My Footwell/cupholder interior accent led project (AKA Fighter Pilot Cockpit Mod)
Discussion in 'Lighting' started by RedruM29, Apr 14, 2009.
  1. May 15, 2009 at 7:01 PM
    #41
    07tacoark
    07tacoark Still kickin like a headless chicken!
    Red
    Dallas, TX
    07 4x4 SR5
    Rock Sliders, Lift + allotta shit done over 12 yrs
    man that makes me wanna put LEDs in my ride :D nice!
  2. May 15, 2009 at 8:58 PM
    #42
    RedruM29
    RedruM29 [OP] Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    they are the four chip superflux leds so they had to be wired in parallel, i did this by making the harness' for the + and - coming from the switch. This is also good cause if one goes out then it won't take out all of them. If you do it this way then you can also add on more later using t taps. This is how i am going to wire up two other white flexible led strips, one in the glove compartment (for late night ipod switching for the HU) and one 4.7 in one to fit in the center console. Oznium 3 week wait though:tumbleweed:
  3. May 15, 2009 at 9:02 PM
    #43
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    oh ok, thats how I did mine.
    turned out great, I used two lights in the cup holder, one on each side.
    right now its set up to turn on with the ignition, i ordered a switch from oznium and ill set that up once it gets here
  4. May 15, 2009 at 9:03 PM
    #44
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    You should! have you seen all the colors too? They have Pink:p
  5. May 15, 2009 at 9:12 PM
    #45
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Dude that looks sick, what size led did you use for this? I thought of doing it that way but i thought it would impede on some of the larger bottles(gatorade) that i put in there.
  6. May 15, 2009 at 9:29 PM
    #46
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Im not really sure what size they were. but they came with a little black clip thing. I drilled a small hole in the holder and made it just barley big enough to squeez it through, crazy glued it in place to make sure it stays, then put the lights in, and crazy glued the back of them as well, they barley poke out into the holder, not enough to get in the way of anything.
  7. May 15, 2009 at 9:30 PM
    #47
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I am not sure how I managed to miss this thread for this long. I am glad my write up helped you out. The lights look great...
  8. May 15, 2009 at 9:33 PM
    #48
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I was wondering when you were going to show up. Ya man i used the basics from you minus the relay(no need) and it worked great, props.
  9. May 15, 2009 at 10:52 PM
    #49
    Chopper4Pilot
    Chopper4Pilot Active Member
    Not sure how I missed it either this long. I've been toying with the idea of doing a mod like this since I had a Ford Fusion as a rental back in November 2008 when I was traveling on business. It had these LED's in the footwells from the factory with a switch next to the shifter on the console that would alternate them between 5 different colors, then off. I might actually get the nerve to do it now. Nice job, and Thx dude.:D
  10. May 15, 2009 at 11:38 PM
    #50
    07tacoark
    Red
    Dallas, TX
    07 4x4 SR5
    :puke: i HATE pink!!!! NASTY :puke:
  11. May 15, 2009 at 11:40 PM
    #51
    07tacoark
    Red
    Dallas, TX
    07 4x4 SR5
    just thought of this, but how well are these LEDs against spills??
  12. May 16, 2009 at 11:42 AM
    #52
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    IDK I think they would hold up fine
  13. May 17, 2009 at 10:52 AM
    #53
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I siliconed the led into the cup holder for this very reason... i haven't had any spills yet but i tested it already with water and it was tight. O and about the pink haha we might be able to find something you enjoy:cool:
  14. May 20, 2009 at 3:15 PM
    #54
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Can anyone here help me out? where I can connect the wire to, I think about will be 2 circuits, one - when i open the door, I want to the footwall light grow up, when i close the door it will shut off, second - the cup holder led will light up all time but when i pull my key out it will shut off......
    Any idea? please give me the idea Thanks
  15. May 20, 2009 at 4:00 PM
    #55
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Ok you kinda confused me, but what i think you want is maybe wiring to the dome light to get what you want from the footwells and for the cup holders you would have to find some constant power like an add a fuse or going from the shifter led like Briangp has done here:http://www.tacomaworld.com/forum/2nd-gen-tacomas/35282-writeup-pictures-led-cupholder-mod.html. Hope this helps if you need to know anything eles there are some pretty good threads that have documented this just check my first post.
  16. Jul 11, 2009 at 7:43 AM
    #56
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    i just received more LEDs from oznium last night... pics soon
  17. Jul 13, 2009 at 8:54 AM
    #57
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    so i switched out my dome and map lights for LEDs and also added a flexible white LED strip to the ridge in the back of the center console so i do not have to turn on the dome anymore to find my junk in the console... it all works great. i hope to take some pictures tonight after Sommelier school.
  18. Jul 19, 2009 at 9:23 PM
    #58
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    ouch internet down time one week and counting...:crapstorm: so now i guess its going to take a little longer to put the pics online than i expected.
  19. Jul 26, 2009 at 8:15 PM
    #59
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    for the person that wanted the lights to grow...you probably wont achieve the desired effect with the leds b/c the have a lower voltage cutoff and cut on...soo more the likely there will be a slight delay and then they will just come on ....been my experience...
    on the oznium website it says the the superchip leds are waterproof...for the people worried about spills.
  20. Jul 30, 2009 at 8:31 AM
    #60
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    This is true...
