My Grounds Are Burning UP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Potomus Pete, Jan 23, 2025.
  1. Jan 23, 2025 at 11:47 AM
    Potomus Pete
    Potomus Pete [OP] Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    As it says when I start my (( 2,7 occasioally the grounds smoke and burn. If i put my headlights on it will burn up my alternator.. Right now Im replacing ground wires but I need some answers for an amature. I dont know how to work a electric scanner. Is the ignition switch on Tacomas been known to short out. The problem seems to be at start
  2. Jan 23, 2025 at 11:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    The grounds burn up?
  3. Jan 23, 2025 at 11:59 AM
    545 Well-Known Member
    2015 Access Cab
    I’ve seen this before (on boats), and the problem is generally the main ground is broken or corroded so that it’s a higher resistance than a smaller ground, and electricity finds the easiest path to ground, through something it isn’t supposed to
    I’ve seen small ground straps glow red from the current going through them. Fix it before you start a fire
  4. Jan 23, 2025 at 12:09 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Have you changed anything recently related to the electrical system? Lights? LEDs? Switches? New alternator? Battery change? Fuse box mods?
    If anything has been added or modified recently, I'd start there.
    xxTacocaTxx and Moonrman like this.
  5. Jan 23, 2025 at 12:23 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    When your ignition switch goes bad.....normally it blows the AM1 or AM2 fuse, or both
    or stops working
    when a main common/ground in a house breaker box is broken......it causes the appliances in it burn up one by one...looking for a ground
    You should have a heavy duty ground going straight to the block
    that can get rusty/corrode down by the motor mount
    As these age weak grounds and vac leaks begin to plague these
    ace_10 and Moonrman like this.
  6. Jan 23, 2025 at 12:24 PM
    Potomus Pete
    Hippy
    I just put on two much stronger ground straps...I will work on it more tomorrow. It starts and runs great most of the time but my key switch seems old and sloppy. On my old Mustang the key could be responsible for the car burning up
  7. Jan 23, 2025 at 12:35 PM
    O'Silver_Taco
    MD
    Your key cylinder should be replaced every 150K.....
    if you wait too late.....key may not come out and you have to drill it out to get it all apart.
    I'd also recommend replacing the back switch part every 150K.....
    that can put you walking when it goes out
    beats all sheeet.....nothin lasts forever.....some of your existing faith is driving on bald tires
    MadNachos likes this.
  8. Jan 23, 2025 at 12:36 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    It's bad ground day is Venus in retrograde?
  9. Jan 23, 2025 at 12:39 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    I’m way over due, almost 500k but still work fine
  10. Jan 23, 2025 at 6:42 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    12V under high amps will find a ground even if it's a weak one. Corrosion isn't very conductive.
    Moonrman and ColoradoTJ like this.
  11. Jan 24, 2025 at 7:09 AM
    Potomus Pete
    Hippy
    The truck seems to smoke the ground wires when I turn the key. On my old mustang its a problem in the steering column
  12. Jan 24, 2025 at 8:21 AM
    Glamisman
    Glamisman Well-Known Member
    There are 3 grounds in the engine compartment that you need to investigate, one from the battery negative to the engine block, battery negative to the innder fender and p/s cylinder head (V6) to firewall. If you dont address this the current WILL find a way back to the battery usually through the throttle cable or the TV cable if an automatic.
  13. Jan 24, 2025 at 11:59 AM
    O'Silver_Taco
    MD
    As stated I'd clean and reseat all your grounds.....
    then I'd look for a stuck relay......I'd be attempted to pull em all 'cept for the efi and starter
    With the key on and engine off......what does an amp probe say
    Moonrman and MadNachos like this.
  14. Jan 24, 2025 at 1:31 PM
    MadNachos
    That is when the AMPs go big. One of your major grounds isn't grounded so the electricity is finding an alternative route over thinner wires. And like glamisman said it can even run through a throttle cable and ruin it by melting the liner.
  15. Jan 24, 2025 at 4:37 PM
    Potomus Pete
    Hippy
    Great help guys...I replaced the two smaller ones with large wire. tomorrow I will go after the main one off the cyl. head. I will respond how it worked
