My interior power outlets (cigarette lighter) aren't working!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hiphopcr, Nov 8, 2008.
  1. Nov 8, 2008 at 10:41 PM
    hiphopcr
    hiphopcr [OP] Well-Known Member
    California
    08 PreRunner SR5 Crew Cab TRD Sport
    My dual 12V auxiliary power outlets (one's a cigarette lighter) aren't working. I drive a 2008 Crew Cab Tacoma and it's perfect and flawless except for this one little thing... which sucks because those outlets power my GPS and iPod adapter and I'm heading out on a long road trip!
    Any ideas?
  2. Nov 8, 2008 at 10:42 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Check the fuse?
  3. Nov 9, 2008 at 4:27 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    I second the motion on the fuse(s). Check the 12v adapters (plug in parts) of the devices you use. I had a Sirius Sat. adapter that I thought was in good working order. The thing quit working one day. Looked at the fuse, SNAP!!!. Come to find out the adapter was shorting out. I used the 12v ports in my Dad's truck to diagnose and I smoked the fuse(s) there too. I changed the fuse again, bought a new adapter and all is well.
    I'm assuming something went bad because I constantly swapped the adapter in and out between the BIG truck and the 'Coma.
  4. Nov 9, 2008 at 6:38 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Happened to me many months ago -- fuses fuses fuses.
  5. Nov 9, 2008 at 6:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Silly question-but have they ever worked??
  6. Nov 15, 2008 at 4:19 PM
    BONTONWHO
    BONTONWHO Active Member
    Caliwaii
    05 PreRunner 4.0
    Im almost 100% that its the fuse. I was on a road trip from San Diego to Canada and was using a spot light to help where needed... Mine went out and luckily i found a dealer right off the 1 at the California/Oregon cause I had no idea where a shop would be.. They hooked up 2 fuses and i was on my way! good luck
  7. Nov 15, 2008 at 4:48 PM
    PetesTaco
    PetesTaco New Member
    North Carolina
    '08 4x4 TRD Sport
    Cold Air Induction, Cat Back Exhaust, Aftermarket Jensen VM9512
    I also have an '08, and have found that my power outlet main switch controls my lighter outlets too. Hope this helps. The switch (actually a button) is marked with AC 115V.
  8. Nov 15, 2008 at 5:13 PM
    TicTacOma
    Columbia,SC
  9. Nov 15, 2008 at 5:56 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    One other thing to check - Those outlets only work when the key is in the ignition and switched to the "ON" position. If you are checking them while the car is parked and not running, they will not work.
  10. Nov 23, 2008 at 10:50 PM
    hiphopcr
    California
    It was the fuses. Luckily the fuse box in the Tacoma is very well organized and easy to access, and it even came with tweezers and spare fuses!
  11. Nov 24, 2008 at 6:44 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    +1 on that. Blew mine a month or so back. When you find them, their is an extra.
  12. Nov 24, 2008 at 8:19 AM
    Munkey
    Munkey Well-Known Member
    Paducah, KY
    2008 Radiant Red 4X4 Double Cab Sport
    OEM Tube Steps, Bed Extender, Pioneer Avic D3 with Bluetooth and XM Radio modules
    Glad you found it. But now that you've used the spare, don't forget to stop somewhere and buy some so you'll have spares again.
  13. Nov 24, 2008 at 8:28 AM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    Ummm, just curious, but why did you need a spot-light on a road trip?? About the only thing they get used for around here is poaching! :popcorn:
