cupholders for the numerous things that i put in there. This mod actually had a good side effect, it lit up my 4x4 switch a little too. The vent was more aesthetic in the beginning but now i can see in the dark on the floor so....
  13. Apr 17, 2009 at 1:06 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I guess I'm a bit late with a suggestion, but I think that I would mount an LED shining down on the cupholders instead of shining up.
  14. Apr 17, 2009 at 1:10 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I thought of that but there was no space above the cupholders that would have kept it from shining in my eyes. This way i can hide the LED inside the divider without getting blinded. good suggestion though if i could recess the LED i would do it your way.
  15. Apr 17, 2009 at 5:07 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
  16. Apr 17, 2009 at 5:17 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    X2
    nice work, looks good bro. nothing like taking a sick day to do up a new mod :D
  17. Apr 17, 2009 at 8:49 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I'm going out for my first night ride with the new night vision tonight. I'll post back with pictures of the glow when i get back.
  18. Apr 17, 2009 at 9:28 PM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    ok my camera sucks i can't take photos in the dark and make the lights show up... ugh
  19. Apr 19, 2009 at 12:50 PM
    jeff6001
    jeff6001 Well-Known Member
    San Antonio, TX
    99 trd prerunner
    Still looks pretty sick though. How many hours total did it take you?
  20. Apr 19, 2009 at 1:28 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    In the '09s, there is a little part of the dash that's bumped in that provides a nice little overhang. I have thought about doing this very mod - foot wells and cupholders...
