My homebuilt 'True cold' air
Discussion in 'Performance and Tuning' started by dually, Mar 1, 2013.
  1. Mar 2, 2013 at 7:09 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Did you have to cut where it goes through the radiator pillar? I was looking at a similar set up for my AFe using the optional opening and routing some pvc just like what you've done.
  2. Mar 2, 2013 at 7:36 PM
    dually
    dually [OP] Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Yeah I used a 3.5" hole saw and cut through my radiator support. Used Some 3m double sided tape and 1/8" vacuum hose cut lengthwise to buffer the radiator support and intake tube
  3. Mar 2, 2013 at 7:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Water spray isn't a problem, but get splashed by a truck or do any mudding and you're up the creek without a paddle.
    Also, the open element exposed to the open grille is going to pack with dirt, and take damage from insects and rocks.
    I ran like that on my motorcycle for a year and finally modded the stock airbox cover to provide some shielding for the filter element.
  4. Mar 2, 2013 at 7:50 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
  5. Mar 2, 2013 at 7:51 PM
    dually
    I should elaborate on how I use my truck:
    No gravel roads
    No offroading
    Very few miles on highways or interstates
    I have a filter sock for it anyhow.
  6. Mar 2, 2013 at 7:53 PM
    dually
    :notsure:
  7. Mar 4, 2013 at 1:28 PM
    SoCaltaco65
    Um water does not evaporate that quickly without another acting force, i.e. heat.
  8. Mar 4, 2013 at 1:34 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Why not hide the filter? I've never understood why urd ran theirs right in plain sight... I'd tuck it down into the bumper or fender or some shit.
  9. Mar 4, 2013 at 4:55 PM
    dually
    There is.. uh.. heat in the engine bay. uh.
  10. Mar 4, 2013 at 5:03 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Kinda defeats the purpose if you think your tubes will get hot enough to evaporate water?
  11. Mar 4, 2013 at 5:06 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Just curious... what do you do with the truck? :crazy:
  12. Mar 4, 2013 at 5:15 PM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    05 AC Sport 4x4
    King RR Coilovers, FM 40, Allpro rear bumper, OME Dakar leafs, rear 5100's, Snugtop Rebel shell, Treadwright tires, Allpro apex front plate bumper, triple hella 700's, Blacked out headlights, CF hood, weathertech floor mats
  13. Mar 4, 2013 at 5:42 PM
    dually
    How much water do you think this intake is going to take on? You honestly think I'm running a garden hose down it? Minuscule amounts of water that *may* be consumed through the filter will not affect performance of the engine, as h2o is a biproduct of combustion.
    And it was asked what I do with my truck? I keep it clean and avoid least desirable conditions.
  14. Mar 4, 2013 at 5:46 PM
    Nixinus
    Nixinus Well-Known Member
    For all those talking about making the hood scoop functional: the hood is a negative pressure zone and therefore would actually get less air forced through the intake than the current setup.
    I think the concerns about water are valid. Maybe not for hydro lock but for air intake and air filtration. I am not expert so this is pure opinion but adding water to a filter element can't be beneficial to the amount of air that passes through it.
  15. Mar 4, 2013 at 5:48 PM
    #35
    dually
  16. Mar 4, 2013 at 7:06 PM
    #36
    worthywads
    I see, so you can avoid rain, shouldn't be a problem then.
  17. Mar 4, 2013 at 8:46 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    This.
    The only advantage of opening the scoop is that it will help evacuate hot air from under the hood, even more so when parked during the hot soak.
    But beyond that, it's only going to make a dirty spot on your hood.
  18. Mar 5, 2013 at 4:56 AM
    #38
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    That's what you get for trying to do something unique on TW. It could be the best mod in the universe and somebody here is going to find an issue with it and take a giant dump on you. Don't worry about them, IMO it's a pretty good mod.
  19. Mar 5, 2013 at 5:08 AM
    #39
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    If this works and you can develop one for the 2.7 I guarantee people will spend dat $$$$$
  20. Mar 5, 2013 at 5:09 AM
    #40
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    Silver 2010 DCSB 6-speed supercharged
    I've seen plenty of people run the URD intake with the water sock over the filter with no problems. Pulls air from the same place, no?
    It's the OPs truck, let him do what he likes. The concerns for water intake were addressed below vvv
