My hids work with No relay. Wow
Discussion in 'Lighting' started by aidenhardcore, Feb 20, 2011.
  1. Feb 20, 2011 at 3:56 PM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Hey Guys, I thought we needed relay harness with our hids. I just installed a hid kit 8000k in heads using hi low kit on my 2010 dc.. Low hid and hi halogen and it seems to work fine np with no relay kit. everyone i talked to on here said i needed a relay harness. idk. do you guys use relay or are they only for the hid low and hid hi beam.
  2. Feb 20, 2011 at 4:11 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What kit did you buy? A lot of the kits are plug and play so it comes with all the parts and pieces you need to make them fully functional.
  3. Feb 20, 2011 at 4:17 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I already had ballast from my other truck a dodge ram. So i just brought replacement bulbs from hidny. I didnt use any relay and ballast are not hooked up to battery so ...
  4. Feb 20, 2011 at 4:21 PM
    Pugga
    Massachusetts
    You'll have to put up some pictures of your set-up. Sounds like despite yourself, you've made a functional HID set-up :cool:
  5. Feb 20, 2011 at 4:26 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    i think i did. I have no pics now But i just hooked up bulbs in ballast and to factory headlight harness
  6. Feb 20, 2011 at 4:27 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Most are
  7. Feb 20, 2011 at 4:29 PM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Thats a plug in play kit and should work which in your case it does. You need a relay when you are using HID's in as an aux light such as if you put them in some off road lights. The relay acts as a safe guard so as your not sending all that voltage to your aux switch inside your cab which could melt wires and cause a fire.
  8. Feb 20, 2011 at 4:30 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    ya so maybe you dont need relay for hids on tacoma .everyone esle saying you do need them
  9. Feb 20, 2011 at 4:31 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    If you don't know what you are doing. But I like relays because the wires to my switches can be low current.
  10. Feb 20, 2011 at 4:32 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    Oh so your saying elb that hids in headlights need no relay harrness but hids like in hellas need relay right
  11. Feb 20, 2011 at 4:33 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Let us know if you happen to blow a fuse unless you upgraded your fuses to your headlights. In my old Integra I had them hooked up as you do and blew fuses every once in a while. May have just been a short. But I hooked it up via relay and didnt blow a fuse after.
  12. Feb 20, 2011 at 4:35 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Having the relay has nothing to do with them working or not working. It has to do with protecting your stock wiring. They'll WORK without a relay. But you run the risk of potentially frying your wiring. Without the relay it's pulling power through your stock wiring, whereas with the relay it's bypassing that and pulling power right from the battery. Contrary to what a lot of people here often say, I'd NEVER run an HID kit without one. Especially with how cheap they are to buy. The ballasts draw a lot of current when they first fire up. For like 12 bucks, do yourself a favor and just get one to safe yourself from any headaches down the road.
  13. Feb 20, 2011 at 4:36 PM
    elblako91
    Blake
    1992 Toyo Pickup
    It will work but you run the risk of a melt down with out the relay if your not using the right gauge wiring. It depends really, Old cars with crapy small gauge wiring need a relay because the wire will not be able to handle the voltage. Newer vehicles may be ok because they use thicker gauge wiring. I would still use a relay to play it safe and that way your not running any risk. They are fairly cheap.
  14. Feb 20, 2011 at 4:38 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i thought relays were for bixenon bulbs where both HI/LO beams are hid. i could be wrong though
  15. Feb 20, 2011 at 4:38 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    OK Thanks for the help guys. I guess ill put one on. Thanks
  16. Feb 20, 2011 at 4:40 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    And so you make another new thread... hope you got the answer you were looking for
  17. Feb 20, 2011 at 4:42 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    Sorry memario forgot about the other one. my mind is like a old person, i forget everything
  18. Feb 20, 2011 at 4:52 PM
    memario1214
    Colton
    Missoula, MT
    It's cool
    Okay, for a bixenon HID setup, the purpose of the relay is for high and low beam control. Without a relay, the HIDs would not have Hi/Lo functionality. What I am guessing you have is a set of ebay style headlights that have 2 light bowls in each housing. I am not sure if it is possible to run it so that the bulbs will go to high beam and at the same time the "high beam" lights turn on as well. Essentially giving you 4 high beams on the road.
  19. Feb 21, 2011 at 9:18 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is the wattage of the lights that make a realy needed.
    HIDs draw 35 watts (but produce the light of 150 watt halogens)... your stock halogen headlights are around 55 watts...
    A pair of 100 watt halogen off road lights need a realy, a pair of 35 watt HIDs don't.
    A relay is used so all that power doesn't need to go through the switch in your truck.
    Just fyi, you do know that HIDs with 8,000ºK color are far less bright then those with 5,000º color, right? Blue to violet might help you if you are from a planet with that color star... otherwise it is for looks only.
    Halogens are about 3,000º... (slightly yellow) and the best output HIDs are between 4,000 and 5,000º (pure white with a hint of blue) which is the brightest light color for illuminating the road ahead. Above 5,000º the color become too blue and looses brightness.
  20. Feb 21, 2011 at 9:29 AM
    jtav2002
    Josh
    Reading, PA
    Yea, but it's not the constant wattage that's the problem. They pull a lot more juice when they first fire up. I've seen these kits do some really goofy things(causing voltage sags bad enough to cause headunits to restart, etc.) and that's with a relay. I personally wouldn't want to assume that my wiring is good enough for that constant draw every time you turn your lights on. To each his own I guess if you don't want to spend the 12 bucks extra. Sure, the risk may be small, but until someone can confirm that the wiring is actually sufficient for them I'd never feel comfortable myself telling someone they don't need it. I'd be pissed if someone told me it's okay and then my wiring burned up.
