My Honest Review of K&N Air Charger CAI
Discussion in 'Performance and Tuning' started by Bfoster133, Jul 1, 2011.
  1. Jul 1, 2011 at 10:53 AM
    Bfoster133
    Bfoster133 [OP] If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    I dropped a K&N "Air Charger" CAI into my 2011 Toyota Tacoma...
    Here is my god honest review...
    Well the intake took about 60-70 Minutes to completely install. Every bolt lined up and everything fit like it was supposed to, nothing stretching to fit, nothing off. This was quite possibly the smoothest install i have performed on any truck in while.
    I took the stock intake out and built the K&N to test weight difference, like expected the K&N was about half the weight and 50% more space efficient.
    the K&N heat shield seemed to make a good seal and isolate the filter from the engine.... except the huge hole that the tube goes through... that being said, it probably isnt the most efficient heat shield in the world.
    my oxygen sensor fit right in, all the tubes lined up and fit perfect and it clamped to the throttle body just like it should.
    so enough on fit and looks, what about performance?
    well i drove 4 full tanks with K&N recording distance on two and performance on 1, and the very first tank was to let the computer adjust.
    since i dont have a dyno to accurately test the K&N i relied on my trusty Butt dyno... i know my truck better than anyone else and i think it should be about 75% accuracy of what a dyno will read...
    MPG's:
    well the K&N didnt exactly specify the gain i should look for, but in my real world situation it seemed to only gain 2-3 MPG (circumstantial)
    i wouldnt say its the K&N that helped.. maybe it did maybe it didnt... could just be the way i was driving and weather etc..
    POWER:
    Well lets be honest here... the k7n claimed 13-15 hp was pretty off... i would say about 5-6 hp gain.. but any poney gain is a friend of mine..
    the k&n really helped in the top end power around 4-6k rpm's
    with none of the gain below 3k rpm
    SOUND:
    Wow... this thing sound amazing.. anything above 4k rpm is like my trucks engine came alive and wants to eat the next door neighbors dog.. it really growls and howls and i am impressed as sound goes
    BOTTEM LINE:
    MPG gain?- not really
    HP gain- maybe 5-6hp gain
    Seem to allow more air flow?- yes it seems to be alot more flowing
    Sound- incredible :cool:
    Would i recommend?- i would definitely recommend it but dont expect the 13-15hp claim
    Thank you for reading
    Video sample:
    speed limit was 45 mphs, i will admit i was doing 50-55 :eek:
  2. Jul 1, 2011 at 11:09 AM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    Nice write-up Blake, my friend with the same seemed to say the same thing, mostly sound, which he got annoyed of eventually haha - been riding much?
  3. Jul 1, 2011 at 11:10 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Good job man! I remember K&N talking on "Gears", they said something like "K&N doesn't put out a product unless it gets you at least 15 horsepower". They also published stuff about the efficiency of E3 sparkplugs, so I digress.
    Anyway, thats basically what we would expect from bolt-on performance. Do you think it's worth gasketing the hole in the heat-sheild?
  4. Jul 1, 2011 at 11:46 AM
    Bfoster133
    Blake
    i think if they provided mor of the gasketing tubing for the heat shield it would help a little, that seems to be a big area where heat could come through
  5. Jul 1, 2011 at 11:47 AM
    Bfoster133
    Blake
    yep quite a bit, may be heading out tomorrow, not sure where yet though
  6. Jul 1, 2011 at 11:49 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I have this also, but if I could do it all over again, I'd get TRD or AFE
  7. Jul 1, 2011 at 11:53 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I found that the K&N I had on my 98 5.2L Grand Cherokee actually robbed low end power, just like you found up to 3,000RPM the K&N can be a parasite on some engines. All of their power gains on the dynos are around or above 5,000RPM
  8. Jul 1, 2011 at 10:06 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    What your experiencing is how long it takes that intake to get the temperatures down to ambient air temps. I used to have a K&N then I got the AFE.
