My Footwell/cupholder interior accent led project (AKA Fighter Pilot Cockpit Mod)
Discussion in 'Lighting' started by RedruM29, Apr 14, 2009.
  1. Feb 19, 2010 at 10:58 PM
    #81
    RedruM29
    RedruM29 [OP] Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    They are ran in parallel, I made wiring harnesses for the positive and ground.
  2. Feb 20, 2010 at 8:26 AM
    #82
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    It's kind of a primitive drawing but here is how I ran mine.
    if one goes out, the rest will still work.
  3. Feb 20, 2010 at 9:59 AM
    #83
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Thank you Keason, ya that is how I did mine too. If you made some more leads you could do the door pockets too. Someone else on here did it here pretty recently.
  4. Feb 20, 2010 at 5:02 PM
    #84
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    That helps out alot guys, thank you.
  5. Feb 21, 2010 at 4:06 PM
    #85
    SampleFool
    Ga
    Silver
    08 off-road
    Ok I did it and it looks great but my camera is not good enough to really get a decent pic, but the wiring was somewhat easy. I do though want to know were a constant source would be incase I want to turn them on with out the keys on.
    Oh one more thing the lower holes for the switches have wires connected to them on mine does yours? Also the the switch I got from ozium does not fit so I have to make it work tomorrow.
  6. Mar 9, 2010 at 11:55 AM
    #86
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    If you want a constant power supply just bust out the multi meter or (test light not recommended) and check which fuses are on when the key is out/off, just remember to have the correct fuse in the first slot of the add a circuit. Use the dremel or rotary tool and wear off some of the lip on the inside of where the switch is supposed to go. just take off enough to get the posts through. Don't worry about the wires running to the blanks its just for shit you don't have yet :)
  7. Mar 9, 2010 at 2:26 PM
    #87
    SampleFool
    Ga
    Silver
    08 off-road
    Now when you say yet what do you mean. Is the power running through them and were do they run to.
  8. Mar 9, 2010 at 9:15 PM
    #88
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    When I say "yet" I mean either for more lights elsewhere or switches for factory options you didn't get with your ride. Now I am not sure which model you have since you don't have it posted, but they would go to the lsd if you have off road etc. I'm pretty sure they don't have any power just the expandability to put other factory options in.
  9. Mar 10, 2010 at 5:33 AM
    #89
    SampleFool
    Ga
    Silver
    08 off-road
    Ok I will have to find out from the dealer what there would be, cause I want to take them out put a switch in there. I have an off road but no switches for lsd on/off if they come w/ that.
  10. Apr 2, 2010 at 6:58 PM
    #90
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    What would you need to do to make these lights come on when you have your headlights on? That's how I would want them to work.
  11. Apr 2, 2010 at 9:23 PM
    #91
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    ^you would need to tie in the power for the LEDs to a relay for the headlight switch somehow. That is beyond my capabilities tho:rolleyes:
  12. Apr 4, 2010 at 7:37 PM
    #92
    SampleFool
    Ga
    Silver
    08 off-road
    He is right, just find the power to them or the light switch in side. But use a relay for it. OR you could just put them to a switch and leave it on all the time?
  13. Apr 5, 2010 at 3:29 PM
    #93
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I think I am looking into it when I have time, but i have a plan that tie the LED light to the tempature control light.
  14. Apr 5, 2010 at 8:15 PM
    #94
    SampleFool
    Ga
    Silver
    08 off-road
    Smart idea man.
  15. Jun 11, 2010 at 7:10 AM
    #95
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    How are these LEDs holding up? Read somewhere they burn out quickly...
    And really wouldnt wanna get all the wires run, then have to redo it 2 weeks later
  16. Jun 11, 2010 at 11:11 AM
    #96
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    No problems with mine after almost a year.
  17. Jun 11, 2010 at 11:33 AM
    #97
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    same here, LED's last a very long time. A custom audio shop here builds led light bars and he said they will last around 11 years:eek:
  18. Jun 13, 2010 at 3:55 PM
    #98
    Logically Insane
    Wes
    TN --- USA
    Coolio.. ordering mine now... and hoping for a cooler day to do it on... lol
  19. Jun 29, 2010 at 2:43 PM
    #99
    LaTechLogan
    LaTechLogan Well-Known Member
    Logan
    Louisiana
    '08 PreRunner Sport
    - K&N intake - Pioneer headunit - 2 Kicker 10" subwoofers & amp - Nokya Hyper Yellow foglights - 18" Magnaflow muffler - Bilstein 5100 shocks set to 0" - Eibach coil springs - 1.5" blocks in back
  20. Jan 15, 2011 at 8:08 AM
    #100
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I dont know if I would call this more extreme as I have way more LED's in my Truck than that now but it sure looks good. Thanks for sharing.
