My Fuel economy success story
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMX, Sep 7, 2011.
  1. Sep 7, 2011 at 8:26 PM
    TacoMX
    TacoMX [OP] TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    After calculating my Fuel economy and discovering my 2.7L 1st Gen was only getting 14mpg in the city I had some work to do...
    I discovered my Manifold was cracked...so I replaced it with an LCE header..
    Cleaned the Throttle body (completely removed it to do it, more thorough)
    Cleaned IAC Valve
    Replaced PCV valve
    Switched to synthetic motor oil
    Cleaned the MAF
    Removed the crappy "option racing" ebay craptastic cold air intake and re-installed the stock intake system. (as well as doing the elbow mod)
    K&N drop in filter
    And I'm up to 17mpg in the city, and that is with 33X12.5 on stock gearing!
    So I'm happy..
    :cheers:
  2. Sep 7, 2011 at 8:29 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Nice work!! Bet it's nice to have the mileage back.
  3. Sep 7, 2011 at 8:38 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Ouch, 14mpg is definitely bad. Replacing cracked parts and cleaning old ones did wonders (obviously!).
    I get 18+mpg in my 3.7L, towing a trailer form central CA to WA and back. Granted, it's a fairly small tent trailer, running 265/75r16's...
    The key is to slow down. I did 55-60 the whole way.
  4. Sep 7, 2011 at 8:41 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    i get about 16 with 35s :D
  5. Sep 7, 2011 at 8:48 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Unlimited MPGS!!!!
  6. Sep 7, 2011 at 8:51 PM
    TacoMX
    Jonathan
    Deltona, Florida
    :bananadance::bananadance:
  7. Sep 12, 2011 at 12:32 PM
    Bee
    Bee Active Member
    Ca
    03 Tacoma 4x4
    My truck is sippin a lot of gas nowadays too i'd like to try that too to see if i can get my gas mileage back up. Where would the IAC and PVC valves be located?
  8. Sep 12, 2011 at 2:24 PM
    TacoMX
    Jonathan
    Deltona, Florida
    do you have the 2.7?
    If so...
    The IAC valve is on the bottom of TB held on by four philips screws. I cleaned it with some electric contact cleaner so as not to damage the valve. Take it off before you clean the TB because the crap from the TB will leak into the IAC. And be careful not to strip the four screws, they are really weak (ever take apart a carburetor??...you will know what screws I am talking about). I stripped two and has to use vice grips to remove them.
    the pcv valve is on the rear right hand side (looking at the motor from the front) of the valve cover. It has a vacuum hose attatched to it. All you have to do is remove the host and pop it out of the rubber grommet in the valve cover and replace it. (like $4 at autozone)
    good luck!
    even if you have the v6 it should be generally the same.
  9. Sep 12, 2011 at 2:26 PM
    saundern
    saundern Swerve for nothing
    Nick
    Greenville, SC
    2005 TRD Sport
    more than likely going to have to do some of those things soon, minus the cracked manifold mod haha congrats!
  10. Sep 14, 2011 at 9:29 AM
    Bee
    Bee Active Member
    Ca
    03 Tacoma 4x4
    yeah i have the 3.4 ill give it a shot. Thanks!!
  11. Sep 14, 2011 at 11:20 AM
    TacoMX
    Jonathan
    Deltona, Florida
    goodluck!
