My Kenwood stereo loses power
Discussion in 'Audio & Video' started by surfox, Dec 10, 2013.
  1. Dec 10, 2013 at 9:13 PM
    surfox
    surfox [OP] New Member
    San Diego
    01 Tacoma SR5 TRD
    I bought a Kenwood DPX500BT and installed it in my 2001 Tacoma. It works great except for the times when i start my truck and the stereo does not want to power on. I checked all my wiring and looks good. I checked all the fuses and none of them are blown. The only way i can get it to work again is by removing the fuse from underneath the hood and put it back in. It does not do it all the time but maybe twice a week and sometimes i can go a 2 weeks without a problem. Any ideas on what is causing this?
  2. Dec 20, 2013 at 3:33 AM
    Aw9d
    Aw9d That one guy
    Go over all the wires again with a fine tooth comb. Replace that fuse. Lots of things could be the culprit with this.
  3. Dec 20, 2013 at 4:12 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Dedicated wires directly from the battery (fused) and directly to a GOOD ground! 14ga or larger should be sufficient.
  4. Dec 20, 2013 at 7:10 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    is it a detachable face? if it is try pushing on the face. Sometimes there isnt good contact there and will cause the radio to appear off or not come on at all
  5. Dec 20, 2013 at 8:41 AM
    tony7758
    tony7758 Member
    Tony
    Pearland, Texas
    2012 4WD TRD OR
    Start by trying to isolate the problem. Try to check it when you are having he problem, before you pull the fuse to fix it. . What I would do is this. Next time it happens check first if the power wire at the back of the radio is hot. Check with ignition in ON and in ACC position. If it is hot at the radio then it is a problem with the radio or radio ground. You can check ground with a wire from the Neg battery terminal to the Radio shell or box. With the radio on and the key on. Just touch the screw head holding the radio in the mounting bracket with the ground wire you connected to the neg battery terminal. You could also tap into the ground wire coming out of the radio to check this. If the radio plays you have lost the ground to it. It could be a rusty screw on a ground wire or loose ground wire. If you have power and ground confirmed it is the radio. intermittent problems are a pain. All you can do is try to isolate the problem when it is happening. Good luck
