My Gawd, what have I done?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AkJohnE, Jan 13, 2022.
  1. Jan 14, 2022 at 7:14 PM
    #101
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    My insurance company gives me a discount for having TSS, that alone is reason to not disable.
  2. Jan 14, 2022 at 7:30 PM
    #102
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    You asked them to do it to your truck. How is it their fault?
  3. Jan 14, 2022 at 8:06 PM
    #103
    AkJohnE
    AkJohnE [OP] Well-Known Member
    2021 Tacoma
    Read the thread.
  4. Jan 14, 2022 at 8:27 PM
    #104
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Calvin Coolidge Worthington (November 27, 1920 – September 8, 2013) was anAmerican car dealer
    I just had to add to this...
    AkJohnE[QUOTED][OP] and Barsoom like this.
  5. Jan 15, 2022 at 1:57 AM
    #105
    Montana_Actual
    Montana_Actual ;)
    There are some stealerships that install monitoring systems on their vehicles. They usually mess with something else too in the process. I don't know the dealer you are mentioning, but just to clarify, is there any system on your truck to where they can track you and disable it if you miss payments? Sometimes they even work around mentioning it and people find black boxes on their vehicles spliced into wiring... Granted, it's in the paperwork, but not everyone pays attention when signing these things. Not saying you didn't or anything. Just trying to help get a solution here.
  6. Jan 15, 2022 at 4:23 AM
    #106
    Gearheadesw
    Davenport Fl
    I did, right in the OP you tell them to delete an option on your truck you didn’t like. It ended up deleting other options you want. It’s not their responsibility to educate you on your decision. You didn’t have answers, and neither did they, they did what you asked.
  7. Jan 15, 2022 at 7:07 AM
    #107
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I do not know the answer to your specific question. But, at least one person has posted that their truck is the same way, so this doesn't seem to be a unique situation. Since I already stepped briefly into this shit show, I'll throw this out there: It is entirely possible that the dealer is using the same information that you are from the TSB which seems to imply that constant speed control would still work after the procedure. That information from Toyota could be incorrect, in which case Toyota is (likely unintentionally) misleading their dealers and ultimately some customers.
    If this is the case, then the dealer should have a leg to stand on with corporate if you want to have the system put back to the way it was (give the dealer the replacement part for free or some kind of credit). HOWEVER, the TSB states in Step 1 to validate that there are modifications to the vehicle that might interrupt the function of the radar. If you do not have any mods, then the dealer should not have continued with the TSB, so Toyota may push back on the dealer if that is the case.
    This is likely an oversight on the TSB details, and the dealer has no way to know how to get it working again without reversing the procedure unless corporate helps them in some way.
    Either way, you did not receive what you were promised, and the misleading information came from the Toyota TSB. This should be for the dealer to work out directly with Toyota, and they need to get a field tech out to fix it or put you back the way you were and deal with Toyota for the cost of the part. It's that simple, and that's what you need to convince the service manager of.
    I think the manual states that you have to be going over 25mph/40kph for cruise to work, just in case you've only tried it while sitting still. Although, I think that just pertains to setting a speed, not turning cruise on.
    Editorial note: I'm a little surprised that the mod actually bricks the radar firmware, but it does say "permanently disable" in the TSB. That's pretty permanent. There are likely much easier ways to disable this just with an ECU update to bypass the option, but I am assuming a lawyer got involved and said that would leave it open to be re-enabled and likely pose some liability. This is what happens when people blame others for their own behavior. Like government requirements for automated safety features.
    Barsoom, wiljayhi and blu92in99 like this.
  8. Jan 15, 2022 at 10:35 AM
    #108
    AkJohnE
    2021 Tacoma
    As it turns out, CSCC does work if you engage it before you hit 20 MPH. Or so. After that you get the pop up to go see the dealer and nothing you can do will change it. The speeds at which cc will engage varies depending on whether its CS or radar. I think radar was 28 mph and CS is 25. So ...
    Bottom line is i can live with it as long as it continues to function and I simply have to remember to turn it on before i start rolling. This really indicates that the dealer does not understand these systems very well. No doubt they are complicated. However the TSP is pretty detailed as to the steps involved. Ultimately it was their responsibility to verify cs works when they are done. Which they did not and insisted cs would not work. I can only think the tech and dealer are not up to speed. This does not bode well for a vehicle that relies on electronics heavily. One can only hope Toyota did it right to begin with. Generally have faith that they did, still shit fails, usually at the most inopportune time and can only hope the dealer can make the repairs. To date they have failed that test, miserably.
    If I had it to do over I would have left it alone, I had no idea it would turn out this way. Realistically the dealer should have stated as much, but then apparently they are over their head.
  9. Jan 15, 2022 at 10:50 AM
    #109
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Sound like you are over your head
    Just_A_Guy likes this.
  10. Jan 15, 2022 at 10:59 AM
    #110
    AkJohnE
    2021 Tacoma
    Just try to keep up. Its all very complicated...
  11. Jan 15, 2022 at 3:39 PM
    #111
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Great response!
    This part is what screwed me: "HOWEVER, the TSB states in Step 1 to validate that there are modifications to the vehicle that might interrupt the function of the radar."
    I put in an aftermarket grill and had a shop fab a custom mount for the sensor and they were able to get it calibrated with my lift, different sensor position, etc. It worked fine on the pavement, but it was way more prone to throwing the clean sensor message anytime I took it in dusty conditions. I even had a smoked plexigless cover for it. I just got tired of it.
    I had no idea about the TSB or the impact to the radar until after the fact. I found all that out via this site. I printed out the TSB and took it to the dealer, and they said they couldn't guarantee it due to my mods. Here is a picture of my setup with red arrow pointing to custom sensor mount.
    I've just accepted the fact that I don't have Cruise Control now. If I really want it back, it will cost me $700 at the dealer. Lesson learned. Hopefully this will help somebody else contemplating this.
  12. Jan 15, 2022 at 6:32 PM
    #112
    AkJohnE
    2021 Tacoma
    Have you tried turning in out right after you start the engine? Hold it in as if you were engaging constant speed cc
  13. Jan 15, 2022 at 6:35 PM
    #113
    Mike402
    Palm Springs, CA
    Yep I tried everything. I even pulled up the thread when this came up when I posted about it and was showing the technician and he tried everything along with me. It just flat out does not work
  14. Jan 16, 2022 at 6:46 AM
    #114
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Great looking truck! I'm wondering if the grill material is confusing the sensor -- OEM does have some plastic in the way, but yours appears to be metal and might have a different effect on the sensor. I've been in the back of the line on lots of dusty roads and never get the message -- the only time I have gotten it is driving through freezing rain and snow when it got ice buildup everywhere.
  15. Jan 16, 2022 at 7:08 AM
    #115
    Mike402
    Palm Springs, CA
    Thank you! Good point, that could be it. I guess at this junction it’s a moot point for me
