My ignition key is stuck in "lock" position. Please tell me what I can do to get it to "acc"
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996_2.4, Mar 13, 2025.
  1. Mar 13, 2025 at 1:49 PM
    1996_2.4
    1996_2.4 [OP] Well-Known Member
    Update on my stuck 1996 5 speed ignition lock. I hope this helps people.
    1) sprayed WD40 and was amazed it fixed the lock. But only for 1 day. I pulled the key out and when I tried again the damn thing was stuck again.
    2) I made it to work and left the key in "acc" position for 4 hours. Then at lunch I went out and started the car to make sure the battery wasn't dead. Then I went back to work for the next 4 hours. I'll take a Dann dead battery over a stuck key that won't turn over.
    3) NAPA sold me a lock today for $45. Yes, I can get one on Amazon for $15. But dud you know there are 2 different ignition locks for 1996? One for tilt wheel and one for standard wheel. If you look at Amazon all they do is specify the year. I'm so darn glad I didn't have my dash torn apart only to find Amazon sent the wrong lock, and then I would have to put the broken lock back in a pray it would work.
    4) The NAPA lock I got came in a NAPA box, but is a Echlin brand. I've never heard of Echlin, are they good.
    Tomorrow I'm going to try to pull this lock that's been stuck in place for 28 years. YouTube makes it look easy. Any advice if the darn thing is stuck, there is no room to use tools there.?
    Thanks to everyone who offered suggestions
  2. Mar 13, 2025 at 2:12 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    is steering wheel in locked position at same time key wont come out?
  3. Mar 13, 2025 at 3:41 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    My Taco is doing the exact same thing right now. Crazy but when it does this, I pull the key out and reverse it, push it in, and about 95% of the time, it works! I really think a LOT of this problem is associated with our ignition keys getting worn out to the point that the "teeth" are not actuating the tumblers in the switch.
  4. Mar 13, 2025 at 3:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Can you get it to release by gently moving the wheel side to side while wiggling / turning the key?
    mike759 and ace_10 like this.
  5. Mar 13, 2025 at 6:08 PM
    1996_2.4
    It can be locked or unlocked. Each way the key gets stuck
  6. Mar 13, 2025 at 6:09 PM
    1996_2.4
    Have tried that yet. But WD40 has got it working for now.
  7. Mar 13, 2025 at 6:10 PM
    1996_2.4
    Hey I tried WD40 and got it working now. NAPA has a replacement for $45. And Amazon has a Dorman brand for $26, but it does not specify if it's for tilt steering or not.
  8. Mar 14, 2025 at 7:16 AM
    mike759
    mike759 Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    I've had this issue from time to time and it was the auto shifter not "fully" in park. The transmission would be in park but the shift lever wouldn't have clicked whatever mechanism frees the key from the cylinder. If you give the shift lever a firm push into park you may get that satisfying click.
  9. Mar 14, 2025 at 7:40 AM
    Glamisman
    Glamisman Well-Known Member
    This ^^^^ if it is an automatic trans. The shifter bushings need to be replaced. Driveway job, maybe 2 hrs if you have the tools, 40 minutes if you have done it before.
  10. Mar 14, 2025 at 11:45 AM
    1996_2.4
    Thank you but I didn't mention I got theb5 speed. Some wd40 got it moving and I got the new ignition from napa. I did not know there are 2 different locks, one for tilt wheel and another for standard
  11. Mar 14, 2025 at 11:47 AM
    1996_2.4
    Some WD40 got the key moving. I got a new ignition to install this weekend. I found out not all 1st Gen locks are the same. The tilt wheel is different from the standard wheel. You tube videos make it seem like a 10 minute job. But my.loch has been in there for 28 years. I hope it's not stck
  12. Mar 14, 2025 at 11:48 AM
    1996_2.4
    Lucky I have the 5 speed. WD40 got the lock moving for now
