my fuel efficiency journey
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greensystemsgo, Jan 21, 2012.
  1. Jan 21, 2012 at 8:57 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    lot of debate, and different results and numbers. i figured id cataloug what ive got going on on my journey.
    1999 v6 3.4ltr taco, 3" billy lift with eibachs and expos. stock size 31x10.5x15 tires, and 350lbs of weights in bed for expo's.
    general driving habits are smooth, smooth accel, smooth breaking, etc etc. not granny driving but still very reasonable. i shift at 2000 rpm, and if im in a neighborhood, like my own im in 3rd gear at 15mph which is roughly 1000rpm.
    my daily commute 6 days a week is 40 miles, 39 of them are highway.
    at 85mph i achieved roughly 15.5ish mpg with 87 octane. this is at roughly 3100rpm.
    this is obviously not very good, as toyota rated my truck at 18. now this is roughly 215 miles till needle hits the e, 230ish till the gas light.
    at 73 mph, which is roughly 2750rpm, i got 17.3ish mpg with 87 octane.
    this is ALOT better.
    now, on 89 octane, at 70 miles now driven, and 10 of those city streets cause of errands, ive used till the first tic. this is also not going over 73mph, smooth driving and so forth. when i fill up next i will report back on my mileage. but it feels extremely smooth and looks promising.
    i MIGHT try 91 octane but thats gonna be expensive :D
  2. Jan 22, 2012 at 8:03 AM
    Madjik_Man
    Colorado Front Range
    I'm not refuting your empirical data but higher octane ≠ higher mpgs necessarily.
    If your motor isn't high performance or turbo charged, then higher octane can actually be less efficient. This is what I found with both my Legacy and Tacoma.
    I'm pretty sure they use detergents (among other refining techniques) to make the octane higher. Those detergents are not conducive to fuel efficiency.
    I've been using fuelly.com, religiously, for a year now. I enter pretty extensive data into each fill up (octane used, if different, driving style, how much I used cruise control, temps for the week, etc..) and I've found that 85 octane yields just as good as mileage as 87 and better than 91.
    The single most important factor I have found to increase fuel efficiency is the use of cruise control. I use cruise control as much as possible and after I made that switch I noticed a 1-2 mpg increase every tank.
  3. Jan 22, 2012 at 9:03 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    When you say 85 is that ethanol? Can't say I've seen 85 here in the midwest.
  4. Jan 22, 2012 at 9:17 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    We're stuck with lower octane fuel here at higher elevations. :mad:
  5. Jan 22, 2012 at 10:46 AM
    Madjik_Man
    I live in altitude (5,363 feet)
    Higher altitudes require less octane.
